Removing Shimano Hollowtech I Cranks
Old 03-14-24, 03:00 PM
mark_243245
I have a a Gary Fisher 2006 Hoo Koo e Koo with what I think is Shimano Hollowtech I (one) crankset.
(Not Shimano Hollowtech II).
All the online instructions I have found point to that being a 8mm wrench for the crank bolt to be removed.
But when i put my Park Tool 8mm P-Handle hex wrench in, the whole length of the wrench goes straight through the bottom bracket.
Does anyone know how to remove it?
What is inside there, looks like the crank bolt or something is 10mm hex. But not sure.
Does anyone know how to remove this, like is it a 10mm crank bolt instead of 8mm?
2 pictures I wanted to attach. But I am new to this forum and it won't let me.
It says "Hollowtech" on the crank arms.. And also "Mega 9". And also "Shimano Drivetrain".
The bike is 9x3 speed.
Thanks
mark_243245 is offline
Old 03-14-24, 03:10 PM
Iride01
Iride01's Avatar
Quoted: 6199 Post(s)
Liked 4,816 Times in 3,323 Posts
Some where 10 mm. What ever size it is find a good fitting hex key and just turn it the proper direction. Been a while since I did that, but I think counter-clockwise on the left and clockwise on the right to loosen. Someone else will be fast to correct me if I'm wrong!.
I'm pretty sure that is a self extracting crank arm. What's the exact model/part number? That'll probably be on the inboard side around the hole for the pedal.
Here are your pic's.....
https://www.bikeforums.net/g/picture/33025983
Iride01 is offline
Old 03-14-24, 03:34 PM
mark_243245
The opposite site of the crank to where the pedal sticks out..think it has wrriten:
Shimano FC-M510 MALAYSIA VIA BK 175
So Black 175mm
Old 03-14-24, 03:50 PM
Iride01
Iride01's Avatar
Do you have these instructions? They say 8mm too. But still Shimano used both sizes for the bolts at various times. Maybe yours isn't the original bolts or it's a version that wasn't out at the time of this document's publishing.
https://si.shimano.com/en/pdfs/si/F7...000-00-ENG.pdf
more documents that might be helpful are here.... https://si.shimano.com/en/manual/sea..._model=fc-m510
Iride01 is offline
Old 03-14-24, 05:01 PM
KCT1986
Quoted: 346 Post(s)
Liked 320 Times in 234 Posts
So Black 175mm
Your version seems to be more similar to the FC-M540 with the 10mm style bolt. Bolt should be counter-clockwise to remove, on both sides. Cover should come out with the bolt, revealing standard crank extraction treads. Probably a Octalink V2 hollow spindle BB.
You need a crank puller designed for the large hollow spindle, or use an adapter on a standard puller (see the center circled adapter, sometimes referred as a 'top hat) to 'cover' open spindle.
KCT1986 is offline
Likes For KCT1986:
Old 03-14-24, 05:12 PM
wesmamyke
Quoted: 196 Post(s)
Liked 86 Times in 76 Posts
It's been awhile since I took one apart with that style bolt, if I recall it's just a normal bolt. The bolt is hollow, so the allen wrench will go all the way through if you let it. Pretty sure it's not self extracting and that cap stays on the bolt.
You can see the odd dust cap here: https://si.shimano.com/en/pdfs/ev/FC...-M540-2401.pdf
Different model number there, but same generation cranks.
Just the bolt: https://rmcbikes.com/en/shimano-octa...-bolt-682.html
Edit: Oops, already posted. I'll leave the link up anyway.
wesmamyke is offline
Old 03-15-24, 05:32 AM
frankenmike
mechanically sound
frankenmike's Avatar
Bikes: Indy Fab steel deluxe, Aventon cordoba, S-works stumpy fsr, Masi vincere, Dahon mu uno, Outcast 29 commuter
Quoted: 100 Post(s)
Liked 84 Times in 53 Posts
In a pinch I’ve used a stack of dimes as an “adaptor” for my standard crank puller with success.
frankenmike is offline
Old 03-15-24, 10:16 AM
grumpus
grumpus's Avatar
Quoted: 504 Post(s)
Liked 437 Times in 336 Posts
Wow, classy - I'd use a penny. :-)
grumpus is offline
Likes For grumpus:
Old 03-15-24, 01:52 PM
Crankycrank
Quoted: 839 Post(s)
Liked 1,064 Times in 747 Posts
Had I known when I bought a crank puller for my old square taper BB back in the day that Octalink would come along and need a different puller, I would have bought one of these that can do both. CWP-7 Compact Crank Puller | Park Tool Simple, bullet proof and cheap.
Crankycrank is offline
Old 03-15-24, 06:48 PM
grumpus
grumpus's Avatar
Quoted: 504 Post(s)
You can get a little magnetic cap to adapt a square-taper puller to a splined crank.
grumpus is offline
Old 03-16-24, 12:17 AM
mark_243245
Thanks. I've ordered a 10mm park tool hex tool, so waiting for that to unscrew the crank bolt. Hopefully that should work.
Also already ordered and waiting for a CWP-7. Which should be Octalink V1 compatible.
Old 03-16-24, 09:04 AM
wesmamyke
Quoted: 196 Post(s)
Watch out for the crank bolt washer. It likes to stay in the crank, and then get stuck on the crank extractor.
