what do you think?
Bikes: cannondale 400st, dean el diente, specialized hybrid
Quoted: 20 Post(s)
Liked 7 Times
what do you think?
I've been riding road and rail trails for a long time. Lately I've been watching a lot of single track and mtb videos and I find it quite appealing. Living in sw wi there is not a lot of single track available but there is some. Keep thinking about a hard tail and the likelihood of breaking a hip trying to learn a new style of riding at 71 with a bad back and crap knees. Crazy thinking?
Quoted: 1397 Post(s)
Liked 1,878 Times
single track can be a blast and my guess is you would enjoy
might depend on the areas where you can ride - start easy and progress from there
maybe start with a combination of dirt roads and some easy trails
areas you might want to limit or avoid - and / or push through :
> rocks - some scattered rocks might not be an issue - but extremely rocky areas / rock gardens can be a real challenge
> extreme climbs and descents
> extreme mud
> winter riding with frozen ground / snow / ice
> tree crossings - small trees not too much of an issue but larger trees can be a real challenge (dismount and lift / carry bike over)
> exposed roots - most times not much of an issue but larger roots can be a challenge especially when wet (and more-so if you cannot square up to them)
> extreme rutted sections can be a challenge
probably more I cannot think of at this time
> extreme mud
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
I have chronic spinal issues and love riding bikes. Personally, I would not even attempt to do that. But I have had 4 surgeries and have numerous discs that are not in very good shape. I do get sore knees with a lot of clicking and creaking, so I would not subject them to that abuse either. I have no idea what shape your body is in, but in reality, only you can decide. Anyone you could borrow a bike from to give the single track a try? If yes, I would try that on relatively low impact single track to see how you feel. Progress from there if all is good.
Quoted: 241 Post(s)
Liked 454 Times
Ride within your handling abilities and you may be fine...always look down the trail to prepare for difficult sections, wet roots, baby heads, etc...if you wait until you are on top of them it is likely too late.
Quoted: 20 Post(s)
Liked 7 Times
Thanks for responses. I suspect borrowing one or finding a used bike may be the route I take. The single track available here is not too technical, so I'm thinking doable. On the other hand if I'm laying on the ground with a broken hip, my definition of technical may change.
Quoted: 581 Post(s)
Liked 921 Times
The main skill to learn is maintaining momentum- a bicycle without a rider will coast through surprisingly rough terrain without any help, it is the rider who often interferes and causes the bike to stall and fall over. And unless you are doing high-speed downhills, the primary hazard is slow speed falls when you can't keep the bike rolling.
Quoted: 5224 Post(s)
Liked 3,581 Times
I didn't start crashing until I got a mountain bike. in my early 60s, so I think I can keep going a cpl more years. less crashing would be nice
Quoted: 3238 Post(s)
Liked 2,086 Times
You would want to be riding single track that does not have an abundance of difficult technical features that require skill and stamina to ride. The Trail Forks app often shows a lot of the single track in a particular region and often times is color coded as to difficulty levels. Yellow and green tend to be easier (as I recall). I'm only a few years behind you, have been mt. biking 33 years, but have stopped riding trails with technical features as I no longer want to get hurt in a fall, takes a lot longer to heal and my wife is tired of dealing with an injured husband doing something stupid.
I pretty much do all my mt. biking in fall and early winter (before we get persistent snow cover), when road riding is too cold. We can mt. bike down to 15-20 degrees comfortably, not moving as quick (8-10 mph avg,) are not out as long, and less wind in wooded areas. I transition to mostly road in spring and summer to avoid ticks and poison ivy.
Likes For Steve B.:
Quoted: 643 Post(s)
Liked 1,526 Times
Anyone considering a mountain bike at 70+ is obviously in good shape but it would be a good idea to consider that old bones aren't young bones and if you look at the outcome for seniors who break hips it's shockingly bad. I know in my case, I used to ride motorcycles and gave it up after a serious crash. I've thought about mountain biking but have decided against it mainly due to the injuries that some friends have had.
Quoted: 1949 Post(s)
Liked 2,010 Times
If you need to drive to the trail, I say skip it. And if there is only one trail nearby, skip it.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2582 Post(s)
Liked 5,639 Times
I started mountain bike riding in my 50s after 30 years of road. I found it to be great fun and required a far amount of new skills. I liken road bike riding to cross country skiing where mountain bikes are like downhill skiing requiring your full attention, moving your weight and constantly thinking ahead.
If you ride within your comfort level and keep to ;beginner trails (blue) which are not technical, you should be fine. If you find a part of the trail which might make you uncomfortable, it is no crime to get off the bike and walk it over that section and then get back on again. I have done that many times and even more now that I am approaching 70.
I wouldn’t worry about breaking bones unless you have balance issues already.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
Dumb dumb dumb idea. Go find a paved road with scenery.
10 years ago I had a little slide because of springtime sand on the street. I figured it would be ok to use the side of my knee to break the fall.
Wrong. It cracked the top of the leg bone. Didn't need a doctor but it was sore to touch for a month.
Quoted: 8280 Post(s)
Liked 9,042 Times
I'm 68, been riding off road bicycles for 30+ years and off road motorcycles for 10 years before that. I think it's great fun and has the advantage of no cars. Also, wind and weather is much less a factor than on the road.
If you're going to try it, start easy and get used to the feeling of the bike moving around. You can't just ride like a road bike, you need to learn the techniques and practice. If you're riding dirt roads and smooth trails, any bike will work. If you want to do anything technical or ride with any speed, I recommend a full suspension bike.
A rear suspension is easier on your back, will track the ground better, and will save you from your mistakes. Also, the rear brake works better with suspension.
I have what is known as an "enduro" style bike. 160mm fork with 150mm rear travel. It's 32 pounds and a bit of a chore to climb long hills with, but it's so much fun to descend on. If I could just get a new bike now I would go for a shorter (120-130mm travel) lighter bike. I've tried to tone down the risk in the last couple years and I have no problem getting off and walking a section.
No form of bicycling is completely safe but my worst crash was on the road bike on a bike path.
Here is my KHS.
Here is my KHS.
Liked 9,042 Times
Mountain bike group rides are a blast!
We did a shuttle ride and the van took us up to 9200 feet and we rode back down. We brought lunch and took pictures and it was so fun.
I'm on the right and in the center is a friend who is 71 and she is an excellent mountain biker.
Liked 9,042 Times
I used to go to Lake Tahoe but haven't been there in years. Awesome trails up there!
Quoted: 1944 Post(s)
Liked 2,164 Times
Here is my take on your situation. I started mountain biking at 61. I rode a lot of different trails crashed, got up, kept riding, and continued to push myself. I was also surfing so balance wasn’t an issue.
I can say that the amount of skills needed to do somewhat technical runs is off the charts. Even with decades of riding a road bike it is a completely different animal. The best I could get to was low intermediate. It is still a blast.
Mountain biking can be done at 71, but if you started 40 or 50 years earlier it will be a lot easier since you have established skills.
There are some similarities with surfing in that having decades behind me, I can still get out there at 70, but it might be different if I was just starting out at that age.
And like mountain biking there will be situations where you have to just go for it as being timid will only put you in a bad situation. That is the toughest part, putting the pedal down because hitting the brakes will only lead to injury.
John
John
Liked 1,878 Times
Here is my KHS.
Here is my KHS.
I can recall installing a 'long travel' kit on a Judy XC fork - to increase the travel to 80mm lol ... in the rear had 60-80 mm travel (?)
and this was living large - after forks with 60 mm of travel - and before this it was often just a rigid fork and a 2.2 Ritchey Z Max lol
Liked 9,042 Times
sweet looking KHS ! and with 160 / 150 mm susp travel !
I think it was 80mm and the Rock Shox fork was 63mm.
My first rear suspension bike was a 1998 K2 with a Girvin fork and Noleen shocks front and rear. Yes, the fork had a little shock and linkage on it. I put the older Manitou fork on it after the Noleen blew up. When the rear Noleen went bad I bought a custom air shock from Risse Racing. I had a lot of fun on that bike. The frame broke after 10 years.
Then I got my first KHS and rode it for 10 more years. It was 100mm on both ends but my LBS gave me a 130mm fork for it.
Liked 1,878 Times
good stuff !
this thread is motivating me to get back on the trails - if I lived near rck I would be tempted to hook up with him to find some good (and easy lol) single track !
Let's do a Century
Quoted: 651 Post(s)
Liked 879 Times
RCK, No! No! No!
That’s all I have to say.
Ride your Ride!!
Ride your Ride!!
Quoted: 20 Post(s)
Liked 7 Times
Big John-Nice pics and makes the thought more appealing. Down side is there is no biking like that in sw wi. Closest single track is 30 miles away. It does seem somewhat counterproductive to drive in order to bike, not that I haven't done so before and will likely do once again.
jppe-I suspect that I will bow to your superior wisdom. One of those rare times that I will let my brain decide rather than my heart. I must be getting old!
Liked 1,878 Times
yikes - I don't know which is worse
no close single track (really ?)
or allowing brain rather than heart
Liked 1,878 Times
if you do decide to give it a try - and find something / somewhere to ride off road
maybe you can first find an inexpensive MTB - even something old / vintage / rigid ... just to give it a try
( and make sure the bike is sized properly - often a smaller size bike is recommended for off road use )
