Thru axle problem on Bianchi Infinito CV Di2
Quoted: 19 Post(s)
Liked 5 Times
The rear thru axle on my Bianchi Infinito CV Di2, which I spent a fortune on in March, keeps coming loose. The first time it happened the wheel slammed against the rear fork and nearly caused me to fall off the bike.
Today, the front axle came loose and the wheel came off and nearly caused me serious injury. On the way home, I spent one and half hours stopping and retightening the axle to stop the wheel falling off the bike again. When I tried to tighten the wheel, the wheel would hardly turn. When I loosened it off to let the wheel spin. the axle unwound itself.
To make matters worse, the back wheel was also loose when I got home.
Is this a common fault with thru axles, or am I just unlucky? I bought the bike from a shop 200 km away. I have phoned them and they say they have never heard of this problem.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Thru axles are dead simple. Unless there is a problem w/ the threads they don't come loose if properly tightened. And that is usually pretty damn tight.
Likes For cxwrench:
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
something is wrong - either the threads are stripped, you have the wrong thru axles, or something else.
please get this looked at by someone familiar with your bike. Front wheel coming off could get you seriously injured
/markp
/markp
Quoted: 2026 Post(s)
Liked 1,096 Times
You do realize that thru axles have to be slipped into the unthreaded (non drive side) side of the dropout and threaded into the other (drive side) dropout. It is NOT just a slip fit and has to be tightened firmly. If you aren't doing this, you better find someone to show you how.
Quoted: 19 Post(s)
Liked 5 Times
Yep, familiar with that. After the first near death experience, I made sure the axle was as tight as possible. It didn't help. Before every ride, I check both wheels to make sure there is no play/wobble. I did the same today. It didn't help.
Quoted: 1819 Post(s)
Liked 1,696 Times
Unless the thru axle falls out completely it doesn't seem possible that a wheel could fall out of the dropouts. The axle has to be removed from the frame in order to remove the wheel for a flat repair.
Maybe pictures of the axles would be helpful
Bikes: lots
Liked 2,932 Times
ETA: Just had that customer in the store as I was posting this. Santa Cruz mtb, thru axle 1 full turn at least loose. 1 pivot loose. Rear shock mount loose. Bike will not shift, housing is totally pooched and the cable was frayed at the derailleur. Guy had absolutely no idea and it took me a couple of minutes to get him to understand what a cable and housing were.
Likes For cxwrench:
I have the same bike and have not had any issues with my thru axles. Not sure what you have going on but odd you have same issue on front and rear wheel. How could they be coming loose unless they were not installed correctly. Get your self and the bike to the shop.
Quoted: 19 Post(s)
Liked 5 Times
Hi,
I would like to thank you all for your replies. Although some were not that useful, they were nonetheless appreciated.
The importer phoned me this morning to ask me to take the bike to the nearest dealer.
After inspection, it seems there was a fault with the axles. The bike is on its way to Italy!
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Hi,
I had my Bianchi Infinito CV for a little over a year during which time it performed flawlessly. Suddenly this spring, I began having shifting problems that I couldn't figure out as an inexperienced rider. It turned out my riear thru-axle came loose to the extent that the stress of riding on the back wheel damaged the pawls. It was a quick and easy repair by my LBS, However, I noticed a funny sound again after riding about 50 miles, and the thru axle was beginning to loosen again. Now I'm concerned this is going to be a recurring problem.
Quoted: 19 Post(s)
Liked 5 Times
I waited to hear back from Bianchi on my thru-axle problem for a while. In the end, they offered me a new frame or my money back. I took the money.
I hope your problem gets sorted out.
Quoted: 643 Post(s)
Liked 1,526 Times
One thing I didn't see in this thread is if the thru-axle was able to be torqued to spec. If the thread dims were off and it couldn't be torqued properly, the defect should have been obvious from the start. If it could be torqued to spec, I'm curious as to what kind of defect could cause it to come loose.
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
Quoted: 643 Post(s)
Liked 1,526 Times
Perhaps not related to this case, but defects under the head of fasteners can result in reaching torque, but coming loose after a few stress cycles. This is why castings are spot faced. A tilt in the surface will cause the same issue. Non parallel faces on the head side dropout would do this, though I’m not sure that’s the case here.
