Help with 1x Chainring for climbing
Old 07-08-22, 06:08 PM
PacificSpray
Quoted: 5 Post(s)
Liked 7 Times in 6 Posts
I live and tour in steep hilly areas and want an easier climbing gear for mostly pavement and rail trails.
I have an HPV FX20 Gekko trike (20” rear wheel).
Hub is SA 3-speed, Cassette 8-speed (11-34) and Chainring 1x110bcd (5 bolt) 46T. So effectively a 1x 24 speed.
I’m considering a 34T or 36T chainring. The crank arm looks like 170mm.
I never use the highest gears.
My online searches reveal that I could easily err because of my limited knowledge of chainrings, and I’m not confident to proceed.
Would you knowledgeable folk please guide me and/or suggest something suitable, and point out potential pitfalls?
PacificSpray is offline
Old 07-08-22, 06:17 PM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
Your 110bcd 5-bolt crank will fit as small as a 33T chainring (34T is far more common) so your proposed change will work. I don't know if your current 46t chainring is a "narrow-wide" design to aid chain retention but try to find a replacement of that type.
HillRider is offline
Old 07-08-22, 06:21 PM
PacificSpray
Quoted: 5 Post(s)
Thank you. Are chainrings specific to 1x, 2x or triple setups or can I ignore that?
Old 07-08-22, 06:31 PM
HTupolev
Quoted: 1979 Post(s)
Liked 1,298 Times in 630 Posts
They can be, but narrow-wide chainrings are in general 1x-specific. The narrow-wide profile is specifically intended to prevent the chain from derailing, which obviously is problematic if you're using a front derailleur.
HTupolev is offline
Old 07-08-22, 06:43 PM
PacificSpray
Quoted: 5 Post(s)
The teeth, on close inspection, appear to be of constant width, but on either side of the ring are very effective supports. This suggests to me that a smaller ring might no longer be supported as effectively. So a narrow-wide would become more important?
Old 07-08-22, 08:34 PM
HillRider
OK, your current crank has chain guards on both sides of the chainring and these keep the chain in place. A smaller chainring will probably allow the chain to rub on the guards when on either end of the cassette. So, delete the guards and use a narrow-wide chainring to accomplish the same thing. Depending on the thickness of the current set-up you may need shorter chainring bolts when the guards are removed.
Old 07-08-22, 09:35 PM
bwilli88
Not lost wanderer.
bwilli88's Avatar
Quoted: 886 Post(s)
Liked 999 Times in 525 Posts
Here is the equivalent of your setup now. The SA 3 speed gives you the same as a 55x46x33 triple. With this you have a low of 21.9 Gear inches
Changing to a 34t chain ring will lower that to 15.7 gear inches.
Not too much of a difference. When you get that small you can almost walk faster. Going to a 42 or 39 might be easier and still give you some in the upper ranges.
bwilli88 is offline
Old 07-08-22, 10:04 PM
PacificSpray
Quoted: 5 Post(s)
Thank you for your work. I appreciate it.
Old 07-08-22, 10:09 PM
PacificSpray
Quoted: 5 Post(s)
That makes sense to me. Thank you.
The plate thickness of the 46T is 3mm (aluminum). Two prospects on Amazon are both 4mm. Without the side pieces I may be able to use the existing bolts/screws.
Old 07-09-22, 07:39 AM
HillRider
The OP is riding a trike so there is no such thing as too low a low gear. They are heavy and climb very poorly since you can't stand to use your weight and they can go at a crawl speed since they can't fall over. Yes, you could walk faster than the lowest gear will let you pedal but not uphill and pushing the trike.
Old 07-09-22, 10:01 AM
PacificSpray
Quoted: 5 Post(s)
You are correct. The OP also has very old knees.
Old 07-09-22, 10:10 AM
SoSmellyAir
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times in 1,020 Posts
PacificSpray is using an 8 speed cassette and presumably an 8 speed chain. Are there narrow wide 8 speed chain rings? Is he not better off with a regular chain ring?
Surly 34t x 110mm Stainless Steel 5-bolt Chainring - Modern Bike
Surly 36t x 110mm Stainless Steel 5-bolt Chainring - Modern Bike
SoSmellyAir is offline
Old 07-23-22, 07:35 PM
PacificSpray
Quoted: 5 Post(s)
I have replaced the factory 46T narrow chainring with a Deckas 34T 110x5B round narrow-wide (Amazon). It fits perfectly and has addressed my climbing problem. And I learned what I needed to learn from the replies. Thank you.
