Looking for a Rando Conversion Candidate: Fuji Espree?
#51
For trail, yes, that makes sense. I don't know that I've seen anything in the Dallas market that's a true rando frame, though that may just be a case of my ignorance! I think if I were to really fall in love with a frame, I might consider getting the fork re-raked, but that's probably a few steps downfield from where I am today
Likes For reluctantsuburb:
#52
Happy banana slug
Quoted: 1534 Post(s)
Liked 1,534 Times
Don't know if this'll help, but it can't hurt!
Likes For Korina:
#53
Quoted: 754 Post(s)
Liked 737 Times
You've got a great set of components. I'd keep an eye out for a larger sized Fuji s10 or s12 to steal the low trail frame from.
Likes For bark_eater:
#54
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
Sounds like you're off to a great start with this one! Since we're heading into winter, I'd just focus on having fun and observing what you like and don't like for now. Go on longer rides, and bring allen wrenches to experiment with the saddle and stem positions. (I think I spy a witness line on your seatpost -- I do the same thing.)
Some neck pain might be normal right now since you're needing to hold you head up at an angle. Make sure you're not hunching your back -- holding it straighter lets you see ahead without needing to bend your neck as much.
If the ride is comfortable, some road buzz isn't bad. Subconsciously, it might encourage you by making you feel like you're going fast!
RUSA #7498
Originally Posted by noglider
#55
Quoted: 1954 Post(s)
Liked 2,019 Times
I don't understand drop bars with that stem. Try Northroads, Albatross or Oxford bars. Or maybe you really want to try drop bars on your Cimarron with the RTP tires. And maybe your saddle can come forward some? I always shoot for clamping the middle of the rails.
Likes For Classtime:
#56
Quoted: 472 Post(s)
Liked 1,061 Times
Drops: I have 10 bikes with drops, all are 25 to 30mm lower than the saddle. I submit that they are better for you as they offer 6 hand positions and being lower than the saddle, force your weight onto your legs and off your hands and butt. Nice. You don't need to be "super aero" but, I think, having much of your weight centered on your legs is a good thing. Yes, your neck will hurt for a while but push through that. All sports hurt for a while as your body adjusts. I can comfortably ride in the drops and see well down the road. No worries.
Trail: trail is hard to see but easy to measure. I use a long straight rod to map the steering center through the head tube and fork. I have a shorter rod with one end bent 90° so it inserts into the hollow axle and the rest goes straight to the floor/tire contact point. The difference on the floor is trail. I have an 84 Fuji TS III that has the original trail of 35mm. I enjoy that ride but have not toured yet with a heavy front load. Sumptin kynna plowed those plans aside for a bit.
Likes For Prowler:
#57
Quoted: 754 Post(s)
Liked 737 Times
This bike is a proportionately larger frame on me, but I started off with a fully elevated Nitto Technomic stem and generic Maes bars. I probably gained some conditioning, but I think where I ended up is mostly finding a ergonomic fit. Right now the the bars are 42cm randonneur bars and the Technomic is "slammed". I am actually very comfortable in the drops with this set up. One thing you have to look out for is that the as you bring a stem up the effective reach gets shorter. Hard telling, not knowing, but it could be that your neck is being effected by your back scrunching into to short of a cockpit.
Redundant embarrassing illustration:
#58
Quoted: 754 Post(s)
Liked 737 Times
#59
Well, thanks to all for the input. I can tell you I am very, thoroughly confused
Here's where I stand today:
- I've gotten in a few sub ten mile rides and they've all been very enjoyable. The bike is speedy and fun. I feel like I'm growing used to the drops and enjoying them
- The bike is definitely smaller than ideal, but I'm trying to decide if it's a workable size. I've been considering some wheel sets but am currently afraid to pull the trigger due to some of the comments here
- When it comes to a vintage bike like this, I imagine there will always be something I'm compromising on... Trying not to set too high of expectations
- Based on fit with my current frankenstem, does the bike look like it's worth continuing to invest in? Next steps are stem, wheel set, and brakes
- Based on what you're seeing and my stated use case of pseudo rando, am I barking up the wrong tree?
#60
Quoted: 1084 Post(s)
Liked 688 Times
You're getting a lot of good recommendations, but back to your original post, vintage Fuji road bikes do have a fantastic ride quality. The Espree was on the lower end of their line though. You may want to hold out for something a bit higher on the food chain.
Whatever you choose, remember that it takes just as much time and costs as much money to restore/upgrade a lower-tier bike as it does a better one, so choose the best bike with the best frame that you can, from the start. Make sure the bike you choose is worth it.
#61
ambulatory senior
Quoted: 1956 Post(s)
Liked 3,662 Times
In your pic you don't look way too tall for the frame but the bars are extremely high. At my age and my neck problems I feel the need to ride very upright as well. To facilitate this I use north road or porteur bars. It might be an option for you.
Keep riding baby!
650b
700c
Keep riding baby!
650b
700c
#62
Liked 2,571 Times
I see that you're holding your arms straight in the photos. Maybe that's a function of trying to hold a pose, but you'll want to ride with your elbows bent a little -- that helps a lot with absorbing shocks before they get to your shoulders and neck. Apart from that, I wouldn't fret about having your handlebars set "too high" for now. When I first got into road bikes, I used a short stem set at least as high as the saddle, but as my core strength and flexibility improved, I was able to stretch out and down.
P.S. Tell your wife that a random person from your bike website says she's a good sport.
RUSA #7498
Likes For ThermionicScott:
#63
ambulatory senior
Liked 3,662 Times
I didn't appreciate how tall you are before seeing these pictures! The fact that you can put a foot down while in the saddle makes me think the saddle itself is a bit too low. Raising it up a bit would probably convince most others that the frame is at least a size too small. If it were me in this situation, I'd pull the plug on this frame and look for something that's bigger, but perhaps not much longer in the top tube. Some brands of road bikes tended to use about the same top tube length between frame sizes, so it shouldn't be too hard.
#64
Quoted: 2333 Post(s)
Liked 2,097 Times
I have many bikes that I randonneur on and also one that is a 650B conversion. I would strongly recommend getting a higher quality frame that fits OR buying someone else's mistake.
I got an unbelievable deal on an older custom made frame with True Temper OS Platinum tubes. I built up a set of 650B wheels with good quality parts and put on Rene Hearse Extra legere tires. I had pretty much all of the other parts but if I had to purchase them, I would into this bike for a lot of money. The bottomline message from me.....it won't be cheap and starting with an undersized frame of mediocre quality is a mistake. Sorry to be so blunt.
I also have another randonneuring bike that runs 700 x 35 tires or sometimes 32 mm.
They both are more comfortable than a full on racing bike using 25 or 28 mm tires but the racing bike also finishes the randonneuring brevet much quicker. There is no contest. If your objective is to have a comfy bike for rides under 100 miles, you are on the right path but expect it not to be so inexpensive. Do yourself a favor.....start with a different frame.
#65
Quoted: 502 Post(s)
Liked 466 Times
@reluctantsuburb,
Looking at your photos, the frame might be a size too small, or at least the seat height might be a touch low.
Try checking your leg position while coasting, after you’ve been riding for a few minutes to get in your usual seated position. Put your heel, or arch if shoes have a significant heel height, on the pedal. Your leg should then be completely straight to maintain contact with the pedal. When pedaling normally with the ball of your foot on the pedal, then the leg has a good bend, like this:
Your saddle might also be a bit too far forward. Many like to check that the kneecap is directly above the pedal spindle when the crank is forward, like this.
Only change one thing at a time, and in small increments (1/8-1/4”). Try that change for a while before you adjust farther. You’ll get a sense when you’ve gone a bit to far, so then return to the previous position. Saddle tilt is another important variable for me, after having figured out the saddle that works well for my posterior.
I'll ride alone with appropriate wrenches and a small tape measure when adjusting my “cockpit”. BTW, I put the bike on a “wind trainer”, camera on a tripod with time delay photos to verify fit and compare on different bikes. All that background detail helps visualize how my position changes. The first shot was part of a sequence comparing two bikes a few years ago, second (actually about 6 years earlier) was taken when I first got this bike to compare different stems and bar heights, and this was not the final stem choice. My stem height is now just below seat height as in the shot with the white bar tape, which works for my 72 years and loss of torso length/flexibility over decades of riding. I’m extremely comfortable on this bike for any distance that my legs, etc. can handle.
Likes For Dfrost:
#66
Eesh what a bummer. Dallas does not see a lot of frames of this style come across. Lots of old MTBs or carbon fiber frames. I'll keep a lookout but was really hoping to make this work.
I guess this is a lesson learned in trusting the seller's measurements Thanks to all for the input.
#67
Any chance anyone can be of help in identifying this Bianchi? It's the only intriguing listing of the day on CL! Not much info, listed at $200
https://dallas.craigslist.org/mdf/bi...394734744.html
#68
Quoted: 502 Post(s)
Liked 466 Times
That Bianchi is a very big frame, much larger than the bike in your photos - compare the head tube lengths. The CL post says 58, but it looks like 63+cm. Judging by the “turkey” levers and stem shifters, it’s a lower end bike.
Way up in the first post, you suggested that a 60cm frame is probably a good size, and backed that up with your PBH measurement.
Once you’ve established your acceptable range of sizes, watch the C&V Sales sub-forum. Also check the Sticky threads for the “Frame doesn’t fit”. We all love to help spend other folk’s money!
#69
Liked 2,019 Times
To play internet fitter, the seat tube is ok (could confirm with pedals at 6 and 12) but looks like you have a long torso-arm combination and could use a bigger frame. Pass on the bianchi. Look closely at the rear corset-derailleur and notice that there is a separate metal derailleur hanger and that the derailleur is not bolted directly to the frame? Not what you want. A separate claw like often signals less than "Nice Bike".
go get this https://dallas.craigslist.org/dal/bi...376666513.html
It will take some work but it is cool as hell and I don't think it will be too big.
#70
I think you are right and your pictures were very helpful, I just made a few micro adjustments and things felt a little more natural and I was able to keep a bend in my arms. Either way, I think a 60 cm frame is ultimately what I'm after and now it's a question of how much I try to make this bike work versus just list it for sale and begin the search again
#71
Me again for anyone still receiving notifications. I just saw this Trek hit CL; looks to be closer to my size (though perhaps too tall?). Seller posted some bad quality pics, so I'm having a hard time making it out, but thought someone here may be able tot ell me if it's worth further investigating or not. I've already sent a message to the seller asking a couple of questions. Listed for $140: https://dallas.craigslist.org/ndf/bi...396665215.html
#75
