1″ to 1 1/8″ headset. Is it possible?
Quick answer: no.
Long answer: a frame builder might do it for you, for probably a unworthy price tag. Probably cheaper to get a new frame or, maybe, look from the other way around and buy a custom front fork with matching specifications from the same frame builder.
Bottom line: if everything is OK and you like your bike, just accept it as it is and live with it, there’s nothing wrong with that.
Quick answer: no.
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 160 Post(s)
Liked 134 Times
The bike guy video I've seen uses an adapter. Is there a different one?
I don't see any disadvantage to using an adapter: you can use all the modern stems, and you still have the height adjustment that a quill affords—kind of best of both worlds. What's not to like?
Quoted: 2026 Post(s)
Liked 1,096 Times
Edit: I found what I believe is his video and he specifically says: "A fork with a 1-1/8" streerer just won't work in a head tube made for a 1" steerer in most cases." Actually that video shows how he converted from 1" threaded fork/headset to a 1": threadless fork and headset. He did not fit a 1-1/8" anything.
Likes For HillRider:
Super Moderator
Quoted: 1173 Post(s)
Liked 931 Times
I use a quill adapter on my vintage steel, and happy with the ability to use modern stems.
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,444 Times
You can purchase a 1 inch threadless fork. To use a 1 1/8" stem you would use a 1' to 1 1/8" spacer. Once it is mounted, it is hidden. Other than that, the quill adapter is the other way.
Go back to that video and see how he did it. I don't have any idea how you can fit a large steerer without replacing the headtube.
Likes For Adis:
Have to replace the frame head tube to take a bigger fork headset ... essentally need a new bike.
Framebuilder-Headset manufacturer Chris King , did at one time show a headtube he machined to look slimmer,
by incorporating the headset bearings into the ends rather than as usual pressing the race assemblies into the standard head tube.
and having a 1.125" fork in it..
SE Wis
Quoted: 2750 Post(s)
Liked 3,407 Times
Short answer - No
Look at the numbers in the chart in #11 here.
https://www.parktool.com/blog/repair...earing%20seat.
Likes For dedhed:
Bikes: 2016 Trek Emonda S6 frameset, custom build (road). 1995 Dawes Genesis Reynolds 531 Competition frameset, custom build (road). 1996 Orange C16R frameset, custom build (retro MTB). Coyote Dual hard-tail, custom build (MTB).
Quoted: 62 Post(s)
Liked 76 Times
It can't be converted? I saw a video from RJ The Bike Guy and he convert his vintage road bike from 1″ to 1 1/8″ . Also the reason why I want to convert it because I don't like the old style of the quill stem. Yes, I know I can change the quill stem to a quill to 1 1/8 adapter but, I don't want to.
1 1/8th to 1 1/8th....oh boy...
Quoted: 1948 Post(s)
Liked 2,180 Times
Is it road or mountain, suspension or rigid?
You still can’t fit a 1-1/8”, just wondering.
Road quill stems including higher rise and short reach are easy to find. Mountain quills may be a bit more limited. Mountain 1” steerer tube forks are tougher to find, especially suspension forks.
John
John
Likes For fietsbob:
Randomhead
Liked 3,706 Times
We just went through this in the framebuilder forum. The answer is no.
The math just doesn't work on that. A standard head tube for a 1" steerer has a 30mm internal diameter. An 1 1/8" steerer tube is 28.6mm, which leaves a difference of 1.4mm. Divide that 1.4mm by 2 and you get .7mm of clearance between the steerer and the head tube. Allowing for a .1mm clearance between the steerer and the headset cup leaves a .6mm wall thickness for the cup. Even with a steel cup, that is not thick enough for safety.
Likes For unterhausen:
Quoted: 440 Post(s)
Liked 464 Times
If the question is can you put a 1.125" headset into a frame meant to take 1", the answer is no.
If the question is can you put a 1" headset into a frame meant to take 1.125" then I suppose there might be an adapter out there.
Quoted: 581 Post(s)
Liked 921 Times
I have a bike with a 1" threadless headset and carbon fork, and a Ritchey 1" threadless stem. They are out there!
From the late 90s to early 2000s, road bikes were commonly specced with 1" threadless headsets. Before that it was all quills, and after that they went to 1 1/8".
Headtube reducer:
https://www.jensonusa.com/Problem-So...adtube-Reducer
Steering tube spacer:
https://www.sjscycles.co.uk/stems/mp...54-mm/?geoc=US
https://www.ebay.com/itm/Steer-Tube-...-/233470928651
Indeed. I purchased adapters for a 1" headset and steer tube fork into a 1.125" headtube frame, and paid a LBS mechanic for the installation. Frame and fork were early and late 90's respectively, and the installation was successful.
Headtube reducer:
Headtube reducer:
Liked 2,180 Times
John
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
I just discovered this thing: https://www.bikeforums.net/classic-v...n-headset.html it does not quite adapt a frame with a smaller head tube to accept a fork that can't realistically fit in it, but it does a much better job of making a clean conversion to a modern threadless fork.
the bike in this video uses it
Randomhead
Liked 3,706 Times
I build road frames with 1" steerers and see nothing wrong with it. 1" quill has a few downsides, but they really aren't significant. I use quill adapters on all of my bikes with threaded 1" steerers, and shims with the threadless ones.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
If the OP is curious, the dimensions here should clarify. The OD of a 1-1/8 steer time is bigger than the ID of the head tube. You'd have to remove the headtube on the frame to replace it.
This might not sound like good advice, but here is how I converted my 1" Mondonico to 1 1/8".
1. I loaded my bike on my roof rack, it had 1" head tube at this time
2. drove it into the garage (you saw this coming, I assume)
3. framebuilder replaced head tube and top tube, using 1 1/8"
voila...now you could skip the part about driving it into the garage
honestly though, just get a bike with a 1.125" head tube if you don't wanna run 1"
