How to lace a 32 hole hub on a 36 hole rim?
Old 03-10-07, 11:47 AM
caotropheus
caotropheus's Avatar
Greetings fellas
Do you know of any example or have you tryed to lace a 32 hole hub on a 36 hole rim? I want to lace a wheel fixed/free, so I need a three cross lacing patern or two cross lace partern.
Welcome your suggestions.
caotropheus is offline
Old 03-10-07, 11:56 AM
Sheldon Brown
Gone, but not forgotten
Sheldon Brown's Avatar
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times in 5 Posts
Originally Posted by caotropheus
Greetings fellas
This is not a good idea, because the rim will have unsupported arcs where the 4 missing spokes should have gone.
Using a hub with more holes than the rim is workable, but tricky.
Sheldon " https://sheldonbrown.com/mismatch " Brown
Sheldon Brown is offline
Old 03-10-07, 12:04 PM
Wil Davis
Curmudgeon
Wil Davis's Avatar
Bikes: (see https://wildavis.smugmug.com/Bikes) Bianchi Veloce (2005), Nishiki Cascade (1992), Schwinn Super Sport (1983)
Liked 4 Times in 4 Posts
First Thoughts: Why?
Second Thoughts: OK, if you really want to do this; you will have to "lose" 4 holes on the rim. So, that means 2 holes from each flange; you might get away with having empty holes diametrically opposite each other for the first flange, and the same thing but at 90º offset for the spokes from the other flange.
There might be a problem here, as on a good rim, the holes are usually drilled slightly offset from the centre of the rim so that they provide a better angle for the spoke to the flange; if you skip a hole, you now have the spoke going to the "wrong" flange (for that side).
Third Thoughts: see First Thoughts.
- Wil
Wil Davis is offline
Likes For Wil Davis:
Old 03-10-07, 12:19 PM
urbanknight
Over the hill
urbanknight's Avatar
Quoted: 998 Post(s)
Liked 1,206 Times in 692 Posts
There are two possible ways I would do this:
1) Sell the hub and buy a 36 hole one
2) Sell the rim and buy a 32 hole one
urbanknight is online now
Likes For urbanknight:
Old 03-10-07, 01:08 PM
dbg
Si Senior
dbg's Avatar
Bikes: Too Numerous (not)
Quoted: 23 Post(s)
Liked 10 Times in 8 Posts
Go ahead and try. The folly of it will sink in eventually but you'll have had good brain exercise while you're figuring it out.
dbg is offline
Likes For dbg:
Old 03-10-07, 01:28 PM
Gravity Worx
Parts Guy
Gravity Worx's Avatar
Bikes: several
Exactly
Gravity Worx is offline
Old 03-10-07, 02:59 PM
urbanknight
Over the hill
Quoted: 998 Post(s)
The problem is what happens if his "folly" doesn't happen until he's out on the road and all the overtightened spokes rip through the rim?
Old 03-10-07, 03:52 PM
Stacey
Non Tribuo Anus Rodentum and off to the next adventure (RIP)
Stacey's Avatar
Sheet happens when you least expect it.
Stacey is offline
Old 03-10-07, 04:32 PM
vpiuva
vpiuva's Avatar
If you use 24 spokes, you would use 12 of 16 on each flange, so 4 groups of three with a skipped hole, and on the rim 24 of 36 holes, so skip every third hole, each group of 2 would have a spoke from each flange. Probably go 2 cross with this. (have fun with the spoke lengths - probably need 2 lengths for each flange). Then I'd hang it on the wall and feel all warm inside knowing that I could do this - show it off to bike chicks and my riding buddies. Then buy/build a properly constructed wheel to ride.
vpiuva is offline
Likes For vpiuva:
Old 03-10-07, 06:24 PM
Michel Gagnon
Year-round cyclist
This is the kind of thing you do if you are stuck in Desmaraisville, QC (pop. 3) with a broken rim and find a 1950 abandoned bike in the bush.
Michel Gagnon is offline
Likes For Michel Gagnon:
Old 06-27-22, 04:28 AM
David.P
David.P's Avatar
Quoted: 7 Post(s)
Why not carefully drill two additional spoke holes into each of the two spoke flanges of the hub.
David.P is offline
Old 06-27-22, 05:11 AM
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
Liked 582 Times in 399 Posts
sweeks is offline
Old 06-27-22, 05:22 AM
David.P
David.P's Avatar
Quoted: 7 Post(s)
No train wreck unless you want to use radial spoke patterns
David.P is offline
Old 06-27-22, 08:02 AM
ClydeClydeson
Quoted: 581 Post(s)
Liked 921 Times in 518 Posts
Not impossible, but will likely be a grade 12 level geometry problem repeated 16 times to figure out the various different spoke lengths you will need, then a very long day of lacing and re-lacing until you get it 'right'
Much better idea to sell the rim or hub, and get one that matches the hub or rim.
ClydeClydeson is offline
Likes For ClydeClydeson:
Old 06-27-22, 08:29 AM
squirtdad
squirtdad's Avatar
Quoted: 2338 Post(s)
Liked 2,824 Times in 1,541 Posts
am even more ridiculous idea than the 32 spoke in 36 rim
I am truly hoping this was satire, but not clear
squirtdad is online now
Old 06-27-22, 08:56 AM
David.P
David.P's Avatar
Quoted: 7 Post(s)
Sheldon Brown at some point even recommended doubling the number of spoke holes in the hub, and then fumbling the different numbers of holes in the rim and hub together in a suitable way.
In case the rim does not have spoke holes alternately slanted sideways, this is the way to go:
David.P is offline
Old 06-27-22, 05:42 PM
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times in 1,617 Posts
Also, we'd have a good fail story with photos for the next guy who comes in here to ask the same question.
DiabloScott is offline
Old 06-27-22, 05:47 PM
zandoval
zandoval's Avatar
Quoted: 966 Post(s)
Liked 1,629 Times in 1,045 Posts
WOW... Everything is on Youtube... Bravo... Good find...
zandoval is offline
Old 06-27-22, 11:03 PM
tkamd73
Quoted: 604 Post(s)
Liked 1,064 Times in 535 Posts
Proven once again, common sense is an uncommon virtue.
Tim
tkamd73 is offline
Old 06-28-22, 07:54 AM
David.P
David.P's Avatar
Quoted: 7 Post(s)
Sounds like someone is crashing hard into their common sense horizon right there
David.P is offline
Old 06-28-22, 08:39 AM
_ForceD_
Sr Member on Sr bikes
_ForceD_'s Avatar
Bikes: Several...from old junk to new all-carbon.
Quoted: 1019 Post(s)
Liked 785 Times in 414 Posts
I did it once on a road bike front wheel. I road it for years and never had any problems.
Dan
_ForceD_ is offline
Old 06-28-22, 12:06 PM
urbanknight
Over the hill
Quoted: 998 Post(s)
I sincerely hope that, 15 years later, the OP has decided on how to proceed. I am curious if you have considered how to address spoke length calculation and lacing pattern with these carefully drilled holes.
It's like riding a bicycle
