Brand new Woom 3 bike ?Hub problem
Hi
Just got this brand new woom 3 delivered to New Zealand from the Neatherlands via Bikeinn.
I notice the rear hub is noisy and it's more "grippy" in that the pedals are much more likely to spin.
Also the chain has a bit more of a clank when you rock the pedals back and forth (I think this is separate issue. maybe chain slightly loose).
Please see video (The yellow bike is the new bike and the blue bike is our older bike
Can anyone give advice as to what is wrong with this brand new bike?
Also the rear wheel is not completely "true" when it spins.
Thanks
Mike
Thanks
Mike
Expired Member
Quoted: 3797 Post(s)
Liked 5,795 Times
Warranty? First step would be take it to the shop.
I am potato.
Quoted: 1826 Post(s)
Liked 1,705 Times
The video link doesn't show. So, I'm just guessing.
I had to look this bike up. It claims to have a freehub and sealed bearings. My guess is that the bearing adjustment is too tight and/or if there is a genuine rubber seal to really effectively keep the weather out of the bearings like an adult bike that the seals are tight enough to drag the super tiny drivetrain along when you are walking the bike along.
Any bike shop can do a bearing adjustment. It's super common for all new bikes direct from the factory to require this. The factory worker has neither the time nor inclination to do it right when he's expected to churn out hundreds of hubs a shift. Especially when there is a bike assembler between the company and the customer. It goes with the territory. This is what you are trading away when you go mail order. Go to a local bike shop. Perhaps they'll install the absent grease, too.
Likes For bboy314:
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 891 Post(s)
Liked 1,245 Times
Likes For Barry2:
Palmer
Quoted: 1704 Post(s)
Liked 1,890 Times
Single-speed or two-speed?
Clark W. Griswold
Quoted: 4505 Post(s)
Liked 4,190 Times
What did Woom say about this? If BikeInn is an authorized dealer of Woom then they might be able to help with warranty as they sold it to you. It might also be the bike needs to be properly built and tuned which doesn't happen at any point before getting to you from being bought online (sometimes in rare instances a company will send a bike that is tuned but not common). From a shop they will build it and tune it before it ever gets to you but from online in a box it won't generally be touched at the factory beyond a quick assembly and then quick disassembly to get it into the box.
Likes For veganbikes:
Expired Member
Liked 5,795 Times
Likes For shelbyfv:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1253 Post(s)
Liked 338 Times
My search shows a SS kids bike for pre-school age. With chain case, rim brakes and bungie fork.
Will need to adjust every nut and bolt on that, often likely.
Expired Member
Liked 5,795 Times
Hopefully they can get it sorted for you.
Likes For shelbyfv:
Likes For grumpus:
I was surprised that woom come back to me that everything is fine after sharing the videos, although when i watch their video on adjusting chain length the rattles sound a lot like their video on incorrectly set chain tension and how to adjust.
Originally Posted by woom support
Thank you for reaching out to us!
At the beginning, the freewheel is often very smooth-running. That is also a sign for the quality and ease of operation of the drive system. It may also be the case that the crank rotates when the wheel is pushed. This is because there is less friction in the bottom bracket than in the freewheel. As a result, the rear wheel moves the chain via the friction in the freewheel, causing the free-moving crank to start moving too.Don't worry, though, as the force of the friction tends to be minimal anyway. You wouldn't even be able to see this effect if the bottom bracket didn't run so smoothly. It would be a defect, if the crank still rotates while coasting with feet on the pedals. But if you have any further questions, feel free to reach out anytime!
Quoted: 1873 Post(s)
Liked 1,748 Times
What difference is there between the 2 bikes? That could explain why they do not exhibit the same behaviour
If one has a simple freewheel and the other has a multi speed hub, you have your explanation
they are same bikes just 14 vs 16 inch one is old and one is new. both single speed freewheel hub.
I've sent a further video to woom it's a little frustrating.
In the interim i will buy a set of hex keys and try adjusting the rear wheel.
there is a slightly bigger gap on the brake pad on one side of the rear wheel too, and if i backed the rear wheel on the chain side a few mm back that would be corrected too.
quite disappointing. if i can't get resolution with woom i may need to take to the local bike shop to and pay them to sort out the issues. shipping the bike back overseas is going to cost a fortune. its disappointing that an expensive bike comes with this issues and I'm left sorting them out. unfortunately there is no local option for a higher end kids bike nz with a freewheel rear hub (we only have coaster brakes).
really disappointed again with this bike. I bought some brand new hex key set and I've discovered that one of the hex bolts for the rear wheel was stripped in the factory, which might explain why the rear wheel is not set up properly. Its a 4mm hex.
Quoted: 563 Post(s)
Liked 504 Times
Thread stripped or head rounded? They look like regular M5x0.8 stainless screws as used for mudguards and bottle cages. You should loosen both sides and slide the wheel back while centring it between the stays. Tighten the adjustable dropouts and check there is a small amount of slack in the chain while turning the crank a few times. If the brake is not centred you then adjust it to the wheel, rather than adjusting the wheel to the brake. These are all things that are normally done by the dealer before handing over to the customer, but you may have to pay your LBS to sort out. Online/international purchases are really useful in some ways, in others not so much.
Clark W. Griswold
Liked 4,190 Times
If you didn't touch it prior to this point and it was shipped in a box, that would be a good thing to send pictures of to Woom so they can send you a credit for a new bolt and to pay a mechanic to fix it. You can also try a Torx wrench sometimes that will allow you to remove it and then just check the specs of the bolt and order a good quality stainless steel bolt and use good quality hex wrenches to install the new one (with the proper grease, anti-seize or thread locking compound as needed) and then you have a little extra in your pocket if you don't want to pay a shop to remove the bolt.
The hex bolts are really rounded off, I think they have had trouble getting the wheel setup correctly.
After a dozen emails with woom EU they now want me to start again with woom US, the bike is purchased from EU retailer (Bikeinn) and came from EU, but because I am from New Zealand, they now want me to deal with woom USA (Woom USA doesn't deliver to NZ).
Not having much like with Bikein either, they have asked me to send them videos again (which they already had links to).
Have asked woom EU to escalate to a manger. I;m getting close to 30 days now, I might have to look at whether I can do a charge back or something.
I really just expected that they would tell me to take the bike to a local shop to diagnose and then they would either repair or replace, instead of back and forward emailing
Liked 338 Times
They look like cheap bolts. Just unscrew the good bolt. Use vice grips for the other bolt.
Go to a hardware store and get 6 or 8 of them and replace all of them. Done.
Likes For GamblerGORD53:
I think bikeinn need to stand by their product which is new and shouldn't arrive with faults.
I've sent them the following email today
Urgent: Resolution Required for Faulty Woom3 Bike (Order # xxxxxx)
Dear Tradeinn Customer Service,
I hope this message finds you well. I am writing to urgently address the ongoing issue with the Woom3 bike I purchased on May 3, 2024 (Order Number: xxxxxx).
Despite multiple attempts to resolve this matter, I have yet to receive a satisfactory response. Here is a summary of my efforts and the issues encountered:
To resolve this issue, I request one of the following actions:
I await your prompt response.
Yours sincerely,
- Initial Contact and Return Request: Filed on May 16, 2024, including photos and YouTube video links documenting the faults.
- Follow-Up: Filed another return request on May 21, 2024, as the original request seemed to have disappeared from your system.
- Two Emails with Videos Attached: Sent on May 23, 2024, as requested by your team.
- Loose and Rattly Chain
- Noisy Freewheel Hub
- Misaligned Rear Wheel
- Rounded-Off Hex Bolts
- Missing 14mm Wrench and Hex Key (which should have been included)
- Missing Manual (which should also have been included)
- A full refund, including any shipping costs incurred.
- Alternatively, a replacement bike, ensuring it is thoroughly inspected for quality assurance before shipment.
- Reimbursement for local repair costs, should you prefer that I take the bike to a local mechanic for diagnosis and repair.
Yours sincerely,
