What size of tube do I need to accomodate my tire?
I have a Vittoria Zaffiro Pro tire in 700c x 23 size. I'm a total newb to this, so I don't know what the numbers mean. What size of tube would I need to accomodate this tire?
I saw some 700x25 on sale, but I'm thinking the 25 might be a width so it will not fit.
Please suggest.
Please suggest.
Thanks! Just ordered a kenda 18/23c from Amazon!
As far as the numbers: I assume 23c is the width? Then what is 18?
Tubes will expand and fit a variety of different width tires. In the case of a 18/23c the tube will fit a tire that is anyware from 18 to 23c wide.
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
pan y agua
Quoted: 1456 Post(s)
Liked 733 Times
^ It's a range. It means the tube is intended for tires 18mm to 23mm wide.
Innertubes stretch a lot. You don't have to be too precise with them. A tube nominated as 18-23 will work in a tire 25-28mm wide 9or more if you push it).
And a tube labeled for 25mm wide will work in a 23mm wide tire, although depending on the tube, you may have some difficulty getting the tire seated without pinching off the tube.
[edit] Garysol types faster.
You could get lost and die.
You could hit a tree and die.
CAT4
Bikes: 2009 Cervélo S1, 2009 Felt F75, 2010 Cannondale Synapse Carbon 5, 2011 Cannondale CAADx, 2011 Specialized Transition Elite
^^^ Found a better deal online. I have Amazon Prime membership, so I get it 2nd day w/free shipping. It's worth it.
