Tool for cutting Delta brake cable...
I have just a tiny bit of cable still coming out from underneath the Delta brake cover as my wire cutters were too thick, how do I get rid of that last bit? Cable fraying would not be a concern as the brakes are now properly set.
Disciple of St. Tullio
Bikes: Ciöcc, Bianchi, DeRosa, Eddy Merckx, Frejus, Hampsten, Kondor, Losa, Magni, Pegoretti, Pelizzoli, Pogliaghi, Scapin
Quoted: 267 Post(s)
Liked 334 Times
A dremel with a cut off wheel. You can probably use a set of needle nose pliers to hold the end while you cut.
When I put cables on Deltas, the very last thing I do is cut the cable. I run it through and down by the tire, get everything adjusted like I want and then cut the cable with the dremel.
Likes For Choke:
