Tire slightly unseated
Likes For njkayaker:
Quoted: 501 Post(s)
Liked 632 Times
Can't tell from the picture, easy enough to tell with it in person. Do this, mount that tire on an old school hooked alloy rim, and blow it up to 130 lbs, then you will know. Wear hearing protection. Or zip ties...
Sunshine
Quoted: 10965 Post(s)
Liked 7,492 Times
So in just a few weeks of owning this $3000 bike you have had a tire tear apart at the bead(that's what it looks like), you broke a spoke, and you've gone thru brake pads?
That may be the cheapest and worst put together $3000 bike of all time...or you abuse bikes and need to take up a different hobby.
ETA- or was the brake pad issue on your new fixie that you couldn't even remember the brand name of?
Regardless, the second option above stands.
Likes For mstateglfr:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
Likes For veganbikes:
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Quoted: 2700 Post(s)
Liked 486 Times
Bike shop said it looks like the tire, I thought it was the wheel because I think this is the 3rd broken spoke. No brake pads replaced, but the rotor is severely discolored. Its one of those carbon disk brake bikes that are like 3k, there's like 6+ brands or something and they are all similar. I think the "cheap" pinerello is the one you see all over that is most similar to this model, they are all roughly 3k, like this one https://www.incycle.com/products/202...BoC6NYQAvD_BwE
The faux-fixie is the one whose brake pads died in a week, I bought it because I kept breaking spokes on the carbon thing and don't like riding it with broken spokes.
Sunshine
Liked 7,492 Times
This guy always delivers.
Klaatu..Verata..Necktie?
Quoted: 10436 Post(s)
Liked 11,912 Times
Version 7.0
Bikes: Too Many
Quoted: 1340 Post(s)
Liked 2,482 Times
Larry, more than likely, the wheels are not designed to carry your weight. I ride Fast Forward wheels and the road versions are rated for 220 pound rider. This is the gravel version that is rated for 265 pounds. https://ffwdusa.com/product/gravel/drift/
That is an example not a recommendation. IMO, you need stronger wheels rated for your weight which can be purchased or have them custom made with more spokes.
Edit:
And more than likely, the remaining spokes in the wheel are compromised since you broke 3 spokes already. Judgement call...the wheel may not be safe for you to ride.
Edit:
Passista
Quoted: 868 Post(s)
Liked 721 Times
Like others said, it's not a tire bead seating problem, it's a sidewall problem. Replace that tire ASAP.
Likes For Reynolds:
