Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Best Road Bike Size for Me?
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 04-17-16, 05:14 AM
MadDog1999
MadDog1999's Avatar
Quoted: 32 Post(s)
Hello guys,
I just want to know the best Road bike size for my body. I am 16 and still growing so would like a size that will last for a while. I am small for my age as I am only 5ft 2 or a bit more. I don't know of waist size comes in here but if it does about 31 inches. So, what's the best wheel size and frame size?
Thanks
MadDog1999 is offline
Old 04-17-16, 07:28 AM
NormanF
Quoted: 147 Post(s)
Liked 8 Times in 8 Posts
Are you male or female?
If you end up on the small size like me at 5'7 or 5'8, you'll want a 54.
For now, you'll want a 48 to 50. Keep in mind you're still growing so you may be better off with a 48 cm mini velo.
NormanF is offline
Old 04-17-16, 08:03 AM
MadDog1999
MadDog1999's Avatar
Quoted: 32 Post(s)
I am male. Thanks for the info. Why would I go with the smallest size if I am still growing? I also want a racing bike
Old 04-17-16, 10:22 AM
NormanF
Quoted: 147 Post(s)
A Respect mini velo can be adjusted by moving the seatpost up as you grow taller. With a road bike, you're basically limited by whatever height you were when you bought it. When you reach your final adult height, then is the time to buy a full size road bike.
NormanF is offline
Old 04-17-16, 10:25 AM
MadDog1999
MadDog1999's Avatar
Quoted: 32 Post(s)
I sadly don't like the look of those bikes, but I'll have to choose. Can it be used for racing?
Old 04-17-16, 07:42 PM
NormanF
Quoted: 147 Post(s)
Its fast enough for rides. But if you want to enter racing, find someone to sponsor you so you can get started in junior racing competition.
NormanF is offline
Old 04-18-16, 08:53 PM
oldbobcat
oldbobcat's Avatar
Quoted: 531 Post(s)
Liked 477 Times in 359 Posts
At 5'2", look for a bike in the 48-50 cm range. 50 might be somewhat on the large side, but you'll likely grow into it or eventually grow out of it. For the interim, it can be fitted with a shorter handlebar stem. The bike will have 700c wheels, which is good because tires and tubes are widely available and you'll be able to share spares with your riding companions. With compact frame geometries, smaller wheels are only necessary on extremely small frames.
oldbobcat is online now
Old 04-19-16, 01:19 AM
MadDog1999
MadDog1999's Avatar
Quoted: 32 Post(s)
Thanks for that oldbobcat. Do you recommend a good cheap bike out there?
Old 04-19-16, 08:07 PM
oldbobcat
oldbobcat's Avatar
Quoted: 531 Post(s)
Regarding used bikes, you can find what's available in your area better than I can.
Regarding new entry level, I like Trek's 1.1, available in 47 and 50 cm, MSRP $770, but usually discounted. Also, check out Scott's Speedster 60, available in 47 and 49 cm, MSRP and local prices unknown. They're usually comparable to Trek's. I was going to recommend the Raleigh Merit 1, but, sadly, it isn't available smaller than 52. Happy hunting.
Old 04-19-16, 09:27 PM
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
5'2" tall but what is your leg length? That will determine your frame size and your torso length will determine the reach you need to comfortably reach the handlebar.
If there is a racing or performance oriented club near you they might know someone who has a used bike the size you'll need.
Cheers
Miele Man is offline
RP25
Fitting Your Bike
5
10-22-18 07:05 PM
kroxburgh
Road Cycling
3
01-29-18 08:54 AM
kpross
BMX
0
05-17-17 06:00 AM
rryyaannbb
Road Cycling
2
09-20-12 08:25 AM
Saephan215
Road Cycling
11
02-04-12 04:08 PM
