What is SRAM Eagle?
Habitual User
Quoted: 4954 Post(s)
Liked 8,095 Times
what i find somewhat confusing about the SRAM approach is that "eagle" refers to a huge range of MTB components, unlike, say, "dura-ace" or "XTR" in the shimano world, which specifies both a type (road, mtb) and a level.
so in SRAM MTB land, there are several levels chosen from the tiers that go with eagle, NX eagle, GX eagle, X01 eagle, and XX1 eagle. pretty big differences from NX to GX (e.g. different driver and so on) and then more differences as you work the way up, but they're all 12 speed mountain bike drivetrains.
Likes For Eric F:
Quoted: 768 Post(s)
Liked 1,742 Times
Also, I believe anything Eagle AXS is electronic shifting. So anything with that labeling can be mixed in. Similar to the Road eTap AXS, all of their AXS stuff is compatible, so you can have a Red shifter and Rival derailleurs and brakes and Force cassettes.
Edit: Added AXS...
Edit: Added AXS...
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Habitual User
Liked 8,095 Times
Eagle does not equal electronic. AXS is SRAM’s designation for their electronic shifting.
Likes For Eric F:
Quoted: 768 Post(s)
Liked 1,742 Times
Oops, yep, sorry, meant to add in the AXS part and failed to do that.
Homey
Quoted: 2427 Post(s)
Liked 1,407 Times
You kidding? The first post is entirely hostile and unnecessary.
This forum is not really moderated, and there seems to be a contingent of bad actors who think they are freelance moderators - steering topics around to their biases by making discussion intolerable. And then everyone else reacts to the person who got targeted for being put out about it. The OP should be put out. You should be put out. Koyote's post shouldn't be tolerated by people who want a discussion board to be about discussion, not aggression.
You know what works really well to limit seemingly valueless posts? You ignore them. Someone asks a dumb question, leave the thread alone and it will disappear off the bottom of the page in a day.
So instead of potentially interesting discussion about what is and isn't Eagle and its features, we have the script from Mean Girls. Because a couple of not nice people think the topic is beneath them.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
A conversation on SRAM Eagle could be interesting, as a Shimano person myself who has coming increasingly in contact with SRAM because a lot of companies have switched due to pandemic related shortages it is growing a little on me. I mean I wouldn't run DOT brakes on my bikes but their new brakes are actually pretty decent especially considering how bad their old stuff was.
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,439 Times
Sometimes, if you don't already know the answer, formulating a question becomes a challenge. Add to that a (possible -- I don't actually know) non-native speaker of the language, a different culture, etc., and there emerges a compelling case for cutting the questioner a wee bit of slack.
Tolerance can only help.
Quoted: 1279 Post(s)
Liked 1,393 Times
add in AXS vs not, and it’s moderately confusing. probably no worse than shimano’s gravel groups which abandon the named tiers for numbers …
Likes For mschwett:
Liked 1,393 Times
Quoted: 4408 Post(s)
Liked 1,562 Times
I was observing the level of moderation, not complaining about it. And I'm sharing my respect for the OP by pointing out the pattern of bad behavior that persists across many threads and calling for it to end.
Likes For Kontact:
Habitual User
Liked 8,095 Times
…was a harsh response.
However, he’s right. Doing a simple G search of “SRAM Eagle” got me multiple links that described exactly what it is - in simple terms - that you could have found in less time than it took you to write your post.
That said, the Big S companies seem to be determined to making things kind of confusing with group designation, so having questions is understandable.
Quoted: 1088 Post(s)
Liked 1,025 Times
I could easily see that from the SRAM Eagle webpage, and yet sjanzeir is upset that people suggested that he review that info.
OP, I've generally found the whole Eagle aspect to be annoying, as others pointed out, eagle designates 12sp but the different levels all have different quality points, the sx, nx stuff will be low level items designed to meet price points predominantly for oem bike builds. The real advantage to the two lines, that I understand, is that the cassettes are compatible with older HG cassette hubs unlike the higher levels which require a 12sp XD hub. From there you'll probably need to find online articles about the more specific differences between the quality of the shifters and derailleurs which will come down to which use bushings vs bearings, carbon vs aluminum or plastic, and just how few grams difference there will be between the various levels of chains.
I will say if you switch to one of their groups I've been using JFOYH 12 speed cassettes from Amazon. I needed to do it for Jr. gearing restrictions on their road bikes where going with shimano or sram 12 speed would have meant ridiculously heavy cassettes or stupid gearing due to the brands using 10t cogs for whatever reason. The shifting on the cassettes has been flawless for Sram AXS to shift across and the low cost for the weight is nice.
Likes For Russ Roth:
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
Quoted: 4413 Post(s)
Liked 4,865 Times
Regarding brakes, I also prefer mineral oil in case of leakage, but using DOT has never been an issue in practice. Higher-end SRAM mtb brakes have been fine for me since 2015.
Likes For PeteHski:
Liked 4,865 Times
Eagle = 12 speed mtb
AXS = electronic shift
XX1, X01, GX, NX, SX = descending group tiers/price
NX and above have been good for me. SX looks fragile (lots of structural plastic), I don't think XX1 is worth the cost over X01. GX is probably the best value for money in their range. X01 is really nice.
Quoted: 7652 Post(s)
Liked 3,478 Times
When I actually googled SRAM Eagle to see how confusing it all was .... I got this:
So not only was there SRAM's corporate hype, there were several specific questions, and an independent review. No one who made much effort would be confused.
Pete Hski replied, "Eagle is just a collective name for all SRAM 12 speed mtb groupsets. It gives a very wide range across 12 cassette gears." and that was enough to satisfy the OP. Seems that all that info was available on the search page ....
Me, I do so basic research and then ask specific questions if I need more explanation. But that's just me.
Hopefully, in future the poster will ask more specific questions so that people can better answer his questions.
I do notice that after one response suggesting googling it, the poster started slinging curses around.
Maybe a better second post would have been, "Thanks, I went to the SRAM site but didn't understand these specific points .... " but again, what do I know? Just because those approaches work for me, no reason to think they work generally.
Quoted: 6971 Post(s)
Liked 10,968 Times
The opening post reads as if sjanzeir hadn't done even minimal research, as it didn't include any specific questions. But rather than responding as I did, I could've (and should've) simply suggested that he ask actual questions. I apologize for the rudeness.
Quoted: 792 Post(s)
Liked 1,494 Times
Not that I owe anybody an explanation, but I'll go ahead and say that prior to making that fateful original post, I had read through a lot of content to try and understand what it is exactly that sets Eagle apart from other, non-Eagle stuff, but as anyone who read any news/first impressions/review-type article in any online trade outlet ever knows, you know how these things tend to be written - and none of them would give you nuggets of the "Eagle is anything 12-speed" kind. So, when I found myself spending too much time clicking through Google search results, I thought - obviously wrongly - that I might turn to the forum for some distilled clarification. Instead - and, given past experiences on this forum, not surprisingly - I got the kind of vermin that almost makes me swear off the sport/hobby for good.
Likes For sjanzeir:
Clark W. Griswold
Liked 3,994 Times
Wow, I don't put people on ignore, and in this instance you doing it is pretty comical, I have a feeling that short list is really long. I tried to help you out and help you get to your question but it seems like maybe there wasn't a purpose for all of this. I don't know, but you do you.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Agreed.
Agreed.
Agreed.
Clark W. Griswold
Liked 3,994 Times
Quoted: 1461 Post(s)
Liked 1,486 Times
I guess I just turned it into a one-liner
It doesn't help that they further differentiate with meaningless and generic alpha-numeric codes. Your average consumer is never going to remember that XX1 is different than X01, much less remember which one is "better" than the other. They should've gone with Eagle Talon, Eagle Eye, Eagle Feather, etc.
Administrator
Quoted: 11971 Post(s)
Liked 6,652 Times
A little less snark and a little compassion would go a long way around here. I think the OP did a good job standing up for himself. The ignore list works well, but I wish you guys would be kinder, gentler in general.
Regarding the moderation remarks, there's a pretty widespread belief that moderators monitor threads from start to finish in realtime, and that when hostilities erupt we're available to respond promptly. This clearly demonstrates the issue hasn't been given a lot of thought. One needs only to check out the New Posts feature occasionally to realize how many users and how many threads are active throughout these forums at the same time. There's no way these can all be monitored in realtime. We rely primarily on users to report behavior violations, and when we're not tied up at work, or with the family, or out riding our bikes, we will make some time to respond to reports. Considering how few volunteer, unpaid moderators we have here the system works pretty well, because we can truly hammer bad actors when need be. But we need the reports. They're never shared in public. If you feel wronged, report it and we'll respond in due time. Cut us some slack, we're trying to enjoy life a little too.
Now where's my coffee?
Liked 4,865 Times
It's worth noting that SRAM's naming conventions for their MTB groupsets are a little confusing, especially if you're used to the old Shimano names where each tier of groupset has it's own name. People hear "SRAM Eagle" and assume that it is a stand-alone tier of groupset that somehow slots in with other SRAM MTB stuff.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
The fact that a stick destroyed the drivetrain has nothing to do with the brand. I've destroyed my Shimano XT derailleur on my mountain bike twice with a stick now. So your post about the SRAM system being garbage is not even close to being factual. It can and has happened with every brand.
Last edited by mstateglfr; 01-23-23 at 11:14 AM. Reason: my awesome comment makes no sense without context
