2009 Specialized Robaix Expert
I've been riding my old Navarro Randonee for a few years and I'm thinking of buying a used 2009 Specialized Robaix Expert to upgrade my road workouts. (the randonee is so slow and heavy) Do any of you have any thoughts about that? The Expert looks to be in great shape...just old and dusty.
Quoted: 7652 Post(s)
Liked 3,473 Times
If you can be certain that it fits you well and is indeed in very good shape ... then it could be a very good purchase.
https://www.thebikelist.co.uk/specia...ix-expert-2009
OM boy
Bikes: a bunch
Quoted: 517 Post(s)
Liked 644 Times
it's a v-nice bike. stable, but also quick enough to feel lively. That generation of Ultegra is BULLETPROOF (actually, most generations are...)
I have the same yr Tarmac with same Ultegra, I can' telll you how many miles I have on that stuff - without a problem, ever.
They're not the lastest lightest weight Carbon Frames, but that's only a small difference, and if anything, their durability/longevity should be greater/longer.
The wheels were moved onto an older 06 Roubaix and are still running true, with never a spoke issue, and they run fast.
If you can make the bike size/dims fit you, Check the frame possible damage, take it for a ride to test basic functions, check the headset,. If you can check the chain for stretch, and find it well out of acceptable range, you might have to replace cogs/cassette along with the chain.
Otherwise, at the right price, you'll be hard pressed to wear that bike out.
Ride On
Yuri
Ride On
Yuri
OM boy
Bikes: a bunch
Quoted: 517 Post(s)
Liked 644 Times
Forks can sometimes show 'stress' , and inspection around the BB/downtube/stays, other places where there are stress points, like where the seat tube collar sits...
This year had stainless plates on the chainstays to prevent damage from a chain shipped off and between chainring and frame - so very hard to this to create damage, unless it happened very frequently... Then it's just your gut feel for how the bike was handled and cared for.... Bad rub marks on the inside of the chainstays, or inside the fork blades ???
RD Hanger is replaceable, so not a big deal.
Hard to go wrong with this bike - if it hasn't been obviously thrashed...
Ride On
Yuri
Likes For cyclezen:
Quoted: 6193 Post(s)
Liked 4,809 Times
Make sure it all shifts perfectly. 2009 is old for a groupset. Ultegra 6700? If so you might find some incompatibility with new stuff if you have to get a new rear DR. That might require a new shifter. And that gets expensive quick.
Otherwise if it's in great shape it'll probably be a great bike for you.
Quoted: 1461 Post(s)
Liked 1,485 Times
2009 Roubaix was a nice bike. As long as the frame is in good shape and the groupset is in good working order, it's a solid purchase.
Carbon bikes of that era are relatively stiff, narrow tire clearance and with a short cage RD you'll be limited to narrow range cassettes.
Likes For msu2001la:
OM boy
Bikes: a bunch
Quoted: 517 Post(s)
Liked 644 Times
as for compatibility of RD - the Brifters/shifters determine compatibility... they decide between 10 spd and 11 spd... Ultegra 6600 or 6700 are interchangeable for 10 spd, 6800 & 8000 should work - although I've not have personal experience with that yet... I've used the older 9 spd 6500 RD on a 10 spd setup for 5 months (2.5K miles approx) and that worked very well.
as long as the cog range isn;t too large or too broad a range for the cage style.
Cage length will determine max cassette range...
I've NOT used any 11 - ? cassettes - 11 tooth cogs are a joke for me ... would/could never use... I can spin a 12 (on a downhill) up to 100 rpm if needed - that's just over 50 mph... LOL!
at 45 mph, I relax and enjoy the ride !!!
I have, just a month back, replaced the 53/39 std ultegra crank with a NEW Ultegra 52-36 Mid-Compact crankset (which is '11 spd') works great !!! Awesome improvement as I continue to approach the grave... LOL! 11 spd cranks, RD and FD will work on 10 spd as well....
Your options for replacement/upgrade are very broad - without having to do full gruppos... the equivalent Dura Ace stuff (or lower 105) also works. Britfers determine the 10 - 11 spd world.
Ride On
Yuri
EDIT: I do have a wheelset using Conti 700x28 tires (n HED 23mm wheels) and have plenty of room/clearance on the stays, should I get a wooble or broken spoke issue during a ride... I'm eyeballing 3mm space on each side..? normally I ride 25c tires with no issues...
Quoted: 643 Post(s)
Liked 1,526 Times
My first road bike was an 09 Roubaix with a mix of Ultegra and 105 parts and triple chainring. It served me well for several years when I splurged for a new Roubaix Comp Di2. Might still be riding it but wanted to run wider tires as the roads in my area have horrendously bad pavement. I also just wanted a new bike.
What about this one in comparison to the Expert: Which would you buy? The BMC is cleaner and newer...has 105's instead of Ultegra, but other than that...really clean and nice. How do they compare?
