Argon Krypton vs. Specialized Roubaix
At pretty much the same price point between the two:
Argon 18 Krypton GF
Specialized Roubaix Expert
I'm looking for comments about their unique value over the other. Other than their differences in electronic groupsets and the associated gear ratios, any major differences that stand out to you? Which one is a better value?
Sorry, the system doesn't allow me to post URLs here until I post more often here.
Argon 18 Krypton GF
Quoted: 608 Post(s)
Liked 352 Times
Well the Specialized has the Future Shock which is a major difference.
The bike that you feels the best to you should be the criteria, this notion of value seems off to me.
They are both great bikes, one from a Canadian company, the other from an American company. You can't go wrong with either.
Liked 2,971 Times
Argon if it were my money.
-Oh Hey!
-Oh Hey!
Likes For Troul:
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
The Future Shock is a unique feature and it does make things more comfy on long rides with less than perfect pavement. Also you get a Specialized saddle and they are the gold standard today. I've never heard of Argon so you get bonus points for originality there.
Quoted: 643 Post(s)
Liked 1,526 Times
If you ride a lot of crappy pavement, I'd go with the Roubaix for the future shock assuming it fits you well. It does make a big difference on long rides. If you're riding on good roads, and they both are good fits, go with whatever is more appealing.
Likes For joeruge:
Liked 2,971 Times
Quoted: 4407 Post(s)
Liked 4,860 Times
These 2 bikes are high up on my shortlist too. I'm leaning toward the Roubaix mainly for its unique front suspension. But our local roads are pretty crappy. I haven't had chance to ride either of them yet.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,469 Times
I was considering an Argon 18 Krypton GF too but its only seems to be available (if at all) with a SRAM groupset now.
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times
I think Roubaix is BSA bottom bracket versus BB86 on the Argon, which is a big deal for many. I recommend taking a close look at the stack and reach numbers, as Roubaix has typically been outside the average endurance geometry (more stack / less reach).
From the charts, Roubaix 58 stack is 644 while Argon offers "3D+" that they claim allows variation of 601-625, still quite a bit off from Roubaix.
If you do go the SRAM AXS route, I see Argon is using the DUB crank. Everything I've seen suggests even with DUB the bearings are kind of marginal for BB86 and traditional GXP might be better (though I know many folks dislike GXP design).
scott s.
scott s.
Bikes: Focus Arriba, Specialized Roubaix Expert, Bianchi Impulso Allroad
Quoted: 109 Post(s)
Liked 82 Times
scott s.
scott s.
According to specialized.com the current Roubaix Expert in 58cm has a Stack of 630mm and a Reach of 392mm.
Roubaix Expert | Specialized.com
My 2019 Expert Di2 - last of the previous-gen frames, with Future Shock 1.0, was fitted with Roval C38 wheels, a decent upgrade from the alloy DT Swiss wheelset fitted to the current Expert.
Looks like the Roubaix Pro is fitted with the Roval Alpinist carbon wheelset... excellent lightweight hoops, but also $7500 and equipped with SRAM Force e-TAP
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
In actual practice the spindles are stiff(er than M30, BB30, and Shimano...can't compare to GXP). No idea on longevity, one of mine has 7000km (mostly decent weather) on it, and the other has 2500km (mostly gravel and foul weather). But they spin nice.
Quoted: 6193 Post(s)
Liked 4,809 Times
I'd think the Krypton GS compares more with the Specialized Tarmac than the Roubaix. At least going by frame stack. You can get a lower more aero position on the Krypton than the Roubaix.
Quoted: 109 Post(s)
Liked 82 Times
You'd think wrong. The Krypton GF is the direct competitor to the Roubaix, with room for up to 34mm tires not able to fit on the Tarmac. And the Tarmac SL7 in 58cm shows a stack height of only 581mm -- lower than the Krypton and zero adjustment as with Argon18's 3D+ system.
Liked 4,809 Times
The other things you mentioned are good points the OP needs to consider, however the range of stack heights is probably one of the most important things to weed out a bike model first. Otherwise if they are wanting a more upright position and purchase a Krypton or even a Tarmac, then they'll be putting kooky looking extensions on their steerer tube along with weirdly angled stems. And be posting in the fit sub-forum asking how to make their bad choice of bike models fit better.
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
Argon 18 Krypton GF
I'm looking for comments about their unique value over the other. Other than their differences in electronic groupsets and the associated gear ratios, any major differences that stand out to you? Which one is a better value? Sorry, the system doesn't allow me to post URLs here until I post more often here.
Argon 18 Krypton GF
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,035 Times
I've got over 14,000 miles on my 2020 Roubaix Expert. I own another bike with the FutureShock 2. My back and neck are a little sensitive to getting bounced around. Even on decent roads, for rides over 30 miles or so, I can tell a marked difference when I have the FS set to soft, and when I have it locked out. I really like the Roval C38 wheels on the Roubaix, too. I haven't even had to true them in those 14,000 miles.
I'd looked at the Argon 18, but could only find it online at the time. Seems like a nice bike. If you don't think you would benefit from the FutureShock, I can't imagine you wouldn't be happy with the Argon 18.
Likes For MattTheHat:
Liked 4,860 Times
Likes For PeteHski:
