Addiction 2022.1
#2176
VFL For Life
Bikes: Velo Volmobile
Quoted: 28617 Post(s)
Liked 1,857 Times
#2177
Quoted: 8281 Post(s)
Liked 9,050 Times
#2178
VFL For Life
Liked 1,857 Times
#2179
Klaatu..Verata..Necktie?
Quoted: 10432 Post(s)
Liked 11,909 Times
I've been doing really well on Ebay, picking up bits for the Litespeed Interim Build #2. Today, the 7410 chanrings listed as "low mileage" arrived and yes they absolutely ARE low mileage! The teeth are still shiny. And the FD that I was afraid was scratched up, but it was the cheapest complete example on Ebay - the pictures made it look FAR worse than it really is. I'm getting really stoked! Just cable stops, cables, and the extra crank bolt (7410 cranks apparently came with Titanium crank arm fixing bolts. Who knew?)
I contacted my LBS, and he'll be happy to swap the BBs "while you wait", so the stars are all aligning.....
Likes For genejockey:
#2180
Habitual User
Quoted: 4949 Post(s)
Liked 8,095 Times
#2181
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3194 Post(s)
Liked 1,844 Times
#2182
Quoted: 9653 Post(s)
Liked 6,365 Times
Likes For Mojo31:
#2183
Liked 1,844 Times
#2184
Liked 1,844 Times
#2185
Silver Comet Fred
Bikes: 1
Quoted: 8839 Post(s)
Liked 2,987 Times
DougRNS is your snow shovel ready for emergency deployment?
https://twitter.com/BradNitzWSB/stat...97573074714631
#2186
VFL For Life
Liked 1,857 Times
#2188
Silver Comet Fred
Bikes: 1
Liked 2,987 Times
I have nothing substantive to add in any language.
#2189
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,926 Times
Likes For datlas:
#2190
Liked 8,926 Times
#2191
Quoted: 18419 Post(s)
Liked 15,560 Times
Windchill=0 in the big city.
#2192
Liked 8,926 Times
#2193
Quoted: 10237 Post(s)
Liked 5,184 Times
When I took it apart the top bearing had marks on the outside of the bearing case on one side. This, I believe is why it always seems to have play. Postive it has been this way since I bought the bike.
The play isn’t crazy. If I hold the front brake and rock the bike there’s a clicking/ popping noise coming from the head set. Not sure if new bearings would fix the problem, or if there is something wrong with the head tube.
#2194
Liked 5,184 Times
#2195
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
do not recommend
#2196
Liked 5,184 Times
Last year when I first got the revolt I went out for a ride where the wind chill was like 10. I was fine until about the last 10 miles of a 45 mile ride. Water froze, feet were numb and really struggled. Ended up being really dehydrated and had to go to the emergent care to get an IV- I couldn’t keep anything down.
do not recommend
do not recommend
damn.
My winter rides I don’t typically hydrate much. Kind of hard to drink through a face mask, when it’s super cold I don’t want to pull it down for it will be that much colder when I put it back on.
You have a valid excuse.
#2197
VFL For Life
Liked 1,857 Times
#2198
Liked 9,050 Times
When I've seen the bearings go bad the steering feels rough, like it's "indexing" when you turn the bar.
I had a problem where the headset adjustment loosened up a bit after long rides. Turned out the expander was loose inside the steer tube.
#2199
Mostly Harmless
Bikes: Have two wheels
Quoted: 13714 Post(s)
Liked 4,530 Times
Nine below F this morning. But the sun is out so, naturally, Benson wanted an extended walk.
#2200
Liked 5,184 Times
Does the clunking and play go away when you tighten the headset? If you can't adjust out the play something is wrong and I would take the fork out and check it over. I've heard some bikes come with crappy bearings.
tightening does not make the clunking go away. I’ll take another look at it when I get home. I might have to just take it to the shop. I’ve never had that bike do a complete tear down.
