Going back to 23/25 from 28/30...?
#176
Klaatu..Verata..Necktie?
Quoted: 10440 Post(s)
Liked 11,914 Times
... I think this has been known and accepted for quite some time. Cannondale frames were famously stiff, with their large diameter tubing. And this was used as one of the selling points, along with the lighter weight of the frame. If efficiency is your goal, and you feel like a stiff frame will actually contribute significantly to the efficiency of your rides, I can't argue with that. I am inherently inefficient in so many ways in life that a list would take up too much space.
"Love. Who can explain it?"
#177
Quoted: 3514 Post(s)
Liked 2,927 Times
Likes For smd4:
#178
just another gosling
Quoted: 3890 Post(s)
Liked 1,939 Times
#179
Liked 2,927 Times
They’re Veloflex Master 23s. I think someone here mentioned the model name may have changed (Corsa Race?). I got them online; not sure what the site’s name was.
Interestingly, the Veloflex website says I’m running my tires five pounds below the max!
#180
Liked 2,979 Times
With non competitive road cyclists, I'm pretty sure we mostly tend to aim for comfort, durability, & speed. So finding that sweet combo that does the job without going bankrupt is how I'd expect marketing to align.
-Oh Hey!
-Oh Hey!
#181
Daaaamn - do I dare enter this thread without a bodyguard?
I fit tubeless 32's on the front of my CSI, and 30's on the back, because that's the biggest that fit. Tire pressure is the thumb test, and if more than ~t.h.i.s.~ much deflection, then more air. How much more, you ask? ~T.H.I.S.~ much more.
I fit tubed 28's on the front, and 28's on the back of my Centurion/CInelli, because that's what I have on hand. Tire pressure is thumb test, etc, etc...
Not gonna tell ya what I use on my Mongoose Cipressa Ti, nor my Serotta Concours - They're titanium so that's classified!
Daaaamn - it's only air and rubber people!
#182
Quoted: 1088 Post(s)
Liked 1,026 Times
I've never fully gone the whole wider is better though I've moved somewhat wider. I can remember starting with 19c tires and I do have some left over 23s that are now just dedicated for track use as older tires wear out. But I've found that 25c seems to be my sweet spot. I tried some 27c tires and just found that they felt sluggish/heavy. Currently many of the wheels on mine and the kid's bikes are 19mm internal so the Michelin Pro 25c on my oldest's track bike measures 28.4mm, within .2mm of the external width of the carbon rims she's running. Her road bike has conti 5000s in 25c and it measures a little over 26mm, while my bike this week has 25c challenge elites that measure 27mm on velocity ailerons. I've also used the silca site to get an idea of tire pressure based on rims and they're recommendation was 82/80 for her and 85/83 for me so that's what I run in them. I have to say that for me the ride can still be noticeably harsh over rough pavement, did a circuit race this weekend that had a lot of poorly filled potholes and the ride could be jarring even at this pressure, which is surprising since I run a steel frame. Guess I'm not as tough as I was at 130psi in a 20c tire on Albany streets. Maybe the sluggishness is in my head, I do have to admit the 25c with 85/83psi feels every bit as fast as those older tires but I'm just not fully sold on going still wider. Don't know why anyone would want to still run narrower than 23c.
