First time restoration - Sticky brake hoods.
Howdy all,
First time posting on here so applogies if this is the wrong forum for this topic.
I purchased a bike on a whim as i thought it would be great idea to learn about bike maintence by restoring a neglected old bike.
My first question, which may be the first of many, is about the break handle hoods. The old hoods have to go so I bought a new set of handles and hoods from ebay. However, there is a not nice feeling of stickyness. Is this a feature of old rubber or is there a way to get the hoods feeling nice again?
Thanks for any suggestions.....
Quoted: 3511 Post(s)
Liked 2,926 Times
Great question! I don't know the answer, but look forward to the responses. I wonder if something like ArmorAll might help?
Edumacator
Quoted: 2439 Post(s)
Liked 3,128 Times
Magic eraser, Dawn, water then I’ve been told, baby powder, but I’d imagine that would cause grime build up.
Likes For jdawginsc:
Quoted: 4512 Post(s)
Liked 6,382 Times
Not much to lose, sticky, icky or experiment and find a fix. Advise to proceed with caution as it can be made worse and or rip, tear, melt, etc.
Quoted: 1872 Post(s)
Liked 692 Times
I've only only ever succeeded in making sticky hoods worse. More often than not they just start to melt.
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 1591 Post(s)
Liked 1,018 Times
If they're new they certainly shouldn't be sticky.
I've made mine sticky cleaning them with the wrong cleaner. Repeated applications of baby powder before every ride eventually got them back to relatively normal.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,485 Times
Soak in soapy water for 2-3 minutes on stove (not boiling!).
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
clean them (warm water and dish detergent, sure),
DRY them,
apply glycerin and knead it in with your fingers.
lightly dust with favorite baby powder or talc (but not that stuff with asbestos...right?)
you might need to repeat the baby powder a couple times as it wears off.
DRY them,
Quoted: 211 Post(s)
Liked 199 Times
Send them back !!!
Should not be sticky at all.
If you cannot send back, then try above suggestions.
When I have cleaned "dirty" hoods....................all suggestions have failed
Good Luck
Good Luck
Quoted: 1372 Post(s)
Liked 1,751 Times
I have run into this a few times. Not sure if my advice is good in all cases I clean them with Dawn dish soap, dry them with a towel and thenI just use them. The feel does get better in a short while (a few rides) and my guess is that the natural oils from your hands does the trick. That said, I usually (actually always) ride with my fingerless gloves but the stickiness does go away, sooner or later. The baby powder or corn starch does a quick repair also.
Likes For randyjawa:
Quoted: 1639 Post(s)
Liked 829 Times
I think once it goes sticky, it will be impossible to restore the hoods as they had already broken down organically....on their way to becoming bacon.....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Thanks everyone for your suggestions.
Really nice to know there is a such an active community on here.
I tried some water and soap but I was cautious due to not wanting to make the problem worse. It seemed to help a little but not much. They were second hand vintage break levers with hoods, so i think it might be just old rubber causing the problem. I guess the whole idea of this project was to learn a few things along the way. Maybe they will recondition as I start to use them....
Thanks again everyone!
Groupetto Dragon-Ass
Quoted: 414 Post(s)
Liked 785 Times
If you search the forum, you'll find several threads on which modern brake hoods fit which vintage levers.
My own solution to clean but sticky hoods is to lightly mist them with a couple coats of clear spray paint.
Mist, not paint.
Works with many plastic-rubbery items
Mist, not paint.
Clean with Isopropyl alcohol and then apply baby powder.
When cleaning, wipe in one direction. Avoid wiping back and forth or in circles. This will only smear the grime. Wipe the junk to the edge of the hood, then wipe away.
If after a ride, either from rain or excessive sweat, the hoods start to become sticky again, just apply a little more baby powder.
Try this before buying new hoods for your vintage bike.
Before
After
Before
After
Bikes: Bicycles? Yup.
Quoted: 481 Post(s)
Liked 1,585 Times
One man's gooey is another man's sticky.
Gooey hoods cannot be redeemed and replacement is about it. Ultegra 6500, I'm talking about you.
Quoted: 1609 Post(s)
Liked 2,590 Times
The white hoods are the worst. I use mr clean eraser pad and follow with the baby powder.
