The braking system of a bicycle
At present, the common braking system in the market is mostly divided into hydraulic braking and mechanical braking or other, what is the difference between them?
Quoted: 18396 Post(s)
Liked 4,521 Times
Perhaps there would also be differences in disc vs rim brakes.
And rim brakes are divided into several styles.
Calipers, V-Brakes, Canti-Brakes, U-Brakes, Direct Mount, etc.
There have been attempts to make hydraulic rim brakes, but the technology has never taken off.
Liked 4,521 Times
Cable activated rim brakes are a very simple and mature technology, and work very well. They are also lightweight. But, they have downsides, in particular susceptible to grit, and rim wear. Also heating in certain conditions. Cable runs can also be problematic in some situations.
Hydraulic disc brakes seem to be preferable to mechanical cable activated disc brakes, I think due to responsiveness of the brakes. The hydraulic systems are also not constrained by tight angles, and can be run through the handlebar stem/headset, and around tight bends with internal routing.
Quoted: 4453 Post(s)
Liked 4,914 Times
It's mostly divided between "disc" and "rim" brakes actually. They are all "mechanical" systems in the bigger picture.
Quoted: 4227 Post(s)
Liked 2,488 Times
Likes For wolfchild:
Liked 4,914 Times
But that's not where the current "big divide" is with bicycle braking systems. It's all about "Disc" vs "Rim" brakes, whether hydraulic or cable actuated. It just happens that most rim brakes are cable actuated and most higher-end disc brakes are hydraulic. They are all forms of a "mechanical system", so "hydraulic" vs "mechanical" braking is misleading. The 2 main braking systems of interest here are:-
1. Cable actuated rim brakes
2. Hydraulic actuated disc brakes
These ^ are what all the fuss is about.
The other forms are:-
3. Hydraulic actuated rim brakes
4. Cable actuated disc brakes
There is little current interest in the former and the latter is mostly low-end gear, with a few notable exceptions.
Likes For PeteHski:
Likes For kcorfognik:
Quoted: 1364 Post(s)
Liked 1,684 Times
Old fart
Quoted: 3594 Post(s)
Liked 3,407 Times
Likes For JohnDThompson:
And air brakes and electric brakes, but I doubt anyone has ever adopted either of them to a bicycle...
Likes For Reflector Guy:
Hydraulic brakes are just like the brakes in your car. It has fluid in it that puts pressure on the pads to make you stop. And if you ever disconnect the system for maintenance, repair etc. you'll have to bleed the air out of the system (same as on your car).
Quoted: 7030 Post(s)
Liked 11,062 Times
Likes For Koyote:
CheGiantForLife is back!
No one mentioned dragging one's foot.
Likes For ironwood:
Quoted: 696 Post(s)
Liked 910 Times
Does letting aerodynamic drag bring you to a stop count? Technically your using a fluid to slow you down.
Likes For Ghazmh:
Quoted: 9656 Post(s)
Liked 6,366 Times
Quoted: 1948 Post(s)
Liked 2,179 Times
John
Likes For 70sSanO:
ignominious poltroon
Quoted: 2252 Post(s)
Liked 3,465 Times
Likes For Polaris OBark:
Liked 4,521 Times
What happened to the Fixie crowd...
NO BRAKES?
NO BRAKES?
Likes For The Chemist:
52psi
Quoted: 790 Post(s)
Liked 802 Times
Breaks.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
