Campy downtube shifter cable stuck in lever
Quoted: 211 Post(s)
Liked 199 Times
I know this has been discussed before , but wondering if anyone has come up with a solution ?
There are a few ideas I have read, but not any " follow up" with solutions.
Here are a few pics.
Shifter is off the bike with cable attached.
AND....does anyone know what size head end is ?
Appreciate any and all help.
Quoted: 839 Post(s)
Liked 1,061 Times
Try clamping the cable with vise grips, a vise, etc. and twist the lever in the direction that tightens the cable spiral. This might loosen the head so it can come out easier. Adding a little penetrating fluid for at least a day can't hurt either. Also a soldering iron can be used to melt the head or get it soft enough to move.
Likes For Crankycrank:
Quoted: 211 Post(s)
Liked 199 Times
That sounds great Cc !!!!!
I am wondering if a glue gun tip ( without the glue of course) would be hot enough to soften the head .........??
Really appreciate your help !
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Agree a glue gun will not generate enough heat. I might try dimpling the center of the head with an awl and then carefully (slowly) try drilling it out with a bit just smaller then the head to break it up. We have been successful doing this same type of operation in the past.
Likes For JoeTBM:
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
First approach would be to carefully put the lever in a vise, then use a thin needle nosed plier to grab the cable opposite the Bowden stop (this type of cable is called a Bowden cable, in case you're interested) and then push. If the needle nose is thin enough you'll grab the cable really close to the lever. And the first push would be like 0.2 mm. If this didn't work I'd clip the cable as close as possible to the lever, and use a pin vice with 1mm wire to push. The cable should be 1.2mm I think.
Quoted: 211 Post(s)
Liked 199 Times
I believe you are correct Cc !!
Glue gun probably will not be hot enough.
I have tried to twist it.
I may cut a notch in the head and use screwdriver to loosen.
What do you think of cold??
Like putting in a freezer overnight?
Or letting it soak in fluid??
Thank you again for your time and help.
I did not put this cable in BTW.
I have campy cables ready to go.
Other side cable head comes out
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Penetrating oil and/or the freezer. That's a 'Shimano' cable end, you should see how the Campy are slightly smaller and a different shape.
Quoted: 839 Post(s)
Liked 1,061 Times
Quoted: 1944 Post(s)
Liked 2,164 Times
Since this isn’t C&V, once it is out does it make sense to enlarge the hole enough to fit a Shimano compatible cable?
On downtube shifters it seems like a pretty easy task.
John
John
Quoted: 211 Post(s)
Liked 199 Times
Thanks again everyone for all the great replies!!!
I have many drill bits....pretty new ....and will use this method.
I was thinking about drilling as well.
Very happy that it has worked in the past for someone here on this invaluable site with the best people!!!!
I'll update as soon as I am successful...
Thank you all again!!🚲🚲🚲🚲🚲🚲🙂🙂🙂🙂🙂
Very much appreciated
Quoted: 645 Post(s)
Liked 797 Times
Quoted: 966 Post(s)
Liked 1,629 Times
I got one of these out using and old metal ball point pen refill. It was dry and it just barely fit over the cable. After cutting off a section I threaded the cable through it and tapped the head out. It worked!!!
I am not sure but I think the pen cartridge was from and old Cross pen.
Quoted: 2432 Post(s)
Liked 638 Times
I had that problem once and I heated the shift lever with my heat gun then used some needle nose pliers to grab the cable and "push" it out. Came out pretty easily.
I bought a cheap heat gun about 20 years ago and it's one of the smartest things a home mechanic can get. Used it just a couple of days ago to break the drive cups loose on a cartridge bottom bracket before I stripped them with my tool and then I removed some ugly rim decals on another bike yesterday.
elcraft
I drilled a tiny hole in the lead stop and twisted in a mini wood screw. I was ble to wiggle and pull with a plier until the lead end came out.
Industry guy
The perils of using generic shift wires with Campagnolo.
Campagnolo makes their spec's slightly different on such things.
rusty
rusty
elcraft
“The Curse of Proprietary parts”! I am finding this manufacturing tendency becoming more and more common. From Hot Tub filters to watch parts, many manufacturers seem to want a long term “subscription” relationship with their customers. Don’t even get me started about the Trek Madone Seatmast.....
Likes For elcraft:
elcraft
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
Likes For SurferRosa:
Quoted: 211 Post(s)
Liked 199 Times
Have not drilled it out yet. Going to the bike shop, who is a friend of mine to drill it out.
Waiting to get some " soft jaws" to put in the vise.
Have NEW cables which are campy 1.1 mm
Will update when cable is out.
Thank you again for all the great responses
