Lurking under the 4 layers of handlebar tape...
Old 12-02-22, 05:42 PM
JulesCW
Bikes: N+1
Quoted: 148 Post(s)
Liked 347 Times in 191 Posts
Getting started on refurbishing a circa mid 1980s Tom Teesdale tandem. The captain's handlebars (Specialized made by Nitto) had some grotty cork tape that was pretty thick, so I started removing it. Turns out there were two layers of cork tape over two layers of cloth tape... I'm pretty sure that the bottom layer was the original. The bike as a whole does not have much in the way of corrosion, but these bars did not like having sweat and moisture locked in by all that tape for all of those years. Here are two spots where the bar is corroded at least halfway through. There's another as well. These bars are now going in the recycling bin -- I'm glad I did not stop at the cloth tape (the top layer of cloth looks pretty good and I briefly considered stopping there). I told the stoker and she made me promise I would check everything very carefully -- a promise I gladly made (I intended to do so anyway, but now she's blessed my spending hours in the basement "safety checking" this winter!).
JulesCW is offline
Likes For JulesCW:
Old 12-02-22, 07:37 PM
sced
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 308 Post(s)
Liked 214 Times in 105 Posts
Could'ave been briefly exciting
sced is offline
Likes For sced:
Old 12-02-22, 07:58 PM
steelbikeguy
steelbikeguy's Avatar
Quoted: 1455 Post(s)
Liked 2,252 Times in 1,106 Posts
hmmm.... that reminds me that I've had the same tape on my Olmo for 20 years.
it's a good argument for using cloth tape that wears out after a handful of years of use.
Steve in Peoria
steelbikeguy is online now
Likes For steelbikeguy:
Old 12-02-22, 08:10 PM
BFisher
Quoted: 753 Post(s)
Liked 1,854 Times in 871 Posts
Had a similar situation with a Cinelli bar that had stitched-on leather covers.
Check those bars, folks. Many believe that aluminum = corrosion/oxidation proof.
BFisher is offline
Likes For BFisher:
Old 12-02-22, 11:53 PM
merziac
merziac's Avatar
Quoted: 3657 Post(s)
Liked 4,192 Times in 2,506 Posts
Maybe on a planet in la la land.
merziac is offline
Likes For merziac:
Old 12-02-22, 11:59 PM
cudak888
www.theheadbadge.com
cudak888's Avatar
Quoted: 2019 Post(s)
Liked 3,080 Times in 1,584 Posts
Yep, seen this before, fairly frequently too.
Bars of unknown past? Unwrap them and check before use whenever possible.
Also examine stems with a FINE TOOTH comb. Seems as if every mildly exotic stem that isn't a basic SR ends up cracking, and it doesn't have to be AVA or French to do so either.
Cinelli 1E:
3TTT, unknown model (to me, anyway. Too lazy to Velobase it right now):
-Kurt
cudak888 is offline
Likes For cudak888:
Old 12-03-22, 03:15 AM
Kabuki12
Quoted: 640 Post(s)
Liked 1,462 Times in 859 Posts
Yea, I use cloth tape and so it gets replaced now and then. I just did my Mondia and wiped them down with brake cleaner to get the goo off. After 50 years, the 3ttt bars were still pretty good. I think some bars are anodized to start with and that helps. I have ridden the heck out of this bike, never in the rain and I don’t have sweaty hands. Still good to check. I never even thought about stuff like that until I saw a couple of threads on this forum of stuff like this, it happens. Better to catch it before it actually fails, that would ruin a ride! Better to have a bad day on the stand than a bad day on a ride.
Kabuki12 is offline
Old 12-03-22, 12:36 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1302 Post(s)
Liked 863 Times in 608 Posts
That rusted Cinelli 1E socket-head nut looks like the type meant for use with a reflector bracket, so without such bracket in place the bolt's taper gets pressed too far into the hole and essentially wedges it to the point of splitting/failure. Seen this on a few such stems (the tell is that the head of the nut won't quite bottom against the clamp casting).
Those entire stems should have been recalled, due to their un-intuitive need for the reflector bracket to remain in place on the (usually) race bikes that they were fitted to. But it was entirely the nut's knurl taper size that created the problem.
I had a creak develop on my 1981 Bianchi's TTT stem/bar some months ago, so thought that I would loosen the clamp bolt and apply installation compound (grit grease) to the bar before sliding it back on center and tightening the clamp bolt.
The clamp bolt literally broke as I loosened it(!), and with not much torque required! That bolt had already partially fractured and was well on it's way to complete failure.
Whew(!), I ride this bike at well over 40mph on some of our local descents.
I EZ-outed the remains of the bolt's stud after drilling a tiny 5/64ths hole, and extracted the bit of stud with, again, little torque required.
The headed bolt end shows the crack had progressed about half way across the cross-section of the threaded stud of the bolt, and showed effects of lengthy exposure to the air. Photo isn't very good at showing this but the grain and color told the story. The stud end also isn't actually cupped as the photo suggests, and shows scratches from trying to get the drill bit to center:
dddd is offline
Old 12-03-22, 12:44 PM
zandoval
zandoval's Avatar
Quoted: 606 Post(s)
Liked 944 Times in 613 Posts
Rats!!! Little things like this just scare the hell outta me...
zandoval is offline
Old 12-03-22, 01:05 PM
gugie
Bike Butcher of Portland
gugie's Avatar
Bikes: It's complicated.
Quoted: 4242 Post(s)
Liked 4,125 Times in 1,772 Posts
I often start to think about these things when I'm flying downhill at 40+ mph...
gugie is offline
Likes For gugie:
Old 12-03-22, 01:11 PM
gearbasher
gearbasher's Avatar
Quoted: 352 Post(s)
Liked 463 Times in 241 Posts
I had a Cinelli stem ( I want to say 1A) that had a notch in it and a tab on the bolt, so the bolt didn't spin when tightening. The pervious owner put the bolt in but didn't get the tab to match up with the notch. Yep, that stem cracked.
Those bars are scary.
I have a friend who was riding his '50s Frejus with original steel bars. He stops for a call of nature and when he was getting back on the bike, the bars just snapped. No warning, no tell-tale signs.
Defication happens.
gearbasher is offline
Old 12-03-22, 01:16 PM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 7236 Post(s)
Liked 7,703 Times in 3,929 Posts
The is the best argument for stripping any old bike you acquire down as far as possible before building it back up, regardless of how good it looks. And it's FUN!!!!
genejockey is offline
Likes For genejockey:
