Raleigh Super Tourer frame and some of the original components. $300
Quoted: 753 Post(s)
Liked 737 Times
Raleigh Super Tourer frame and some of the original components. $300 Or F+F for $200
21" Raleigh Super Tourist. Seems complete but for the Huret Jubilee derailleurs, seat and seat post and a wheel set.
It has a Shimano 500 rear derailleur that works with the Huret dropouts and a Suntour front and replacement seat and seat post.
Frame shows plenty of patina but generally very clean with minimal corrosion. At some point I will do a full photo shoot.
$300 with "local" pick up or delivery or a $50 delivery fee to drop off any where on the 95 corridor between DC and NY.
I'm only up to NY once a month so there's no expedited shipping service.
This is sort of a "special offer" which will be available till I order a Stronglight crank puller and break the bike down.
At that point I will offer the frame separate from the parts, and probably keep some bits... So act now!
I will also offer as Frame and Fork for $200+ shipping expenses.
Likes For bark_eater:
Quoted: 753 Post(s)
Liked 737 Times
Bump'n
P.S. It may bear mention, that this frame is very similar to the Raleigh Competition. Differences are no rear center pull brake cable bridge, and the chainstays are already indented for larger tires.
Quoted: 753 Post(s)
Liked 737 Times
Bump....
Quoted: 4513 Post(s)
Liked 6,391 Times
I dare say its a wee one, cute as heck though.
Likes For merziac:
Quoted: 753 Post(s)
Liked 737 Times
Again a bump..
Quoted: 753 Post(s)
Liked 737 Times
Back to the top... The delivery van will be heading to NY in a couple of weeks, and a Stronglight crank puller is in the mail, so this will be available as a bare frame soon.
Quoted: 753 Post(s)
Liked 737 Times
Midsummerish bump.....
Quoted: 753 Post(s)
Liked 737 Times
I'll have to check tomorrow. Raleigh lists the bike as a 21 1/2" frame. Top tube is 22 1/2" C-C, if that helps.
Quoted: 838 Post(s)
Liked 1,082 Times
Surprised it’s still here though.
Quoted: 753 Post(s)
Liked 737 Times
The bike is in an awkward spot, but it looks like its 21" C-T with an extra 1/2" sticking above for the clamp.
Quoted: 838 Post(s)
Liked 1,082 Times
The bike is in an awkward spot, but it looks like its 21" C-T with an extra 1/2" sticking above for the clamp. I just found a 19 1/2" 1994 Schwinn Passage who's frame and some bits will need a new home, if a different aesthetic is acceptable.
https://www.bikeforums.net/22965841-post15168.html
Quoted: 753 Post(s)
Liked 737 Times
Señor Member
Quoted: 1492 Post(s)
Liked 1,096 Times
I know what the catalogue says, but I have seven 21-1/2" Raleigh/Carlton frames. That head tube is shorter than any of them. Looks more like the size of my wife's 20-1/2" 1974 International. Likely still not what your friend wants to hear, but, hey. "French Fit".
Likes For USAZorro:
Quoted: 753 Post(s)
Liked 737 Times
I'm pretty sure all the sizes use the same angles and top tube lengths. So if the seat tube is 2" shorter so is the head tube. I have a 23 1/2 Super Tourist frame and it "looks" right.
Señor Member
Liked 1,096 Times
It's interesting that the bike depicted in the catalog appears to have a head tube that is the same length as the 22-1/2" Worksop made MK I Professional that I have, and notably shorter than the 23-1/2" Competition Mk II that I piked up for use as a "guest bike".
Quoted: 753 Post(s)
Liked 737 Times
USAZorro
Here's a 10 year old listing for the same size bike: https://www.retrobike.co.uk/threads/...dition.278062/
Señor Member
Liked 1,096 Times
USAZorro
Quoted: 753 Post(s)
Liked 737 Times
Wasn't meaning to question your measuring. I think the supposition that the geometry of all the models was identical may not be correct. I think the downtube on the Super Tourer may be a degree steeper than on the other higher-end models. That would make it "my size", but unfortunately, the timing is not fortuitous. If I had a couple of my lingerers sold off, I'd be wanting to fill this gap in my 70s collection.
Bikes: 1975 Motobecane LeChampion (silver lilac), 1974 Motobecane Grand Jubile (red/black); 1975 Motobecane Team Champion (orange); 1982 Pinarello Professional (Exorcist Green); 1974 Raleigh Professional MkIV mink blue, 1974 Motobecane Grand Record blk/red
Quoted: 103 Post(s)
Liked 750 Times
I find this topic very interesting, as I too have a few Raleighs in the 21 1/2" size, namely a Professional MkIV, an International, an RRA and a Super Tourer. I went out to the bike garage and measured all 4, all of which were very close to exactly 21 1/2" center to top. I then measured the top tubes - the Pro, International and RRA all went a bit north of 21 1/2", varying from about 21 3/4 to 22". The ST, however, was more like 22 1/2", a bit longer.
Also, it appeared to me that the down tube on the ST has a slightly different angle than the other frames, and thus appears to intersect higher on the head tube. So, it would make sense to me that even though you have a number of frames with the same size seat tube, if the top tube is stretched out, you're going to end up with a shorter head tube, all else equal, just from geometry. Add to that, the possibility that the down tube angle may be different, and that just changes the length of the head tube needed even more.
I also noticed this on my Motos. A lot of folks have observed the Grand Record and Grand Jubile for certain years seem to be the same frame - my '74 GR and my '74 GJ both feature 3 main tubes only in 531 butted, and they have the same faux Nervex lugs. However, I noticed as well that the GJ has a shorter head tube, owing mainly to the fact that it has a significantly longer top tube.
Both the ST and the GJ also have longer chain stays, as I think the original intent for these was to be more on the touring side than the corresponding International/Competion or the GR, respectively.
Your mileage may vary....
Longer top tube on the ST.... also longer chain stays...
Hard to tell but it does seem like a sharper angle on the ST than the RRA....
Likes For 75lechamp:
