Disk brake noise that baffles me
Quoted: 608 Post(s)
Liked 352 Times
I know, it is hard to describe noises on the internet but I will try. I have XTR disk brakes and they work great. My problem is when I go down a hill fast, brake hard, I hear a repetitive pinging sound that goes away after about 30 seconds. It sounds like playing cards on the spokes.
First thing I did was tighten the center lock disk down, it was loose. No changes
Second thing, was have the spokes retensioned by one of our own here on BF. No changes.
Sorry about the wind noise but this is the sound on YouTube
Stan's Crest Carbon rims, White Industries CLD hubs, 12 mm through axle. Only happens on the front, not the rear. BTW this is a road bike.
Any thoughts?
Any thoughts?
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Pull out your brake pads. Are they wearing evenly across the pad--or has a lip developed at the top?
Bikes: Diamondback Haanjo Trail, Fuji Team Road
Quoted: 160 Post(s)
Liked 68 Times
I have a similar noise with my disc brakes if I brake hard and/or long on downhills. I think the disc warps from the heat, rubs on the pads causing the noise, and then return to their original shape (and the noise goes away) after they cool off.
Quoted: 608 Post(s)
Liked 352 Times
Someone else suggested this to me yesterday so it might be the problem. Thanks for your insight.
Quoted: 1529 Post(s)
Liked 718 Times
Yeah, the caliper alignment might look good enough on the stand, but add some warping, and hey presto. I'd try to ensure the gaps are as even as possible.
