Replacement Chainring BCD
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
I am looking to replace the 1x ring on my fatbike, but I am confused by the BCD dimensions - the distances between the bolts are approximately 48mm, 53mm, and 63mm.
Is this a standard BCD for which I can easily find a replacement? I believe it is the original Comox crankset that came on my Norco.
I see most manufacturers have gone to direct mount chainrings, but I was hoping I wouldn't have to replace the whole crankset.
Thanks in Advance
Thanks in Advance
Quoted: 114 Post(s)
Liked 119 Times
This link has a great discussion on BCD.. The BCD is not the distance between two adjacent bolts, but rather the measurement of a circle that goes thru the center of each hole. But knowing the distance between bolts can determine the BCD.
https://www.sheldonbrown.com/gloss_bo-z.html#bcd
Quoted: 2026 Post(s)
Liked 1,096 Times
Also, "BCD" implies the bolts are equal distance apart and their location around the circle is symmetrical. Many modern cranks use a proprietary asymmetric bolt design so the old 5-bolt or 4-bolt chainring designs won't work. You may be stuck using a replacement chainring from the OEM crank supplier.
aged to perfection
Quoted: 852 Post(s)
Liked 1,282 Times
that's a great link to Sheldon's article, thanks for that !
/markp
/markp
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3922 Post(s)
Liked 6,560 Times
It's better to avoid inclusion of any pics, so the threads last longer with more unnecessary posts with irrelevant questions. So few people have cameras these days as well.
Likes For SurferRosa:
Method to My Madness
Quoted: 2046 Post(s)
Liked 1,541 Times
Come on, we all enjoy a full on differential diagnosis exercise harnessing our collective experience and wisdom.
Likes For SoSmellyAir:
Quoted: 550 Post(s)
Liked 484 Times
http(colon)(slash)(slash)pardo(dot)net/bike/pic/mobi/d.shimano-biopace-bolt-pattern/index(dot)html
I've had difficulties with the secure version of the link using Firefox (old TLS version on server), but the nonsecure version of the link works if your browser is set to allow nonsecure connections. Replace the terms in parenthesis in what I posted with what's in parenthesis and it should work.
This above link is from the Bicycle Museum of Bad Ideas page on the same site. The rest of the page is also a pretty good read.
http(colon)(slash)(slash)pardo(dot)net/bike/pic/mobi/index(dot)html
Quoted: 550 Post(s)
Liked 484 Times
I'm not sure why you didn't just post this for a link to that page. . . . .
In such a case, you have to load the web page using nonsecure http (no letter "s") - if the web server server hosting the page supports nonsecure connections. You may also have to change your default browser settings to allow nonsecure connections. Some recent browser versions have a default setting of "secure connections only".
The Bicycle MoBI page may be where I first ran into this issue. And yes, it's a fascinating look at "oopsies" from cycling's past.
Possibly - but Shimano didn't do that with their other Biopace chainrings, which use standard 110mm and 130mm BCDs. Can't see why they'd single this one out for a nonstandard BCD among all their Biopace chainrings, but maybe that was the reason.
Last edited by Hondo6; 05-16-23 at 01:02 PM. Reason: Omit extra and unnecessary word.
Quoted: 550 Post(s)
Liked 484 Times
