What bottom bracket tool do I need?
Commuting Fool
Bikes: 1988 Miele Azsora, 2022 State All-Road 4130, 2003 Jamis Coda Comp, 1983 Specialized Expedition, 1994 Norco Monterey
Quoted: 104 Post(s)
Liked 72 Times
I haven’t encountered this tool for a bottom bracket cup before. I tried Parks BBT-22 removal tool and it’s too big. The notches in the bottom bracket cup are more rounded compared to the Park tool as well. The only thing I’ve seen that looks remotely similar would be a Phil Wood removal tool… is this a Phil Wood bottom bracket? It’s a mystery bike from my local bike co-op that came with some very nice parts including a Campy Record pista crank.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Could be a Phil bottom bracket, but Phil mounting rings do fit other cartridges, e.g. SunTour, Edco, etc., which is handy when you want to install a cartridge in a frame with odd BB threads (e.g. French, Swiss, Raleigh, Chater-Lea).
Phil Wood:
Phil Wood:
Likes For JohnDThompson:
Quoted: 2026 Post(s)
Liked 1,096 Times
I believe it does take a Phil Wood tool. The cups you show, and the PW tool, have 18 splines. The Shimano tool has 20 so that is certainly the wrong one. Several on-line shops list the PW tool at less than $20 so it's probably worth trying it.
Likes For HillRider:
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Very useful information… thank you
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
I removed it a couple of days ago and it was indeed Phil Wood. The bearings are trashed, but otherwise couldn’t be happier with the pleasant surprise. Thank you to the community for the help , just wanted to make sure the cups were what I thought they were before I spent 40 bucks for two tools.
Likes For boneshaker78:
Old fart
Liked 3,400 Times
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
The bearings can be replaced. You can either do it yourself by pushing them out of the cartridge shell and replacing them with fresh bearings from an industrial bearing supplier, or have Phil do it for you: service@philwood.com
