First time hub buying
Old 04-30-11, 01:36 PM
Treyburn
So my lock ring stripped today and ruined the threading on my hub just a few weeks after I stripped the other side for the exact same reason.
I was running the stock cog and lockring that came with my vuelta pista wheelset I purchased last year, so I'm assuming that was the culprit as after I stripped it the first time I took my bike to my lbs to make sure everything was tightened properly and I wouldn't strip it again (that worked out well).
What kind of measurements and so forth do I need to know when I begin looking for a new hub online? What kind of brands do you guys recommend? I'll be buying a new cog and lockring as well so what kind of brands do you recommend? I'm looking to spend 40-60 for a hub, and 20-30 for a cog/lockring.
Treyburn is offline
Old 04-30-11, 01:38 PM
Sebster
Sebster's Avatar
Iro Hub is $20.
Formula/All City is the next step up
Both sealed I'm pretty sure.
Measurement is usually 120mm spacing, but if your dropouts are different, order accordingly.
Get Dura Ace Cog/Lockring, about $30 for both, or Retrogression stocks steel cogs for a good price.
Sebster is offline
Old 04-30-11, 03:07 PM
stryper
I just wanna ride
stryper's Avatar
Bikes: 2013 BMC Impec
I don't understand how a cheap cog or lockring is stripping threads. I have a $5 cog that I've run on some bontrager wheel and hub for a year, over to a friends weinnman wheel for 6 months, and now I've been running on my dura ace hub for the last 2 years. I've had no issues with it at all.
I have plenty of friends that ran the stock cog that came on their weinnman wheels from an ebay store, no problems. My brother ran his stock cog from one of those real cheap $120 wheels, tubes, tires, cog, freewheel sets off some eaby store, again no issues. I think people are just weak and don't know what tight really is
stryper is offline
Old 04-30-11, 03:28 PM
xkillemallx16
Originally Posted by Sebster
Iro Hub is $20.
iro/formula/origin8 are the same. novatec/allcity are the same. all are excellent hubs for a budget price, sealed - and can be replaced by phil wood bearings if need be. grand compe's are a step up in terms of finish, performance i assume is a bit better if not a wash. all can be had for a relatively decent price.
agreed on da cogs, that is, if you need 14-16t (they dont make em higher)
xkillemallx16 is offline
Old 04-30-11, 05:27 PM
Treyburn
Thanks for the input all, going with a formula hud and da cog/lockring
Treyburn is offline
Old 04-30-11, 05:43 PM
xavier853
xavier853's Avatar
Bikes: Pegueot UO8, Tommaso Augusta
Probably, the person installing the lockring and/or cog do not understand that hand tight is not tight enough.
xavier853 is offline
Old 04-30-11, 05:51 PM
yummygooey
i smell bacon
yummygooey's Avatar
Bikes: Geekhouse Deerfield, GT Edge Ti, Spooky Skeletor, TET Track, Ritchey P-650b, Bridgestone MB-3
The current IRO hubs are not the same as Formulas. The older ones are.
yummygooey is offline
Old 04-30-11, 05:54 PM
Leukybear
THE STUFFED
Leukybear's Avatar
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times in 17 Posts
Hmm would anyone know the make of them? I hesitated during my newest wheelbuild and went for the good ol' formulas instead for a bit more.
Leukybear is offline
Old 04-30-11, 06:36 PM
Scrodzilla
Your cog is slipping.
Scrodzilla's Avatar
Quoted: 640 Post(s)
Liked 100 Times in 58 Posts
They look an awful lot like Gran Compes:
Scrodzilla is offline
Old 04-30-11, 06:37 PM
Leukybear
THE STUFFED
Leukybear's Avatar
Quoted: 361 Post(s)
****! If that's indeed the case....
LilTicTac
Singlespeed & Fixed Gear
6
03-14-15 02:38 AM
jnep
17
08-01-14 06:19 PM
sinikl
39
06-01-13 07:22 AM
Into_the_wind
21
08-17-12 01:07 PM
Brian
32
01-26-10 04:58 PM
