Foreign object inside inner tube
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
I flatted today and put a spare tube into the front tire in a roadside repair. After putting the reinflated wheel back into the frame, I gave it a spin to make sure it was clearing the rim brakes and that there was no other issue. I could hear an odd sound, new to me, as the wheel rotated, but I could see no obstruction or contact with brakes or frame, so I road it home.
Back at the ranch with the bike in a stand, I listened again, and there was definitely something rattling around in the wheel at low RPM, but it was silent at high RPM. I took off the tire and tube, and checked the wheel to see if there was something in the rim, but no. Turned out there was something in the tube itself!
Here's what it looks like in the deflated tube:
By feel, it seems to be a slightly-curved piece of hard wire, 1.5 inches long with a slight hook on one end. I had wondered if it were a valve core that dropped through the valve stem, but it's too long and too curved to be that.
This is a Schwalbe tube, model SV14A, made in Indonesia (so it's a true foreign object). I bought four of these tubes in 2019 when I went to 650b wheels, and it's got lotsa miles on it, along with 5 Remo patches. I'm pulling out of duty for now, but may put it back into rotation as a spare, because whatever is in there hasn't affected its performance.
Another new cycling experience!
Quoted: 4210 Post(s)
Liked 3,876 Times
Was this tube in the 584 wheels/tires? Just wondering as it's labeled as a 559. Not that the possible size miss match seems to have been a problem.
But for the cost of a tube I'd rather not get a preventable flat so I would replace it. Andy
AndrewRStewart
AndrewRStewart
Quoted: 257 Post(s)
Liked 252 Times
Yes, it's a 559 in a 584, good spot. The tire vendor, Rene Herse, (Compass when I bought the tires) recommends this size for 650b x 37-55, they seem to like the smallest tube that will fit. Haven't had a problem in use, but will try a 584 on next tube buy. You're right about not chancing a flat by reusing.
Liked 3,876 Times
I have done this same tube size miss match. But usually, it's a second choice. A get the rider going again choice. Unfortunately, the last couple of years a this has been the "go to" more times than over the previous 40 years as tube availability became problematic. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 6196 Post(s)
Liked 4,811 Times
I have once or twice heard stuff that seem to be rolling inside the tubes when I turned the wheels slowly. I just ignored it and I don't recall that I had any issues or shorter life out of the tube or tire.
Maybe one of the employees and the factory thinks it's a funny joke and puts some little scraps of rubber in there before the tube is joined.
Quoted: 257 Post(s)
Liked 252 Times
Reminds me of the Seinfeld episode with the Junior Mint. Obscure reference.
Liked 4,811 Times
If it's metal or anything that seems hard, my curiosity would have me cut the tube open no matter what just to see what it is. Maybe they put a prize inside like the old Cracker Jack candied popcorn had <grin>
Likes For Iride01:
Quoted: 4806 Post(s)
Liked 3,932 Times
Can you remove the valve stem then work that object to the valve and out? I'd try just to satisfy my curiosity.
Quoted: 257 Post(s)
Liked 252 Times
I don't think so, the object is curved/radiused enough so that it wouldn't pass the valve stem. Eventually I'll just cut the tube and see what it is. Photo will follow.
Likes For PacificSpray:
Quoted: 980 Post(s)
Liked 582 Times
I would take that to my friendly dentist and ask them to make a radiograph of it. This is what *I* would do because I'm a dentist!
But realistically, even using non-destructive technology to identify the object, it it's metal you're not going to use the tube. You might be able to send it back to the source (or Schwalbe) for a replacement.
I was doing a teleportation experiment with hundreds of pieces of wire. The wires did not re-materialize in the target location...
In fact, I lost all of them
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
For no more than a tube costs, I wouldn't want it inside possibly cutting away and damaging the tube from the inside out so I would cut it open. That and I'd be pretty curious as to what it is.
Likes For Chuck M:
Likes For wheelreason:
So, are we extracting the object from the tube to have a look
Quoted: 257 Post(s)
Liked 252 Times
That’s a pretty good idea!
sorry, didn’t quote, to push it out and patch.
Quoted: 257 Post(s)
Liked 252 Times
The Big Reveal!
Foreign object inside a Scwalbe inner tube
It's a rusty metal piece, about an inch-and-a-half long, a sixteenth in thickness. Both ends pointed but not very sharp. As I said in the first post, this thing has been in there for hundreds of miles of riding. The tube has five patches (now six), maybe it caused some of the punctures, can't recall.
I'll send the photos to Schwalbe North America for their amusement. Maybe they'll send a replacement, I wouldn't decline.
Andy, as I said, Rene Herse recommends this 559 tube for the 38x584 tire. I went looking online for a replacement 584 tube, and they are hard to find in a narrow size. There are plenty in the 1.75 and up range, but I only found the Schwalbe with a 1.50 (38mm) tube. Schwalbe even has a tube model SV12 that it specifies for a range of 30x559 up to 47x584. The tubes I have been using, the SV14A, is specified for for 40-60x559.
Likes For BCDrums:
Likes For Crankycrank:
Quoted: 257 Post(s)
Liked 252 Times
Pretty good question, though!
