Fat Guy Wanting a Nicer Bike
Hey there, this is my first post, so if I'm in the wrong place, my bad. Anyhow, I've recently got back into cycling, last year I bought a Jamis Coda S2 used and found out I missed riding. I typically do about 15-18 mile rides 4x a week, but I've been having issues with the bike and I'm pretty sure it's due to my weight. Last year I broke numerous spokes on both rear and front wheels, after replacing them (and subsequently breaking them) I just bought a new wheelset. Fast-forward to two days ago and I realized one of my spokes while riding was super loose. I took it to the shop and they're going to do a tune on it, but my bike is down until the 28th.
And now I'm bored to death. I don't know what to do till then, however, I have thought of buying a second bike, just for situations like this, and keeping the Jamis as a back up. I am eyeing a used 2017 Specialized Tarmac SL4 Sport, but their website says it has a structural weight limit of 240lbs, and I am 300lbs. Also, the 20H and 24H wheelset that comes with it does inspire confidence that it would bear my weight. Any thoughts on this? It looks like a very nice bike, but if I have to spend another $300+ on a wheelset, it just seems silly.
Quoted: 1397 Post(s)
Liked 1,877 Times
what size tires can the Tarmac SL4 Sport accommodate ?
at 300lbs you will want to have a decent size tire under you
if max tire size is around 25 or 28mm - this alone might be a reason to look at another option
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
I really think you need to get a bike and wheel set that will support that much weight, and have clearance for, at least, 35mm tires. Not being critical, but, you probably have extra pounds you could lose. Otherwise, wheels are always going to be an issue. My recommendation is 36 spoke wheels with heavy duty rims. Modern wheel builds and wider rims, you could probably get away with fewer spokes. Having said that, here is a link, https://www.novatecusa.net/product/novatec-30/, to a pretty heavy duty wheel set. the rims are 20mm internal width, spokes are 20 in front, and 24 in back, but they are heavy duty spokes. The rear wheel is 8 non-drive and 16 drive side. This is to give you an idea of what to look for.
I have a set of these that I use with tubes. The hubs spin very well, the wheels roll just fine. They are heavy, almost 2000 grams for the pair. With the 20mm internal, some pretty wide tires will work on them. Wide tires will help support the weight. At $200, pretty hard to beat. There are other options out there for heavy duty wheels. Do some research. Also, I have to have at least 2 bikes just for the reason you stated in your post. I am on a self imposed, 2 day sabbatical from riding bikes. That is hard for me. I have to have other things to keep my mind and body occupied, or I cave and go for a ride. My legs were feeling quite tired as I have been pushing the mileage this month. The 2 days will pay off. I have gotten a lot chores and errands done, and have done some minor work on a couple of bikes.
Likes For delbiker1:
Miles to Go
I don't think the Tarmac SL4 Sport is a good choice for you. Are you committed to going from flat bars to drop bars? If so , there are better choices, but honestly, the Coda you already own is better up to the task of carrying your weight than the Tarmac once the wheels are properly addressed. Ask the shop to stress relieve and properly tension the spokes.
If you want a different bike with drop bars, you might consider a touring bike like the Long Haul Trucker or Fuji Touring. They are built to carry a heavy load long distances.
Liked 1,877 Times
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
B.U.F.F.
Welcome to bike Forums.
We have a section dedicated to just such questions.
You might want to go for a look by clicking here >>> clydesdales-athenas
All the best
Barry
All the best
Barry
Went to a local bike shop, was convinced out of buying a second bike by the manager. Suggested wider rims with eyelets and a wider tire. Said nothing he had in stock, near my price range at least, would suffice besides an MTB, which I don't want to do.
Quoted: 624 Post(s)
Liked 396 Times
I also weigh over 300lbs. 36 spoked rims that are wider and high flange hubs will solve your problems. Availability of parts can get in the way. I recently purchased ebikes for me and the wife. Prior to purchase I contacted the manufacture and was told that the wheels were the weak point. I am replacing both front wheels. Velo Orange high flange front hubs. Ryde Andra 40 rims. Sapim spokes. I purchased belt drive ebikes so the rims and spokes is all I need for the rear. The Ryde Andra rims are as tough as it gets.
Likes For Rick:
Bikes: 2000 Litespeed Appalachian, 1998 Litespeed BlueRidge.. 1977? Schwinn LeTour 12.2 'Rain Daze'
Quoted: 64 Post(s)
Liked 17 Times
I can NOT believe a 24 H trip being recommended for 3 bills.... things NEVER CHG here. That is just NUTS.
Do NOT buy second hand wheels.... for sure at your poundage. And do not sweat the scale reading... YOU are riding...
32's are ok... YET DO NOT chase those wheels now w repeated breakage. 32 requires high end built at that load.. quality components---see spokes. Factory wheels
mostly are not high end.. by miles. Bike shops notorisly are NOT QUALIFIED to true a wheel to 'stand'. IE... hold up.
Lots of us around that could set you up. Suggest a wheelbuilder w experience... worth the coins. By miles.
Likes For Aladin:
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I weigh less than you but regularly carry more weight than you + bike since I've always been a fatty on a bike I always make sure my wheels have quality hubs, strong rims, and are HAND BUILT from a wheel builder that has seen me, my bike, and my purpose. Like magic I've never broken a spoke, my wheels aren't flexible when I get out of the saddle, and they don't go out of true. My wheels aren't aero or cheap but they take my fat ass and anything I want with out drama and that has value.
Likes For Germany_chris:
Quoted: 966 Post(s)
Liked 1,629 Times
Good time to learn how to true your own wheels. You can also replace your spokes with some stronger spokes. It's pretty easy to go to 13ga spokes if your are using 14ga.
Here is what it takes to start:
#1 - Youtube - (This is a GREAT TOOL!!!)
#2 - Spoke Wrench 5USD
#3 - Spoke Tension Meter 20USD
#4 - Zip Ties, Bull Dog Clips 2USD, or if ya really wanna get into it a Wheel Truing Stand (30USD)
#5 - Cassette Removal Tools 16USD
All these things can be bought for almost the cost of one wheel truing at the bike shop. Fun, Fun, FUN...
Likes For zandoval:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
May be out of your price range and availability may be an issue but for a new bike look at Salsa. Two years ago I asked about the weight limit for a Warroad.
““As an ASTM Condition 2 bicycle the Warroad is rated for a 300lb rider and 55lbs of luggage!”
Salsa has other less expensive models.
Quoted: 1088 Post(s)
Liked 1,024 Times
You don't need a better bike, just better wheels. Personally I find 26-27c tires to be a fine width, I'm currently running 25 on my road, 25 on my track bike and 27 on my cross bike for summer use, and I find the tires to be fine and wouldn't like bigger than 27 unless I was riding dirt or gravel. Wheels absolutely need to be 32h or 36h, my gravel touring runs 32h rims and I'm typically within 12-15lbs of your current weight and another 40lbs with load so with the right spokes it'll do fine with 32. Spokes should be 13 gauge at the hubs, most spoke companies make that, built with a decent weight mtb rim and a decent hub. I used wtb rims that have no problem with 25c tires and can go out to 38c with no trouble but work well with a road bike. You want to find a shop that can build something similar and can do it for about 400.
Quoted: 4227 Post(s)
Liked 2,488 Times
There is nothing wrong with your bike, the problem is wheels. For somebody your weight you need heavy duty wheels with 36 spokes and bigger tires.
I also have a Jamis coda (size 21 for me) and have carried over 300 pounds of me and groceries.
I have a 36 hole wheel in back, it's been pretty bulletproof but still occasionally goes out of true. I picked up how to true wheels with the bike flipped over on bars and seat; its not that bad.
I can totally recommend the bike for losing weight and gaining muscle. I'm down to 215 from 328 two years ago. Jamis coda rules!
Likes For theapodan:
Quoted: 2700 Post(s)
Liked 486 Times
I maxed out at around 270 and was riding 23s at the time with no issues. Most of the wheels I’ve ridden were factory made and get out of true easily. Get good wheels or learn to deal with speed wobbles, I’ve never crashed from a speed wobble and most cruddy back wheels seem to have several spokes that lose tension, and the wheel will be out of true but not “dangerous” in that it shouldn’t hamper your handling significantly and won’t fail suddenly.
also there are bigger boys than you riding little race bikes with thin tires, don’t let people tell you you’re too fat for a drop bar road bike. Also you want higher psi in tires, the thin guys will think the pressures you have to run are crazy
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
At 300# you should also consider comfort. Skinny wheels and tires are going to translate a lot of harsh vibration and road chatter.
im a 6’4” 270# Clydesdale. I ride a Jamis Renegade steel frame and use 40mm wide tires on the road for comfort. I ride tubeless and fairly low pressure around 40-50psi.
Previously I was riding an aluminum Trek Domane with 28mm high pressure tires and that thing damn near shook my body apart and cause all sorts of spinal and nerve issues. That bike might be fine for someone up under 200# but not fine for a Clydesdale.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
IGH wheels are far stronger and so are Dutch bikes. Look for a steel city bike with a Nexus 7i. That's what my latest roadster has. I have NO problem going 100 miles with any of my heavy IGH bikes. I did change the front hub to a SA XL-FDD dyno drum brake.
I'm not heavy, but my 120 lbs loaded tour bike is, 290 to 300 lbs total. It has a 32h Rohloff14.
And IMO, rim eyelets are a useless gimmic. My wheels all have Velocity Dyad rims, 35 and 38 mm. One has 28,000 heavy miles and looks as good as new.
Quoted: 7652 Post(s)
Liked 3,473 Times
The main thing is to keep your wheels well-maintained.
I weigh about an eighth of a ton---a little less than you---but I have been riding for years on 24- and 28-spoke wheels, with no problem.
Spokes break for two reasons, in my experience---potholes and similar sharp impacts---- and Being Too Loose. Check you wheels frequently---tap the spokes and listen for low-pitched vibrations.
As far as buying a new bike---go for it. But choose very carefully. Maybe consider a cheap bike as a back-up since you probably won't be riding it that often--How often is your main ride in the shop, right?--so maybe consider a decent used bike, and then in a few years, as your fitness improves, you can decide what you might want based on your needs and wants at that time.
Yes .... big people can ride, and love rising .... so keep living and riding and enjoying.
Likes For Maelochs:
Bikes: Eddy Merckx Corsa Extra, Basso Loto, Pinarello Stelvio, Redline Cyclocross
Quoted: 336 Post(s)
But at your weight you're going to continue to have wheel problems and you just have to get used to watching your wheels closely unless you're running 32 mm tires.
