Two-cable IGH spring return a viable option?
Old 01-21-14, 09:54 AM
philski
philski's Avatar
Refer to the diagram below. For a NuVinci n360 you have two shifting cables, the underdrive and overdrive. It seems to be it is possible to use a spring or counterweight to pull the underdrive and then use a conventional shifter for the overdrive (may require modification/consideration for full length of pull). Is there a fundamental reason this couldn't work? Have people tried? A few Googles turned up fruitless.
The difficulty I can see is the 120mm draw length of the cable. The system may need to be a bit more elegant than a single spring.
Open to suggestions (I hope this has been done before, success or otherwise)
Thanks
philip
File Type: jpg
philski is offline
Old 01-21-14, 10:33 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
your lever would need a capstan circumference of 5 inches or take multiple revolutions... (that 12cm)..
how about a pully , 2 housing frame stops, and a loop of cable.. will do the job, I suspect ..
use a bare cable run and attach a ball to it to pull /push
or a big ol' stingray shift lever to pull .. with the distance to lever pivot say 3~4x the cable pull ..
of course, a servo motor could turn that capstan and then you just need a rocker control button
or up/down pair. and a battery ,,
fietsbob is offline
206Moser
Bicycle Mechanics
3
03-10-18 09:54 AM
Paul4444
Bicycle Mechanics
8
04-16-14 08:44 PM
Equinox
Bicycle Mechanics
9
09-27-12 12:08 AM
Ithaka
Bicycle Mechanics
7
08-20-12 10:18 PM
marcelinyc
Bicycle Mechanics
4
01-05-11 09:11 PM
