Maintenance - aluminium v carbon
Just bought my first full carbon bike. I do most of the general maintenance on my aluminium frame/forks/wheels bike so just wondering if there is any difference, good practice, do’s /don’t for the carbon bike. Thanks
Quoted: 18427 Post(s)
Liked 4,544 Times
I wouldn't think a lot would be different. However, be careful with over tightening fasteners on the carbon bike. Possibly use a torque wrench if in doubt.
Carbon and Aluminum will mix some, but I'd avoid an aluminum seat post or stem.
Quoted: 4233 Post(s)
Liked 3,941 Times
Agreed that the basics are pretty much the same with the torque control being the big concern. I suggest either assembly paste or anti seize for the fixed but removeable bits like stems and posts.
What some don't know is that carbon will react with metals and seized stems, posts and corrosion can still happen. Just like other bikes this corrosion is generally in the hidden places that are not viewable with out some disassembly. If the bike sees much water (humidity, rain, washings) I suggest pulling the parts out of the carbon frame at least annually, more often if the conditions are worse or the rider is a high mileage one. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Method to My Madness
Quoted: 2046 Post(s)
Liked 1,542 Times
Likes For SoSmellyAir:
Liked 4,544 Times
For an external stem as most CF bikes have, it may not be too bad.
I have one CF frame that I still have to dig the seatpost out of. I got it with the seatpost cut short. 3 layers. CF frame, aluminum spacer, and CF seatpost. All stuck together tight. It isn't something that looks pretty.
At least if your aluminum stem reacts with a CF steer tube, it should be easy enough to cut it off, or pry the clamp open.
Quoted: 1616 Post(s)
Liked 1,806 Times
In any event seatpost shims suck and are to be avoided.
Liked 1,542 Times
Liked 1,806 Times
Liked 1,542 Times
Yes, but they may be different grades of aluminum. The steerer is unknown (because the frame is old), the shim is 6061, and the stem is also 6061, but I may have to get a different stem if it does not put the handlebar at the right position.
Quoted: 1110 Post(s)
Liked 1,048 Times
Any form of anodizing, and the thicker the better, will greatly reduce/prevent corrosion between carbon and aluminum. I suspect that more modern materials have also helped to mitigate this since I've dealt with plenty of carbon posts sitting in aluminum frames and have witnessed virtually none of the corrosion that was evident in the early carbon/aluminum bikes of the early 90s.
As to how to treat the bike, just the same but use that torque wrench.
Likes For Russ Roth:
Quoted: 4560 Post(s)
Liked 1,698 Times
Posts get stuck because they weren't lubed correctly in the first place and weren't removed now and then to replace it. The best lube when carbon is being clamped on or in is carbon paste, which has little beads of plastic that add traction and help isolate the two parts.
Likes For Kontact:
Liked 3,941 Times
Early on in the carbon age many were concerned about resin breakdown from chemicals. This is pretty much a non issue though as the vast majority of consumer available solvents and lubes won't attack the cured resin or the base fiber. This is what Craig Calfee stated in his presentation at a NHABS years ago and mimics my far less experience too. Before we became aware of assembly paste the standard shop bench grease (Park, or other) was used with no problems for many years. But grease does have a limited ability and life. Reread Kontact's post about periodic refreshing of this stuff. Andy
AndrewRStewart
AndrewRStewart
Quoted: 4859 Post(s)
Liked 4,005 Times
I'd have to look but it wouldn't surprise me if different aluminum alloys were located in different places along the galvanic scale. That is very much the case with stainless steels. The two common types are located far apart. One does just fine in marine use around aluminum and the other forms basically a battery.
Liked 1,542 Times
Maybe "grades" was not the best word. Different aluminum alloys (e.g., 6061 vs 7075) may have different galvanic resistance, although (like Russ Roth said) anodization pretty much makes that a non-issue. But in my example, the steerer is not anodized.
Liked 1,698 Times
Quoted: 1139 Post(s)
Liked 1,241 Times
Fixed it. I don't think very many people have full CF stems on CF steer tubes. Some, yes, but a small portion. I've never had a full CF stem in our garage among the various CF forks. CF seat posts are much more common, but again, certainly not essential.
Liked 1,241 Times
Generally bewildered
Quoted: 1152 Post(s)
Liked 342 Times
In some cases I've seen people suggest bearing retaining compound. I don't think I'd use this in a CF frame, unless the frame mfr or bearing provider suggests this. For most bearing installations in metal frames I think grease is recommended between the bearing seat and the OD of the bearing, and between the spindle and the ID of the bearing.
