Correct distance between top of threaded headset and fork steerer?
Planning a quill setup. Have read about 1inch threaded headsets and their stack height vs fork steerer length minus head tube length.
Q. When the headset top/lock-nut? is screwed down properly, do you ideally want the top edge of the fork to be sitting a mm or so below the headset top face?
Quoted: 4236 Post(s)
Liked 3,963 Times
Not sure of the specifics of the question but if the top nut/lock nut has a lip (and most do) that covers the top edge of the steerer than that steerer has to be at least short enough to clear the underside of that lip. By how much is not the issue as long there's enough thread overlap and the steerer doesn't contact that lip. This usually has a couple/three mm range.
What is meant by "headset top face"? Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 862 Post(s)
Liked 1,105 Times
And if the steerer is a few millimeters too long then add some spacers between the adjuster nut and the lock nut for future proofing for headsets with taller stack heights rather than cut the steerer to fit your current HS.
Liked 3,963 Times
Unless you are dealing with a CK GripNut design which has no allowance for added spacers... Andy
AndrewRStewart
AndrewRStewart
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12970 Post(s)
Liked 7,888 Times
I like about 20mm to an inch of spacers between locknut and cup/cone because I like fairly high bars.
And if you're asking if top of locknut should be above the top of the steerer, yes. Even if the locknut doesn't have an interior flange I'll leave a couple of threads on the locknut unused.
Someday I'll paint this spacer (cut from threadless steel 1-1/8" steerer) and top cup...
Likes For LesterOfPuppets:
Liked 3,963 Times
AndrewRStewart
AndrewRStewart
Quoted: 525 Post(s)
Liked 691 Times
aged to perfection
Quoted: 863 Post(s)
Liked 1,298 Times
I think he means - if the stem is removed, is there a gap between the top of the steerer tube and the inside of the top nut.
you want full engagement on the threads. If the nut and upper cup are tightly locked together and there's no play, look for about a 1 mm gap inside the nut. You do not want the nut bottomed out on the steerer.
/markp
/markp
Likes For mpetry912:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3936 Post(s)
Liked 6,618 Times
Liked 3,963 Times
Because life is not perfect and the spacers needed to get 2mm VS 1mm of gap might not be at hand. Since both achieve the same mechanical result...Andy
AndrewRStewart
AndrewRStewart
