How Were Rear Racks Mounted in the Old Days?
I have this Raleigh Capri and want to mount a standard rack. I'd love to find an old silver ratrap but I don't want to pay a fortune for it. Anyway since I don't have braze-ons on the seat stays, how were they mounted back in the 80's? Is there some hardware I can buy to do it that way now?
The Pletscher type racks clamped on the seat stays and seldom left them unmarred. A Blackburn or Vetta rack, which is more rigid, would fasten at the rear brake bolt or with P-clamps to the seat stays.
Likes For Reynolds:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
There was a Plestcher rack that mounted to the seatpost clamp in the 70s, but it isn’t common. I personally cringe at the ones that clamp to the seat stays. I have one of the seat post clamp style on my 73 Schwinn. Of course there is also the Blackburn rack that can mount to the rear brake bridge bolt. They are quite versatile, and I even have one mounted that has the mounting strut going through a center pull brake straddle cable.
Quoted: 4806 Post(s)
Liked 3,932 Times
Nearly all (all that I ever saw) racks before the modern seatstay braze-ons mounted on the rear brake bolt. Usually going over the brake and bridge and acting as a washer under the brake nut. Cantilever braked bikes were a joy because there you needed just a bolt through the unused brake bridge so rack on and off was child's play.
This was not as stiff as seatstay bossed rack mounts but worked quite well and before recessed brake bolts, it was not hard to add racks to existing bikes with a clean installation.
Edit: What I am looking for is an easy, clean way to convert seatstay compatible racks to the old brake bridge style. I own zero bikes with seat stay braze-ons and to me, P-clamps belong on crawlspace pipes, not my bikes. Rack on-off isn't as easy and straight forward and they are paint nickers if you don't pay attention. I've never owned a bike that didn't have a brake bridge and I look at brake bridge paint at the brake and nut as I look at paint on dropout faces. Expendable.
Liked 3,932 Times
There was a Plestcher rack that mounted to the seatpost clamp in the 70s, but it isnt common. I personally cringe at the ones that clamp to the seat stays. I have one of the seat post clamp style on my 73 Schwinn. Of course there is also the Blackburn rack that can mount to the rear brake bridge bolt. They are quite versatile, and I even have one mounted that has the mounting strut going through a center pull brake straddle cable.
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
Pletscher made a bracket that would allow their rat trap rack to be attached to the brake bolt, instead of the stays. I've never seen one in the wild, but there are probably a few on FleaBay.
Another problem with the Pletscher racks was that they only had one strut on each side and were prone to swaying (which probably helped with the paint removal on the seat stays).
A vintage Blackburn (or Vetta) has 3 struts on each side and is much more rigid.
Likes For Vintage_Cyclist:
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
My mountain bike lacks any eyelets on the dropouts, so I use padded P-clamps. The drive side chain hanging peg prevents downward slippage, and the upper anchor is to the seat post bolt. (I replaced the original quick-release skewer with an Allen bolt and nut to at least slow down any Brooks Pro thieves out there.)
That second one is interesting, but it looks very narrow. You'd absolutely have to buy panniers. I would probably do it anyway but it would be nice to have the option to just bungee stuff to the top.
As to the p clamps. I have read on here I can buy them at home Depot? Any idea what size?
Quoted: 2485 Post(s)
Liked 2,956 Times
The piece pictured above was added to the package at some point in an effort to prevent the rack hardware from sliding down the seat stays (and taking off paint) when the rack was carrying a significant load.
Likes For Trakhak:
Quoted: 1372 Post(s)
Liked 1,752 Times
I have a couple of these old Pletscher racks, The struts bolt to the eyelets on the drops...
And the front clamps onto the seat stays...
Hope that is a help...
Likes For randyjawa:
For vintage Blackburn are popular. They came with center mounts
Quoted: 3464 Post(s)
Liked 2,831 Times
before the bracket that extended down to the brake mounting, the way we secured them was to hammer the stamped bracket around the stays each side- it was a quick two man task, one with a big ball peen hammer and the other with a small sledge with a blunt chisel end to buck up the strikes. 2 whacks each side and secure. We did appreciate the accessory bracket before Pletcher included one with the parts kit.
a procedure not done in front of a customer.
there was the Wald rack .
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
Here's an image from my '75 Schwinn Sports Tourer which compliments the ones randyjawa posted. I used some dense foam to help protect the paint on the seat stays.
Bob
Bob
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
IMG_0622 by Stuart Black, on Flickr
That bike had rack mounts on the dropout but Ive used them successfully for bikes that didnt have mounts. I used them top and bottom on this frame and have never had any issues with carrying smaller loads. Ive never used loaded panniers on the bike but I have used the rack with 10 to 15 lbs in a rack bag while doing mountain biking.
Stuart Black
Old School When It Wasnt Ancient bikepacking
Stuart Black
Liked 3,932 Times
Thanks guys. Pre-head-injury memories. Pletscher racks. I remembered the rat trap but not the clamp. I thought I'd always been using the downturned early Blackburn style but these posts bring me back to my first several bikes and setting up those Pletschers. (The journey of two lives, one before my 1977 accident, one after. Periodically windows onto that first life get opened. Again, thanks.
Quoted: 96 Post(s)
Liked 292 Times
Here you are
Rear rack-ebay
Hardware
and as another used foam above, I've used cork/rubber automotive gasket material to mount the
stay brackets.
Rear rack-ebay
Hardware
stay brackets.
Here you are
Rear rack-ebay
Hardware
stay brackets.
Rear rack-ebay
Hardware
stay brackets.
Quoted: 2364 Post(s)
Liked 1,750 Times
Aren't pieces of retired innertube considerd the universal material for protectively mounting things like Pletscher-style brackets?
Liked 1,752 Times
I just took a look and I have one rack left. In fact, I think it is the one that I took off of the Freddie Grubb (I could be wrong about that). The rack is complete with mounting bracket and in good shape. The only problem is some surface rust on the steel clamp. I rubbed the rust with aluminum foil and it cleaned up not to bad. Let me know if interested via a PM.
Cantilever believer
Quoted: 536 Post(s)
Liked 1,839 Times
That bracket wasn't meant to be used instead of the seat stay mounting hardware. It was supplied in the package of mounting hardware along with the usual seat stay mounting pieces and the bolts, screws, and nuts. The rack was meant to be installed using all of the pieces in the package.
FreedomRider
Needed a rack for my 21" 1971 Raleigh Sports ... I tried the Ventura Universal Bicycle Carrier Rack --- which has proved to fit well and support fully loaded panniers. Some like, some don't, but I do.
See photos for how I attached it successfully. It took a while to figure it out. Basically, attached it to the rear brake bolt and the fender drop out holes.
The label for the Ventura Rack ... available on eBay and other sources (in the US)
Attaches over the rear mudguard nicely (with about 1 mm to spare), and parallel to the ground
Attached to rear brake bolt
Share the rear drop out mudguard holes
Panniers attached. Note that there is no place to attach the hook of a bungee cord. Oh well.
Cantilever believer
Quoted: 536 Post(s)
Liked 1,839 Times
For racks without a lower hook, I'll take an S hook, push one end into a closed loop, turn the other end 90 degrees, and then put it on the rack eyelet bolt. Seems to work well.
Likes For RCMoeur:
