Sram Spectro S7 2003 shifting issues
Commuting Fool
Bikes: 1988 Miele Azsora, 2022 State All-Road 4130, 2003 Jamis Coda Comp, 1983 Specialized Expedition, 1994 Norco Monterey
Quoted: 104 Post(s)
Liked 72 Times
Anyone have experience with this hub that could help me? Manual says 2005, but drum plate is stamped 2003. Don’t know which year it’s from or if it matters.
Im having difficulty with the clickbox shifting. I rebuilt the hub over the summer and I think the overhaul went fine. Everything is really smooth and the rod pushes in no problem, springs back well. Im at a complete loss as to what might be happening. I install the clickbox with the grip shifter in first gear, I can shift to 2, but I can’t tell if it is shifting or not. When I try to shift to third it is very difficult to do, to the point that I don’t want to force it for fear of breaking it.
The clickbox will shift through the gears if it isn’t installed on to the hub, but as soon as it’s on the hub axle, it has issues.
Really could use some help everyone.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
There should be a spring loaded rod and an outer sleeve protruding from the axle with the clickbox removed. The fingers in the clickbox engage with the rod and sleeve and push on them to select the various gears.
You should be able to push the rod and sleeve both back into the axle without too much resistance and they should spring back. If you find you can not then something is wrong inside.
It is also important that the notch in the sleeve is correctly oriented so the fingers in the clickbox can properly engage. That is the job of the red plastic clip that fits over the axle.
If that clip is missing it will not work correctly.
Likes For Dan Burkhart:
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Thanks for the reply. The rod pushes in and springs back very freely. I had the hub completely disassembled and nothing inside seemed broken or worn that much at all. I followed the manual instructions when assembling the rod, tube and red clip. It sounds like everything you mentioned is in good order. Some of what you mentioned does help to understand it better though. Thank you
I know nothing about IGH, but this was one hell of a learning experience, going back 5 or 6 months… what a journey.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
It is shifting now through the gears, but something is clearly not right. I’m getting a tha-thup, tha-thup sound in 5th gear and it seems to continue freewheeling in 6 and 7. What a disappointment. Does anyone know why this might be happening?
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Well, I test rode it just now. This is what it’s doing.
1st and 2nd gear work as they should
3rd gear doesn’t work at all, just spinning with no gear engaged
4th gear works, but makes freewheeling sound while pedaling
5th gear works, but makes the “tha-thump” “tha-thump” noise
6th and 7th gear work, but make freewheeling sounds while pedaling
Seems really bad. So sad 😩
Senior member
Quoted: 943 Post(s)
Liked 658 Times
You said you rebuilt the hub. If you removed the planetary carrier it is vitally important to Time the planetary gears on assembly. Failure to do so can result in broken sun gears. That would cause all kinds of issues.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
I understand how important the planetary gears are. When I reassembled it, it seemed as though I had it lined up right, but it isn’t necessarily an easy thing to do without the guide and at the time I had no idea where to find it. It’s quite possible that is the issue, but given the fact that the hub has a poor history as well, no anti-rotation washers used for who knows how long, what riding conditions it was used under… it’s just too hard to tell definitively at the moment.
I suppose I have nothing to lose by opening the hub back up to see what might be going on. Anyone know where to find the guide they mention in the manual for aligning the planetary gears? Of course, with the video Dan has shared I have more confidence aligning them if i were to do so again anyway.
In my experience, Sram has pretty good customer service. I reached out to them and I’m waiting to see what they might have to say.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
SRAM North American support for gear hubs was pretty much non existent even during production let alone now that these hubs have been orphaned.
I wish you luck but I would not expect much help from SRAM
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
That’s not great news. I guess I’ll do my very best to see what might be happening. Thanks for your help Dan.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
With regard to timing the planetaries, I made this video ten years ago showing my technique without the guide tool.
https://www.youtube.com/watch?v=p9A8XWPzwVg
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Here is an image of the planetary gear alignment when I took a look inside. They appear aligned well to me, maybe I’m missing it somehow, but they look okay to me.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
The one guy at Sram that might lend you an ear is Ed Nasjleti . That is if he still works there, I don't know. It was many years ago when I dealt with him.
He was always frustrated with Sram's reluctance to support these hubs.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
If the planetary carrier spins freely on the sun gears without binding, the timing is correct.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
One thing I’ve noticed since inspecting the pawls is how one pawl springs back while the other one doesn’t very much. In these images you can maybe see some damage to the area where one of the pawls sits. When I initially took this apart that was one of the obvious problems with the hub, the one pawl didn’t spring back at all. I cleaned it up and added fresh oil, I thought it was back to working right, but now I don’t think it is. What kind of issues would one pawl sticking and not springing back cause?
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Well..🙄… after messing around with the pawls for a bit and the retaining ring it would seem that the pawls are hardly moving at all now and when installed in the hub shell nothing is engaging. It would make sense that 3rd might not be engaging if the pawl is unable to spring back into position properly. The question is why? What could cause this pawl to hang up like this? Did I misshapen the retaining ring? Is there damage to the body of the hub where the pawl sits? Is a pawl damaged?
I don’t think the pawls are damaged, they appear fine. The groove they sit in is a bit inconsistent on one side and it’s clear that one side isn’t springing back like the other, however, after messing with it some, neither side is springing back well. It leads me to believe the retaining ring might not be as round or robust as it once was from me removing it too much.
One thing is for certain… this is definitely one of the causes of the issues I’m encountering.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
The high speed pawls (which is another name for the pawls on the ring gear) only engage the ratchets in gears 4 thru 7. For gears 1 thru 3, the ring gear is shifted endways and the pawls are taken out of engagement with the ratchets.
This differs from the Sturmey Archer design that has tails on the ring gear pawls that are retracted from behind by the clutch.
When the pawls are disengaged from the ratchets, they run on a delrin ring inside the hub shell. Some models did not have the ring but I think most do.
The pawl spring needs to be fairly strong. I would check the sockets where the pawls seat for debris or burrs and also for any irregularities on the seat portion of the pawls and polish them up a bit.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Here’s a video I made of the issues while the hub is in 3rd and 5th. Not engaging in 3rd and noise in 5th. I ran through all 7 gears.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
The pawls and the sockets they sit in are pitted and worn irregularly. I tried to sand them back with some lighter paper and polish them with compound, they are better but still rough enough to catch when you drag your nail across. They were springing back a little better, but still not the greatest.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
https://www.youtube.com/watch?v=1rnAY7AtTUY&t=2s
3rd and 5th gear both drive off the same sun gear, that being the smallest one. It is possible, or even likely that the engagement key is not properly coupling the small sun gear to the axle.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
It has not been brought up yet, but I am assuming since you referenced the manual that the clickbox is properly adjusted to the alignment marks in 4th gear?
Senior member
Quoted: 943 Post(s)
Liked 658 Times
I did line up the line with it in 4th gear. That’s a good thought Dan and something I will double check. Thanks for all of your help. Very few resources for information regarding this hub. I’m emailing Aaron at Rat City Bikes in Seattle, WA as well. Still haven’t heard from Sram, quite possibly won’t, it was worth a shot I guess.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
I’m not exactly eager to completely disassemble the hub again. I had help the first time and a bench vise, but I don’t have that this time. It was quite the chore and some of it required quite a bit of force. I live in a small apartment and don’t have a bench vise or work bench at the moment, although I may run out and get one soon. Pretty obvious it should come apart again.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
