Spork for low-riders?
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
Rodeo Labs Spork appears to be the only carbon fork that enables mounting of low-riders for front panniers.
My touring bike has a steel fork with low rider mounts, which I am sure is the option most people use. However, there are times I would like to put front panniers on my other ride, which currently has an Envy CX carbon fork (with no viable attachment points). Most carbon forks that have attachment points seem to want you to limit what you cary to a water bottle mount or a packet of chewing gum, which makes the Spork (currently 3.0) an attractive option iff it can really handle the weight.
Any positive or negative experiences?
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
Pork, pork, where's my Spork, err spork? 🤔 As if the world's not complicated enough already. 🤨🙄
It looks like you win the right to test it, and report back here. 😁
Perhaps I should be asking in Mechanics, but is there a reason to not epoxy a hard point to a carbon frame? Besides aesthetics?
Liked 3,434 Times
I think if you want to mount low-riders as shown in the picture, you need to put a bolt through the fork, so it would require a drill, not just a dab of glue.
Firm but gentle
Elkhorn Bicycle Rack - Slender, Stout, and Stable | Old Man Mountain
Maybe not what you're after, but I like mine, versatile across many bike axle types. Note the weight limits. I have read that hoop-less front racks are... hopeless.
Quoted: 3461 Post(s)
Liked 1,466 Times
A friend of mine built up a titanium touring bike with a carbon fork eight years ago. He has used a Tubus Tara on it for panniers with no problems. I think his fork is a Bontrager, but that was eight years ago and I am sure models have changed. That was the first carbon fork that i had seen that had low rider rack mounts built in.
In your photo it looks like your rack is mounted so that it hangs on the outside of the rack without any bracing to the inside of the fork blades. I think such racks should be attached to both sides of the fork blade, if possible. For example, the Tubus Duo is attached to both inside and outside of the fork blade. Or, use a hoop like on the Tara if such bracing is impractical.
I used an Axiom rack on my heavy touring bike, it was not reinforced with any bracing to the inside of the fork so I made some extra bracing myself. Photos below:
Palmer
Quoted: 1669 Post(s)
Liked 1,822 Times
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 523 Times
My 2006 Specialized has a carbon fork with low rider mounts. I've had a rack on it from day one with no problems.
Likes For mtnbud:
Liked 3,434 Times
But many thanks for your valuable contribution and accompanying irrelevant graphic.
I really appreciate your deep insight.
Likes For Polaris OBark:
Liked 3,434 Times
I very much appreciate your response, and photos. (Seeing is believing.)
Quoted: 418 Post(s)
Liked 523 Times
BTW - I have some spacers between the fork mounts and the rack to keep the rack completely clear off the forks.
Likes For mtnbud:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
The Spork is awesome but here are some other options as well depending on straight or tapered steerer:
https://tout-terrain.de/en/the-produ...adventure-fork
https://tout-terrain.de/en/the-produ...q-touring-fork
Likes For veganbikes:
