Buying a bike repair stand question(s)
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,996 Times
This is the one you had mentioned in your first posting:
https://feedbacksports.com/products/...44212113637674
It is rated to a max working load of up to 70lbs. What someone else has done is of no consequence. I have no doubt you could put a heavier bike in the stand but it will not be stable and it probably won't last long doing that more often and a big heavy cargo e-moped falling on you would SUUUUUUCK! Stability is going to suffer, heck I have seen the Park E-assist lift stands become slightly unstable that is why we double plated them at the bottom. A lightweight aluminum stand is not going to do as well. Just be careful.
Quoted: 6972 Post(s)
Liked 10,970 Times
I own the Feedback HD stand that the OP referenced. I’d say 70 lbs is a realistic upper limit.
Quoted: 2338 Post(s)
Liked 2,827 Times
kindle vs hardcover is personal preference :
you could start buy looking at sections of the park online source....clear and good videos
Bikes: Pedego Stretch 2016 (electric cargo bike for around town and grocery shopping, Small surly Ogre (2015), Bianchi Advantage (46cm) 1993, Bike Friday NWT, 2005
Quoted: 126 Post(s)
Liked 44 Times
Which other stand are you looking at?
Feedback sports pro mechanic
Regarding your method of hauling. Since you're transporting multiple bikes, have you thought about a hitch mount rack? No need to remove wheels.
Quoted: 126 Post(s)
Liked 44 Times
We have two cars - one is an electric Honda Clarity and it's not recommended to attach a hitch and its would void the warrantee if we added it.
We have a 2009 Honda Fit we keep around for a second car and our "truck" for going to the garden center, hauling bikes etc. And we just don't want to spend the money on having a hitch installed on a vehicle we will probably be selling soon. The AC has been repaired 3 times in the darn thing and the last time we said, never again, because it's over $1500 to do it.
So, we just make do until we get a new car with a hitch. My partner works for the government and has been able to work from home for the last 4 years, but they have to go back into the office starting in a month and we will need a more reliable and comfortable second car now. THEN we will get a hitch which will be great!
Clark W. Griswold
Liked 3,996 Times
The one I'm looking at is this one - which I would listed on the REI site:
Quoted: 2496 Post(s)
Liked 739 Times
Thread Killer
Quoted: 3148 Post(s)
Liked 1,714 Times
Buying, carrying around, and deploying a repair stand just to put on a front wheel does not make sense. It probably wouldn’t even be helpful.
I’d suggest the OP figures out what they’re doing wrong first— and they’re definitely doing something wrong— and correct that, because adding a repair stand is not the solution to the wheel problem.
Get a repair stand for any of many other good reasons, but not to put front wheels on properly.
Quoted: 126 Post(s)
Liked 44 Times
Quoted: 126 Post(s)
Liked 44 Times
That is the same one, I thought you had found a different one. If you look at the Feedback Sports website it lists the max working load at 70lbs and that is what I would suggest sticking to that vs. what REI says. You could ask Feedback Sports and have them check as 30lbs is a lot of weight.
Huh... I wonder what that really means. "optimized for 70lbs. Max 100 lbs". I'm going to guess it has to do with actually putting a bike over 70lbs on the rack without assistance? As I would NEVER try to lift my electric cargo bike without help!
Clark W. Griswold
Liked 3,996 Times
Having had a stand topple it was not fun luckily I was not in the way but it did destroy a glass top on a chest and I did eventually get a sliver of glass in my toe because I missed a piece and wasn't wearing any sort of foot covering but still it sucked and I learned to just take the batteries out and that gets the load low enough so it is stable. Though I now wish I had the Topeak E-Up stand I still would probably remove the batteries but it would make lifting way easier thankfully though I do most of my work on that bike at work these days and since I will own the shop I won't have to worry about home repair and probably won't have as much time for it.
Quoted: 126 Post(s)
Liked 44 Times
Nope not that at all. It is usually saying while it may actually mount in the stand and hopefully not actually tip over it is not designed to work at that load hence why they have a load limit. Lifting would have no bearing on the stand you could do it solo or with 3 people or whatever it is more about once it is in the stand. I wouldn't go above 70lbs without a stronger stand with a stronger base and arms and such. It is a lightweight aluminum stand and while it is well made I would keep it to 70 or less or figure out a way to relieve some weight on the stand maybe by having a sturdy wheel holder say at the front.
So, if I'm just going to get a bike stand I can use for the other traditional bikes (of which my family has 6) why go for the $500 one? Wouldn't one of the lighter ones in the mid-range and $100 cheaper be better for most people (including me)?
Quoted: 3514 Post(s)
Liked 2,927 Times
Like someone wrote above, using a stand might be a game changer for you. So you might start with an inexpensive stand, and if you find it helpful then you could move up.
Liked 2,827 Times
So then it makes me wonder - if I should just skip the idea of every doing anything with he electric cargo bike (as it was recommended to always just bring it in for anything anyway, but it just BARELY fits in my vehicle and I have to remove things for it to go in anyway.
I got a park similar to this years ago and have been happy $250 https://www.amazon.com/Park-Tool-Uni...097DZ9XRG&th=1
I have like the next up from the most basic of Park Tool repair stands. My DW was stuck for a Christmas present for me and it must have slipped her mind that I already had a good repair stand. She got this stand for me. She is a good shopper. Does research. Reads reviews. The proof though, when I put this thing side by side with my big blue tried and true, there isn't much not to like. Since four of my bikes are tandems and I've never found a good way to get a standard repair stand to hold a tandem, I plan to use both of them, one at each end! As for the o.p., I think I've found them a bike stand. FWIW
Quoted: 626 Post(s)
Liked 399 Times
I purchased th EVT right angle clamp last year. This clamp does a much better job than the Park clamp.
I bought this stand in 2014. I paid $350 for the stand and $200 for the base plate. I believe it is rated for a 120 pound load. I have worked on ebikes and it holds them no problems. This model doesn't have the lower pivot but it is easily slid around on the carpet. I took the Base plate which had both rust and oil on it to be sandblasted and powder coated for $30.
Clark W. Griswold
Liked 3,996 Times
Quoted: 365 Post(s)
Liked 419 Times
I've had a bike stand for decades, it's great for doing maintenance and for cleaning.
But, I don't use it for centering a wheel in the dropouts. For that task, the bike is on the ground.
Commuter
Bikes: Main Bikes: 2023 Trek Domane AL3, 2022 Aventon Level.2 eBike, 1972 Schwinn Varsity, 2024 Priority Apollo 11
Quoted: 238 Post(s)
Liked 323 Times
I was in a similar boat as the OP. Wanted a bike stand, wanted it to be heavy-duty, as I have one eBike that's around 70 lbs.
The Park Tool one in the earlier ebay link has to be bolted to the floor. That's why it's professional.
The one from REI is way too expensive. You have to do a LOT of your own work to justify a $500 bike stand. Also, all of the bike weight is hanging on one side, so a tripod leg arrangement is unnecessary and takes up too much room. With a two-legged design, you can have it right near a wall for those tight spaces.
The floor-standing ones by Park Tool are very good, but also kind of expensive. I looked and found a nice used on on Craigslist for $100 and bought that. I'm really happy with it. Mine is an older version of the PCS-9.3. Here's their current line-up. Park Tools is an American company and they make quality stuff. Not as cheap as the Amazon stuff, but reliable quality. Here's the rest of their bike stand line-up.
Then, I bought an eMoped (120 lbs.) and there's NO WAY I'm lifting that thing up. I bought a set of Handlebar Jacks and that's my plan to work on that one. (I also put FlatOut in the tubes, so I'm unlikely to get a flat in the first place.) I'll probably also use the Handlebar Jacks on my 70 lb. eBike and only use the stand on my wife's, which is ~ 50lbs. I really like these because they're ultra-portable and they use the bike's own frame to support itself. It's like flipping your bike over to work on it, except that the "jacks" keep the stuff on the handlebar from scraping on the ground. They are US-made, well-designed and well-executed.
So this is your ultimate solution, I think:
- Put your feelers out for a nice used Park Tool two-legged bike stand. (ebay local, craigslist, Facebook Marketplace)
- Buy a (set of) Handlebar Jack for the short term.
Quoted: 626 Post(s)
Liked 399 Times
Likes For Rick:
Commuter
Quoted: 238 Post(s)
Liked 323 Times
You can also bolt the stand to something heavy like a base plate or a used heavy truck brake drum. There are also Bench/Wall Mounts
I bought a Park stand for use with our two 70 lb e-bikes. Sold the bikes and bought two new e-bikes that each weigh 27 lbs and are much much easier to manage.
With their carbon fiber frames I added a Silca stand adapter to support them without using the bike stand's clamp.
https://silca.cc/collections/workben.../hirobel-clamp
Up until now, I have not had a bike repair stand. I just take my bike in for regular maintenance (which I will still do), but I've wished for a bike repair stand for awhile so I can more easily change tires or even line up a tire more easily.
Right now (and for the foreseeable future), if we want to ride our bikes, we need to haul them in in old Honda Fit. We can fit 2-3 bikes in the car if we take off the front wheel. The problem with this is getting the front wheel all centered up properly every time we do this. Maybe having a bike repair stand I can throw in the car will make that easier to center? (or is that silly?)
I figure I would also use this repair stand for cleaning the chain. It has to be easier than trying to do it while the bike is on the ground. I'm also thinking of getting the super heavy duty one because I have an electric cargo bike. The Pro Mechanic HD by FeedbackSports is the one I'm thinking of getting.
As you can figure out - I'm mostly an end user bike rider. I know how too change a tire, but that's about it.
I don't recommend it. And if you got multiple bikes and do lot of service work etc, don't buy the cheap ones. Get a good one. I've no idea which one, as that is what I am looking into now. The $50 still works fine. I may be able to just reinforce the tubing though? I may go to the hardware store and just buy some PVC pipe or something and glue it in there and see how that works out.
But if all you want to do is change tires and wheels, then yeah those stands would do fine.
