Will average speed be higher on a stationary bike?
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
Last year, I bought a Schwinn IC3 stationary exercise bike for my lovely bride, and she rides while watching TV. I decided to do the same, and want to record my mileage into Ride with GPS to add to my good-weather road riding.
The bike is not web-connected. It has an on-board “console,” really like an old-school Cateye bike computer, that reads out MPH, distance, time and cadence, derived from a single RPM sensor on the flywheel. The MPH and distance it reports seem inflated to me. For the last few years, my average speed has been 15-15.5 MPH at 85-90 RPM cadence and this unit reports 19 MPH at the same cadence.
I am wondering if the console data is accurate or not. Does the fact that I am not riding a varied terrain of rolling hills translate to a higher average speed, or is the console just wrong?
More clues: in order to send the data from this bike to RwGPS, I bought a Wahoo speed sensor and mounted it to the flywheel. The sensor talks to the Wahoo Fitness app on my phone, which can forward my ride data to RwGPS. The app allows me to enter a circumference for the wheel, so I used the circumference of my road bike’s wheel and tire. The result was a crazy-high speed and distance, 23 MPH, so I changed the circumference to the actual size of the flywheel, and got an average speed of 17 MPH, not much different from the bike’s onboard console at 19 MPH.
Does anyone have some idea as to whether I should expect a higher average speed on a stationary bike? Or is the bike’s on-board meter inaccurate?
Thanks for your thoughts.
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,844 Times
Will my little tykes oven be the same temp as my adult oven.
don't want to burn the cookies.
Likes For Wildwood:
Quoted: 236 Post(s)
Liked 196 Times
Kind of apples and oranges here.
Any speed/distance stuff will be whatever you choose to calibrate it to be. The flywheel isn't a tire, you're not covering ground, and you likely haven't any real idea as to the gearing ratio from the crank to the flywheel like you might with a bicycle on a trainer.
Also, since there's no wind drag, you'll tend to see more speed for the same power output at any given cadence.
If it were me, I suppose I'd set the wheel size to whatever gave an approximation of my usual outdoor speed for a given cadence/effort. It's still going to be an approximation so I wouldn't get too wrapped up in trying to achieve any sort of accuracy.
Likes For gpburdell:
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
On an actual moving bike the power lost to wind drag will start to vary with the cube of velocity (the difference in wattage between 19 and 20 mph is substantially more than that between 15 and 16), while the power consumed by the exercise bike's resistance mechanism is likely nearly linear with cadence if a strap, or the square of cadence if magnetic.
Quoted: 4420 Post(s)
Liked 4,873 Times
Speed and distance reported on that type of bike are pretty meaningless. Only a smart trainer/bike with accurate power measurement and real world simulated physics model (including your own weight, height, road bike, tyres etc) can provide a realistic speed and distance covered over a simulated course. What you have there is a very crude approximation of speed on some generic road bike riding on flat smooth ground with no wind. IME they are nearly always much faster than what you can achieve outdoors, especially if your outdoor ride involves hills and windy conditions.
Thanks.
To the OP i feel slower on my stationary but speed sensor indicates I'm faster on it. Like others said the factors of riding to the outdoors will attest to what you're seeing. Either way you're pedaling.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Virtual training setups take into account road grade, a CRR estimate, the physics/aero actually somewhat tweaked to rider height and weight, etc....... This is why "distance" and "elevation" work out reasonably well for smart trainers and things like Zwift. None of that exists for a simple stationary, so distance becomes irrelevant.
Stationaries and fluid trainers and such, just worry about time spent doing work. If you need to track wear and tear, speed sensor works fine to track miles on fluid trainers using your real bike. Most gyms with stationaries probably track equipment hours, not distance, to perform maintenance.
Outdoors also, I go by time and intensity. Not miles. If I ride cyclocross, I might average 12mph but work just as hard as riding my TT bike at 24mph. So.....distance is worthless to fitness.
Quoted: 257 Post(s)
Liked 252 Times
Friction trainers are not accurate against real world performance. Smart trainers will be reasonably accurate but ridiculously expensive.
If you don't have the budget, friction trainers are more than adequate enough if you have a heart monitor to enable zone training. They get the job done.
Indeed - an OP is starting to get into a speed regime where (apart from climbs) wind drag is the major consumer of wattage. Remove that and of course "speed" goes up...
Indeed... have been debating if the snow I'm watching fall outside means today is the day I'm finally sticking some sort of algorithm...
Virtual training setups take into account road grade, a CRR estimate, the physics/aero actually somewhat tweaked to rider height and weight, etc.. None of that exists for a simple stationary, so distance becomes irrelevant.
Quoted: 930 Post(s)
Liked 393 Times
(They do claim it's a light fluffy snow)
Quoted: 1944 Post(s)
Liked 2,164 Times
Just adjust the circumference setting until you get to 15-15.5mph. You can probably use the road wheel and flywheel numbers to calculate the circumference. You will be close enough for what you are doing. When you get back on the road, you can compare and adjust for next winter.
A heart rate monitor is nice, a fitness watch might be a good choice. It won’t help you now since you don’t have an outdoor baseline. But it will be helpful going forward.
John
John
Likes For 70sSanO:
Quoted: 18424 Post(s)
Liked 15,582 Times
Distance travelled will be less.
Likes For indyfabz:
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,041 Times
In my experience with both a wheel-on smart trainer and a Wahoo Kickr bike, yes your average speed will be higher. With the same power output the trainer’s “speed” is higher than road speed. I always put the difference down to not slowing down for corners or stopping for red lights. Simulate both with the same frequency as when you ride the bike and you’ll likely find the speed matches more closely.
Likes For MattTheHat:
Liked 4,873 Times
Quoted: 1612 Post(s)
Liked 2,594 Times
You could use your Garmin to calibrate your results.
Quoted: 6198 Post(s)
Liked 4,814 Times
You aren't going anywhere on a stationary bike or trainer. So really you shouldn't even think of speed or distance when on them. IMO.
I only look at time, power and/or resistance level when on a trainer.
Likes For Iride01:
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Yup. Just ride, get a workout and don't "sweat" the numbers.
Likes For Homebrew01:
Exactly. On average, a stationary bike goes... 0 mph. It's stationary! Any number on the speedo is imaginary. The important numbers are work (heart rate?) and time.
Quoted: 4227 Post(s)
Liked 2,488 Times
Just get a good workout and don't worry about chasing any numbers.
Likes For wolfchild:
ri alene
Quoted: 51 Post(s)
Liked 60 Times
And so endeth the lesson.
But how can I reach my “mileage” goals on Strava if I don’t inflate my numbers?
Set your trainer wheel circumference to zero on your trainer app that way it reports no speed or distance.
Trainers are for time only and power if you’re tracking it.
Pretend miles are pretend.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4394 Post(s)
Liked 3,017 Times
No.
Quoted: 426 Post(s)
Liked 274 Times
From my experience ( we have two saris h3 direct drive smart trainers ) several friends with other direct drive and friction trainers.
The friction trainers or at least the few people that I know is way optimistic ( gives you more watts, speed than you have ). I see their strava times/ride with them etc.. and it does not add up.
If you are on really smooth road, no cars, wind etc.. your flat speeds outside is very very close to zwift. Where I rides it's almost 99% not like that so it takes more watts to do 20 mph on the flats than in zwift. I compared it to my assimo power pedals.
Up hill is accurate in zwift as long as you plug in the correct data. 10% hill takes x watts todo y mph.
downhill is a joke. You have unlimited gearing on zwift bike. Your bike can pedal 50 mph. I have nothing to compare it to. I never pedaled that fast IRL. So your avg mph will be faster in zwift if you can pedal 50 mph down hill while IRL might only be 30 ish mph. You're slighter faster on the flats and even faster if you draft people which never happens IRL on solo ride.
So, yeah hard to compare a zwift ride for 50 miles at 3k elevation at avg 18 mph vs IRL 50 miles at 3k elevation at avg 13 mph.
Liked 4,873 Times
Likes For PeteHski:
Klaatu..Verata..Necktie?
Quoted: 10442 Post(s)
Liked 11,916 Times
Yeah, as lots of other have said, on a "dumb trainer" distance is meaningless. And if you don't have a power meter or heart rate monitor, you really don't have any way to gauge your effort. When I was still using a dumb trainer, I used an HRM. From years of riding, I knew my HR zones, and I would adjust my gearing accordingly, to spend the desired amount of time in the zones I wanted.
Regarding Zwift's model, I think the downhills seem unrealistic because there are no turns to brake for. Long descents IRL rarely come without corners, and some of the descents in Zwift are miles long with no braking. Bike Calculator gives a speed of 51 mph for a 90kg rider on a 9kg bike, going down a 0.5 mile descent of 8% in the drops, so I don't think the speeds are really that unrealistic, given all of that.
Quoted: 581 Post(s)
Liked 921 Times
There is no direct comparison to calculate equivalent road miles to trainer miles. Lots of more expensive trainers may have power meters that more directly equate to power meter reading on a bike, but even that isn't "1 mile trainer = 1 mile on road" - you can compare and say "I maintained an average of X watts on the trainer for H hours, and I previously did H hours at X watts on my road bike, therefore it was a similar workout" and make assumptions about mileage based on that if you wish.
You can do a comparison using a heart rate monitor, as well, and this would be cheaper than a power meter, but heart rate isn't as repeatable a metric in my experience.
Likes For ClydeClydeson:
Liked 4,873 Times
