Will this rear rack work with panniers?
Full disclosure: I'm cheap.
I have had this Walmart rear rack before. It seemed to work well. But I am thinking about panniers, and I am not sure if these will keep the panniers away from the rear tire well enough.
Blackburn 45 Lbs. Capacity Lighted Rear Bike Rack $24.97
https://www.walmart.com/ip/Blackburn...4?athbdg=L1600
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I would guess it will work with some panniers that don’t need much support (have stiff backs) and also don’t need to hook at the bottom. My Arkel Metro would work, but my old Banjo Brothers one would not.
To be honest it does not look like a great design to me if you plan to use panniers, though.
Also, the rack looks really high.
Likes For Kapusta:
Quoted: 540 Post(s)
Liked 416 Times
Have you considered used?
A used rack that is complete and intact without any broken welds will function and hold just as it was designed for.
Racks should never be fastened to both seapost and axle frame eyelets. One or the other, not both. The reason being that a seatpost is considered movable, even if it is not a quick release.
Seatpost clamped racks are the only option when a rear suspension does not allow a frame mounted rack.
Otherwise, a proper rack is to be fastened entirely onto the frame for utmost solidness.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
$15 more, tried and true,last for decades and never fail:
https://www.walmart.com/ip/Planet-Bi...Black/31986263
Thanks. I don't have any rear suspension. From what I have found, used tends to cost as much, or more, than new. When I look on craigslist, I think "these people must be out of their minds."
The rear rack in photo looks great.
I am not crazy about both seatpost and axle frame eyelets, but I can get by with it.
Quoted: 540 Post(s)
Liked 416 Times
Instead of the walmart website, have you visited a local Walmart Supercenter?
They will have frame-mounted pannier racks in stock.
I've bought and installed many of them due to supply chain scarcity.
The trade-off with a seatpost rack is that your center of gravity is high and a heavy load will make your bike wonky and dangerous.
Ideally you want all cargo to be as low as possible.
But hey - it's your bike. Not mine
But, I don't want to be top heavy.
Last time I was at Walmart, their bikes, and bike parts, selection was pretty bad. It's been like that since the supply chain issues started.
Likes For soyabean:
Advanced Slacker
Liked 2,537 Times
The echo the previous post, I’ve been using a brake mount stay for 10 years on this bike:
It actually has seat-stay mounts, but one of them is blocked by the brake caliper on this particular frame size.
Likes For Kapusta:
Tragically Ignorant
Liked 9,098 Times
I would be extremely wary of an off-brand like that, especially because there's an exceptionally large number of parts involved in making that particular model "adjustable" and failure of any of them under load could be a big problem. If you're going to go cheap, at least go simple.
Quoted: 137 Post(s)
Liked 81 Times
$.02 if you’re wanting to carry panniers on a road bike with shortish <17” chainstays consider front low riders with medium to small panniers and rear rack for bulky light loads. It’s a poor fit putting lots of weight behind the rear wheel of a bike not designed for weight in that location even though most pictures and people put stuff there. Rear racks on road bike, cross bike, gravel bike, modern mtn bike, light touring bike, etc. are common but not ideal for panniers simply because the pannier has to be moved far back to clear heels. Absolutely nothing wrong with a cheap rear rack I’ve used a bunch but if your goal is carrying panniers where you have to elevate or extend the panniers far back or high then you are choosing bad handling more than meeting a budget.
If your need is a rear rack then get a good cheap rear rack that attaches to seat stays and attach it so the deck clears the tire or has room for fenders. If you need a rack for panniers and the rear position compromises handling get the cheapest front rack, low riders or small platform rack that enables the panniers to be mounted as far back as practical on the forks.
Likes For LeeG:
Quoted: 137 Post(s)
Liked 81 Times
Most of my touring was without panniers and rear rack holding a medium sized stuff bag plus five lbs or so on the handlebars. If you have to have a pannier sized load front low riders is hands down the best route if your rear wheel is not especially robust.
this looks good
https://www.modernbike.com/delta-mega-rear-rack-ultra
https://www.modernbike.com/racktime-...ng-clamp-black
Likes For LeeG:
Quoted: 18416 Post(s)
Liked 15,556 Times
I’ve had some experience in this area. Current setup.
Likes For indyfabz:
All the racks should hold the panniers out of the wheels, the biggest problem is whether the bike handles a rear load well and whether you have to slide the panniers too far back to clear feet. Lots of people have ridden “10 speeds” with heavy rear loads and learned to live with a twitchy front end and cheap rear wheels going out of true.
this looks good
this looks good
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,434 Times
I got a few of the Axiom racks pictured above (post 3) for less than $30 each new. They are solid.
Likes For Polaris OBark:
https://www.walmart.com/ip/Ventura-E...Steel/11065174
You will want panniers with a solid side so they cannot get into the spokes of the wheel. Measure how much distance you need from your heels to the panniers to determine maximum size that will work.
Load capacity means next to nothing. What is important is how rigid the rack is with a load on it and want to minimize any sway of the rack and its load. The touring type racks have bracing to insure there is zero flex. They are not designed to fold for shipping which also makes them sturdier and better overall. Check out the design of the Blackburn Outpost Rear World Touring Rack. It is made much like the ones I have had to buy from UK dealers in the past for my own touring.
Likes For Calsun:
Liked 15,556 Times
I think the Blackburn Outpost is a bit outside the OPs budget. By a lot.
Likes For indyfabz:
