What's the best freewheel?
Rhythm is rhythm
My 1986 Shimano 600 rear hub needs a new freewheel. What should I look for? It has 6 speeds right now, should I go up to 7, or would that mean getting a new chain? Should I replace the chain anyway, seeing how the chainrings are also new for the bike? I know IRD makes a nice freewheel, any other brands I should look into? Thanks
Wookie Jesus inspires me.
If you can find an old Sachs freewheel, those are really nice.
Are you looking to go indexed?
Even the cheap shimano or sunrace ones work really well.
If it were me, I'd probably replace the chain since you are replacing the rings and freewheel.
Quoted: 1607 Post(s)
Liked 2,216 Times
I did the 6-7 upgrade with IRD and am very happy. I also upgraded the chain to a SRAM 870. The newer FW are a good upgrade in shift quality.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Mechanically speaking, Shimano 600 and Dura-Ace freewheels are as good as they get. SunTour Winner/New Winner are a close second. IMHO, Zeus freewheels have the best design, but are pretty scarce these days. Sachs and IRD are more modern freewheels with decent reputations.
Knows Bigfoot's Momma
Bikes: yeah; got a couple...
They're really light (thinking the 2000 freewheels), and cool 'cause they're ZEUS (I really like the 2000 stuff)... But aren't they a little soft, and quick wearing..?
nice lugs baby!
nice lugs baby!
White industries in California makes the Best Freewheels , but only in 1 or 2 speed..
older stuff..
Light alloys, aluminum , Campag, and the Titanium, Zeus are
by the nature of the metals used, softer.
older stuff..
Bikes: Cinelli, Paramount, Raleigh, Carlton, Zeus, Gemniani, Frejus, Legnano, Pinarello, Falcon
Quoted: 12 Post(s)
Liked 8 Times
Itch, I don't know. I can tell you I've never successfully removed a Regina from a hub, but never had any problem with a Suntour.
Rhythm is rhythm
It sounds like most of you recommend a used freewheel over a modern remake? Even though it doesn't have shifting ramps?
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Old Shimano HG freewheels have shaped teeth and shift very nice. I prefer Shimano over suntour because the splined remover tool is a superior design to the 2 and 4 notch suntours.
Quoted: 12 Post(s)
Liked 8 Times
No, I usually pick up new gold 14-28 Suntours on ebay for fair prices. I don't know from shifting ramps and never needed one.
Modern remakes may be fine. I have no experience. I tend to stick with what I know.
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
I just looked at my 6 speed Shimano UG freewheel and it even has twisted teeth to aid shifting. It's a nice shifting freewheel but it's not as nice sounding as others that I have.
Bicycle Repair Man !!!
I have always thought that the internals on Suntour freewheels was better and they were longer wearing while Shimano has the best tooth design and is probably the nicest shifting freewheel out there.
The quietest and smoothest are probably Regina and Sachs freewheels are nice in every respect.
FBoD Member at Large
Quoted: 30 Post(s)
Liked 7 Times
If you lock the freewheel tool in with a skewer (then back off 1mm or so to allow the FW to spin) you'll never strip or munge a Suntour freewheel.
Likes For khatfull:
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
That is what I do, I even have the Suntour branded remover tool. I can remove them fine... but I still think it's an inferior design compared to the Shimano.
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times
I would replace the old 600 UG freewheel with a modern Shimano HG freewheel. You get the best of both...best shifting performance and according to Sheldon Brown, the latest Shimano freewheel body is the best on the market.
If you have a remover tool for the 600, I bet it'll work on a new Shimano.
Bikes: 82 Trek 613 Sport Touring, 84 Lotus Classique
Liked 10 Times
Ditto on the Shimano Hyper Glide Stuff! Inexpensive and well made. I switched from vintage Suntour (still good stuff) and did not look back. They just shift reliably! You can get a 14-28 easily for under $20.
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,195 Times
Or you can send your original freewheel to me. I bet it still has 10-20 more years left in it. Any pictures or can you tell us why it needs to be replaced?
Bob
Bob
Can you find the Shimano HG freewheels in 14-24 or 13-24 (6 speed)?
I have a Shimano 600 and am using it now, but prefer my SunTour New Winners a touch over this. IIRC, the Shimano is UG. Agreed on the remover design, though I don't have problems getting my SunTours off (skewer method as well).
Quoted: 30 Post(s)
Liked 7 Times
Of course the Shimano is a better design, that doesn't obviate the Suntour design from working well for close to 50 years. Since the single purpose of a freewheel removal tool is to....remove a freewheel my assumption was that you might have had trouble with Suntour in the past. If both remove without issue even a superior design has no practical benefit.
Quoted: 30 Post(s)
Liked 7 Times
The only problem here is that I like to rearrange my Suntour freewheels' cogs for particular gearing a lot of the time. You can't do that with HG...UG yes, HG no.
The splined removal system is superior to the 2 and 4 notched system as people who are unfamiliar with freewheel removal can use a splined tool quite readily while many do not understand how to use a 2/4 notch tool properly and end up damaging the freewheel or tool.
Rhythm is rhythm
Actually, my freewheel does work fine, but it has the super low gear that I want to switch out for a 24 tooth so that transition into my lowest gear will be smoother. Can I replace just the last cog or do I need to replace the entire freewheel? Thanks
You will just need the right replacement cog.
Oh Snap, not again...
This is a timely thread.
I'm looking to upgrade my old 14-28 five speed to a new 13-28 seven speed. I was looking at Niagara and they have a Sunrace version and the Shimano for around $15 the Shimano is a buck or two more, no big deal. Spacing is not a problem but I will probably need a new chain as well. Any opinions on which is the better quality/make. The site says the Sunrace is HG Shimano compatible.
Old fart
Liked 3,400 Times
Yes, the cogs are soft (except for the smallest, which is steel), but the design is great: all the cogs use the same spline pattern, except for the final cog which is threaded and holds the rest in place. Thus, all the splined cogs are fully interchangeable. No washers or spacers are needed because the cogs themselves are machined to provide the necessary clearance. The body itself can accommodate either a 2-prong Regina-type extractor or the superior splined Zeus extractor (later copied by Regina and Atom, among others).
