BB30 Confused and Need Help!!
Quoted: 193 Post(s)
Liked 37 Times
Hey all. Need help with a BB issue. I bought a Cannondale Slice for a TT build and it's marked to take Cannondale's proprietary BB30. I thought the BB30 is a press-fit BB. Yet the frame's BB has threaded aluminum inserts already installed. Is that typical? What am I misunderstanding?
Also, it's my understanding that the BB30 isn't the greatest BB in that it tends to creak. I have no personal experience with it. I also like to use Shimano cranks, none of which are compatible with BB30 (as I understand it.) Praxis makes a conversion BB that allows a BB30 frame to accept Shimano cranks. Here's the link: https://praxiscycles.com/product/shi...f30-68mm-road/
Actually, it looks like that Praxis will not fit a threaded BB. I'm completely lost on this issue. Admittedly, I don't have a lot of knowledge about BB's. Any advice on how I should proceed will be greatly appreciated.
Quoted: 193 Post(s)
Liked 37 Times
BB30 Confusion
Hey all, I'm not a mechanic, so I hope you all don't mind me coming to this forum for a little direction. I bought a Cannondale Slice for a TT build and it's marked to take Cannondale's proprietary BB30. I thought the BB30 is a press-fit BB. Yet the frame's BB has threaded aluminum inserts already installed. Is that typical? What am I misunderstanding?
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista
Quoted: 3130 Post(s)
Liked 6,797 Times
Merged duplicate threads.
Please do not cross post.
Likes For cb400bill:
Quoted: 1111 Post(s)
Liked 1,050 Times
Someones probably pressed in an adapter. Can't remember which one I used but my middle kid's cross bike came with a pressfit standard. I pressed in an adapter that takes an english threaded BB. Came in handy when the first BB didn't survive its 3rd race. BB30 and PF30 are both only 68mm wide so installing an insert will let you use a standard width crankset.
Quoted: 4595 Post(s)
Liked 1,749 Times
https://www.universalcycles.com/shop...RoC0V0QAvD_BwE
If this is what was installed, and it was installed correctly, you now have an English BB and you can't go back.
This might have been done because of squeaking problems that it solved.
Quoted: 193 Post(s)
Liked 37 Times
Quoted: 193 Post(s)
Liked 37 Times
I should know this stuff alreadyy, right? Thank you!
Liked 1,749 Times
You'll need to refer to the BB instructions that match your chosen crank model. Road bikes are never 73.
Likes For Kontact:
I put a Shimano 105 11sp crank onto a BB30 shell with the Praxis adapter and it works just fine. What the prior owner of your bike did should also work, and gives you a lot of flexibility.
Quoted: 1158 Post(s)
Liked 1,267 Times
The OP's bike has been adapted beyond this, but just FWIW, it's pretty easy to adapt/convert a BB/PF30 to a Shimano Hollowtech, or really, any crankset.
I used this thread together PF BB to adapt my wife's BB30 (maybe PF30) bottom bracket shell to her Shimano Hollowtech crankset. Easy, effective. PRAXIS WORKS | CONVERSION BB for Shimano HT2 Road cranks. (praxiscycles.com)
Aside - both Wheels Mfg and Praxis make thread-together BBs just as an alternative to simply pressing them in. I use one on a PF30 BB with a Sram DUB crankset and it works silently and was easy to install. Lots of reviews and DIY videos of these things online.
I also used these simple shims for a while, and really, they worked fine. BB30 Adapter for 24mm Spindle Cranks (Shimano, FSA, etc.) (wheelsmfg.com) This is the ultimate in simple easy to use press fit - Shimano adapters. I switched to the above not because she was having any issue, but as the family mechanic, responsible for "never problems", I decided to use the above product thinking that it's probably less likely to cause issues.
