Help to choose surly LHT frame size
Hi all!
I am from Russia and here no any LBS which can sell or order or help with surly frameset.
I have a height of 176cm, weight 79kg and an inseam parameter of 81cm.
Because before I did not really bother with the choice of a bicycle and frame size, now I have a problems with the definition of a frame sizing.
I tried to select a frame using the Competitive Cyclist Fit Calculator and it suggest me next frame parameters:
The French Fit (cm)
Seat Tube Range c–c:
Seat Tube Range c–t:
Top Tube Length:
Stem Length:
BB–Saddle Position:
Saddle Handlebar:
Saddle Setback:55.4 - 55.8 cm
57 - 57.5 cm
54 - 54.4 cm
9.8 - 10.4 cm
66.8 - 68.8 cm
53.5 - 54.1 cm
5.3 - 5.7 cm
The calculator advises me a frame with ETTL 540-544 mm which сorresponds to 52cm frame size with 26'' wheels.
I want to try the 700c wheels but I don't know if these wheels better than 26''.
There is also the difficulty with these wheels, because the minimum frame size on the 700c wheels is 56cm with a standover of 81.19cm, which is more than my inseam parameter.
And based on the calculator result, I should choose either 52 or 54 size on 26 '' wheels.
Does it matter if I will use butterfly/trekking handlebar?
So the question is which frame size will be best for me? 52cm, 54cm or 56cm with 700c wheels?
I stopped on surly because it is cheaper frameset then other, but if you suggest something another I will consider it)
The French Fit (cm)
Top Tube Length:
Stem Length:
BB–Saddle Position:
Saddle Handlebar:
57 - 57.5 cm
54 - 54.4 cm
9.8 - 10.4 cm
66.8 - 68.8 cm
53.5 - 54.1 cm
5.3 - 5.7 cm
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Colnago Classic Rabobank Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista
Quoted: 3102 Post(s)
Liked 6,649 Times
Bump for thread that got caught in the machine.
Quoted: 671 Post(s)
Liked 49 Times
I'm 180 cm height, bought the 56 cm 26"/559mm wheel Trucker, standover is OK but 54cm frame would have given option to use a suspension seat post. For your 176cm height the 52cm/26" wheel might work best?
Slow Rider
Either 52 or 54cm should work.
Some user inputs on size with scatterplot showing relation between height and frame size
https://docs.google.com/spreadsheets...GQ/edit#gid=23
second sheet with height and frame size with comments
https://docs.google.com/spreadsheets...BGQ/edit#gid=0
Another thread with similar information
https://www.bikeforums.net/touring/53...l-trucker.html
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1243 Post(s)
Liked 327 Times
Get the 56. No doubt.
FAR too many get an LHT too small and end up with ridiculously jacked up steer tube spacers
If you don't believe me, go thru all the loaded tour bike pics thread.
Sunshine
Quoted: 11033 Post(s)
Liked 7,579 Times
What you say may(and probably) have some truth, but their road frames at least are hurting for more headtube height in a bad way.
Sunshine
Liked 7,579 Times
Ride a bike, measure its dimensions, then decide if its a good size in comparison to the one you cannot test ride.
Bikes: Hardtail MTB, dropbar commuter
Quoted: 9 Post(s)
I'm almost the same size as you, and have been shopping around for bikes recently.
If you are set on the LHT, just buy the 52cm size with 26in wheels and then make adjustments with stem and handlebar height. When you order, see if you can get them to send it to you with the fork steerer uncut.
Quoted: 1058 Post(s)
Liked 1,315 Times
Hi all!
The French Fit (cm)
Top Tube Length:
Stem Length:
BB–Saddle Position:
Saddle Handlebar:
57 - 57.5 cm
54 - 54.4 cm
9.8 - 10.4 cm
66.8 - 68.8 cm
53.5 - 54.1 cm
5.3 - 5.7 cm
The French Fit (cm)
Top Tube Length:
Stem Length:
BB–Saddle Position:
Saddle Handlebar:
57 - 57.5 cm
54 - 54.4 cm
9.8 - 10.4 cm
66.8 - 68.8 cm
53.5 - 54.1 cm
5.3 - 5.7 cm
Ozark Hillbilly
Bikes: Long Haul Trucker
Quoted: 136 Post(s)
"Does it matter if I will use butterfly/trekking handlebar?"
I would think so, if the hand positions your using on the bars most often get you too far upright or stretched out too far. I've only used dropbars on mine so I won't be of much help. I'm sure a few people have converted from dropbars to your choices.
Oh! Thanks for all your replies!
I asked the same question in russian forums recently and nobody answered to me yet)
Here in Russia people more like offroad touring and usually they disscuss about surly troll, ogre, ecr frames or other frames with similar geometry.
Your answers is really helpful for me, especially spreadsheet.
Today I remeasured inseam parameter more accurate and it increased to 83cm.
So I think I should try to find either 54cm or 56cm 700c surly DT frames.
Also I read today about Soma saga dc frame which has 54cm 700c size and I think it also can be suitable for me.
I will looking a little bit larger frames than fit calculator suggested me, because I will use trekking/butterfly bar which a little bit closer to me than other bars (dropbar or flatbar).
So my next step is to find dealers who are ready to send frame to Russia.
For USA I can use some shipping services which gives their domestic addresses where I can ship purchases and for additional cost they will send my purchases to Russia.
It is very convenient if the right thing is not saled in Russia. And sometimes it cheaper than buy the same things directly in Russia.
But in my current case those shipping services сan refuse me because of the size of the shipment.
So at first I will ask dealers/sellers ship frame directly to Russia.
And you are right - several europe bikeshops can ship frames directly to Russia. I will check them also.
Quoted: 1185 Post(s)
Liked 842 Times
I'm 183 cm in height, and ride a 58 cm LHT (700c). Not a perfect fit but with a little shorter stem it feels pretty good. My legs are disproportionately longer than my torso, so the long top tubes on the LHTs are not optimum for me. I would think the 56 cm bike would work for you.
Quoted: 671 Post(s)
Liked 49 Times
Yes, on my 56 cm/559 mm Disc Trucker I have at least 5 cm spacers but stem is fairly short. Truckers have long top tubes, with shorter frame one can use a longer stem. Shorter frame might allow use of a suspension seat-post for those rough Russian roads?
Liked 1,315 Times
Quoted: 1188 Post(s)
Liked 1,154 Times
Another option if you want 26" wheels and trekking bars would be the Intec from Bike24 in Germany. More in the style of the Troll, but much cheaper than that or the LHT.
Some other bars to consider would be the Velo Orange Crazy bars. I recently switched from Butterflies to them, and find them nicer...
Quoted: 671 Post(s)
Liked 49 Times
Bike24 German trekking bikes have more standard features & options & better prices than Surly or other US companies. Russian roads are reputedly bumpy, several German trekking bikes come with suspension forks that might be more comfortable & perhaps even more efficient than 26"-wheel Trucker with fat tires. Plus the German bikes come with flat bars so switching to butterfly bars would probably be fairly easy.
I am your height and own an 56 cm LHT. Could have gone with the 54, but wanted the 700 wheels. No regrets.
bikecommuter13
Fitting Your Bike
11
01-12-15 09:04 PM
Bike4Hunter
Fitting Your Bike
24
09-05-14 02:08 PM
wheysted
Singlespeed & Fixed Gear
29
05-25-14 03:49 PM
