Looking for a road stem with some "style"
Bikes: many
Quoted: 18 Post(s)
Liked 16 Times
I have a 1994 Litespeed Catalyst frame and threaded carbon fork on the way. The Catalyst uses smaller OD tubes and has a bit of a classic road bike look to it. While I will be using modern components, I want to preserve some of that classic look.
What stem would you suggest? Pics appreciated.
I could go with a quill, even though they are kind of a pita. What is a good source for quills?
Or, I could install the threadless adapter and go 1 1/8. What do you consider to be the best looking threadless stems?
Are there other options?
Thanks as always, RFC
YOU ARE NOW TUNED IN
For my money, these two are great. Esp. for a bike from your era, and with a narrower headtube. But, no 31.7. For that: Deda?
Salsa SUL
Salsa SUL
That salsa quill is HIDEOUS. No way!
Not cheap, but hot sexy stem action...
https://www.peterwhitecycles.com/stems.asp
Quoted: 12204 Post(s)
Liked 1,499 Times
I love the look of a Nitto Technomics Deluxe.
Btw, you could also troll ebay for Ti stems.
Bikes: 2001 Fuji Track, 2006 Bianchi Giro
Successful alcoholic
Quoted: 21 Post(s)
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
3T mutant, available in both quill and threadless.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
SLJ 6/8/65-5/2/07
+1 on the 3T Mutant. There's a seller on eBay with quite a selection of size and color. They do look a bit "phallicy" though when you hold them in your hand.
“Life is not one damned thing after another. Life is one damned thing over and over.”
Edna St. Vincent Millay
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 28 Times
Salsa SUL
Salsa SUL
Quoted: 75 Post(s)
If you decide to go with the Nitto Technomic Deluxe(tall) or Nitto Technomic(even taller), make sure your head tube is long enough to get your handlebar as low as you'd like. I have the Deluxe on my old Bridgestone RB, and it's a pretty stem, but I need to cut some of it off to get my handlebar where I really want it.
Bikes: 1994 Proctor Townsend Reynolds 753, TT S3 True North, Kona Major Jake, Kona Honky Tonk, Marinoni Puima, Cannondale BBU
Cinelli Alter. End of discussion.
Senior, Senior Member
Designer
Quoted: 13 Post(s)
Liked 5 Times
If you want classic though, you might want to keep your stem sleek and simple. Afterall, not every single component on your bike needs to scream.
I think any of the stems on this page will do just fine:
Liked 5 Times
sure... if you like the 'industrial/meat knuckle on a stick' look of it...
Bikes: cannondale caad 8 custom
cinelli frog. quill stem with three bolt removable face plate. nitto is nice too
J E R S E Y S B E S T
+1
beautiful
