Vitus Carbone9 bike with missing seat post
Bikes: 2012 Litespeed C1R w/ 10spd DI2, 2005 Cannondale Six13, 1998 GT Forte titanium, 1989 Cannondale SR600 w/Shimano 105 group, Nishiki Pinnacle MTB, Vitus 979 w/Campag Veloce, Peugeot PSV10
Quoted: 22 Post(s)
Liked 14 Times
I just received a Vitus Carbone9 in the post today. As can be seen from the photos someone did a terrible flatbar conversion to it.
The used a MTB trigger shifter for the rear derailleur along with a single downtube shifter for the front derailleur.
This along with the el'cheapo white brake levers were the first things I stripped off of the bike when I pulled it out of the shipping box.
As received the bike has a Shimano Golden Arrow rear derailleur, a Campagnolo front derailleur, a Mavic headset, a Stronglight 175 crankset with 48/34 chainrings and a set of Shimano 105 Super SLR brake calipers.
There is also a matching pair of Mavic 192 NE rims laced to some Exage FH-HG50 hubs.
The biggest problem is the bike is missing the original seat post. Normally this wouldn't be such a big deal but this frame has one of the smallest diameter seat posts I have ever heard of at 23mm.
As a work around some previous owner had shoved a piece of 23mm aluminum tube down into the seat post and then had a hollow Kalloy seat post with a 23mm ID cut off and stuck onto the aluminum tube sticking up out of the frame. A real butcher job. It took a LOT of work to get that 23mm aluminum tube out of the seattube without damaging the frame.
Has anyone ever seen a road type of seat post that is 23mm in OD?
I know such a thing exists because there is a seller from Romania with a Vitus Carbone3 frame for $500 that actually comes with the 23mm seat post as part of the item listing https://www.ebay.com/itm/403891748821
So I am in search of a 23mm road type of seat post like the one shown in this other ebay auction listing.
Quoted: 22 Post(s)
Liked 14 Times
pictures of the seat post butchery
What the seat post should look like
nice 23mm fluted seat post missing from my new bike
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 391 Post(s)
Liked 813 Times
Congrats on the bike, once I missed out by a few hours on the lo-pro version.
aanyway....
Someone has one over here in the German classifieds since last September (I guess there are no hordes of Carbone 9 owners out there)
https://www.ebay-kleinanzeigen.de/s-...96406-217-3499
If you want, I can ask him, if he's willing to post it to the States, but I quickly check the other classifieds as well...
aanyway....
Quoted: 22 Post(s)
Liked 14 Times
aanyway....
aanyway....
Quoted: 1641 Post(s)
Liked 831 Times
The original seatposts used on Vitus Carbone bike was made by Rubis with a 23mm diameter.what was also unique about the supplied (On the Carbones and oater 979s) Rubis seatpost was, it was machined at the back side of the seatpost shat to have a flat vertical strip where the seatpost anchoring grub bolt with the special pivoting tip presses against when you tighten the grub bolt.
The Rubis seatpost comes up once in a while at eBay for sale. It would be best if you get the Rubis seatpost with the machined flat area so it will less likely slip on you while riding.....or you can have it machined yourself if you cannot find the exact seatpost.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 206 Post(s)
Liked 460 Times
Campagnolo made one back in the day. I had this exact frame, but the bolt chewed a hole in the seatpost. If you do find one, I would recommend finding a clamp to use on the seatpost where it would sit on the seat lug. That way you won't have to crank the bolt down as much and ruin your new one.
Liked 831 Times
The important thing is to retain the proprietary seatpost anchoring grub bolt that has a special pivoting nose bearing so it minimizes damage to the seatpost it is anchoring onto the seat lug. The pivoting bearing has a flat portion so it does not dig into the seatpost too deep.
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 22 Post(s)
Liked 14 Times
Or failing that a picture might help so I could see about replicating one.
Liked 831 Times
Unfortunately those special grub screws do not come up that often for sale.I replaced the one on my Carbone Plus 7 some years ago with an NOS one for sale at ebay as the original's allen socket was pretty much stripped out, so I could not tighten it as much as I needed to anymore.I have only seen a couple of them for sale at eBay since. Maybe I just keekept missing them when they came up., but if you stay vigilant and keep checking regularly, one might still come up for you.Most of the ones I've seen since were just regular grub screws with a point at the nose. They should work in the meantime but it means that you might have to live with divots at the back of your seatpost shaft that it will make.
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Liked 831 Times
Here's a link to a business that sold spare parts for classic Vitus frames. IIRC, they are from Canada.https://guywires.com/salestuff/vitusparts.htm
Last I heard about them is they scaled down (Or maybe closed down for good?) drastically some years back, maybe because of dwindling old Vitus parts supplies.You can still see the special grub screw listed on their site. Whether it is still available, I dont know......
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
I am not sure, but you might be able to use a standard (metric) hex bolt with out the pivot if the groove is cut in the seat post along with a clamp as suggested. There may be enough surface area to set the post etc.
It's worth a try with the additional clamp in place.
Good Luck, Ben
Good Luck, Ben
Voltaire
Voltaire
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times
Used in SRT bearings by various manufacturers . Your local bearing/engineering supplies shop should be able to get them ?
Would be better / safer than a standard knurled grubscrew.
Likes For 1simplexnut:
Quoted: 22 Post(s)
Liked 14 Times
Wow, good find! Thanks 1simplexnut
Liked 831 Times
Just remember, the pivoting bearing needs to have a small area of the bearing machined flat.That flat area on the bearing is what interfaces with the flat vertical strip machine on the back side of the seatpost shaft.
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 283 Post(s)
Liked 636 Times
I wonder if some cunning engineer could figure out a way to grind a flat on the ball ?
Quoted: 4513 Post(s)
Liked 6,389 Times
What a (seat) cluster.
Liked 6,389 Times
Also have to assume the original had a provision for keeping the flat correctly located and only turning rotationally, not something a standard bearing grub screw will do.
Quoted: 283 Post(s)
Liked 636 Times
So gonna ask the obvious question, is the grub screw a standard metric thread assuming you could figure out how to get the flat on the bearing?
I think I need to pull the grub screw from the one frame I have with the grubscrew lock and investigate
Also have been wondering what would be the downside to using the ball type instead of the orginal ?
Point contact from a ball so possibly not a lot of deformation to the flat area (if using the original post with a flat. )
It certainly wouldnt gouge like a serrated tip grub screw .
MAybe not enough area to hold post ?
Will have a nosey at the screw in my red Vitus and see what is what in the morning .
Way past my bedtime now (yawn yawn)
Liked 6,389 Times
Was thinking about this myself .
Likes For merziac:
Likes For Hondo6:
Liked 2,182 Times
Wondering why one would need a bearing with the flat, wouldn't there be enough surface on the regular bolt to hold the post in place? The angle of the hole looks perpendicular to the post (close enough) , wouldn't the "flat" bearing still be locked in place with the tightening of the bolt anyway losing its ability to rotate? Standard bolt would be the same...what am I missing?
Ben
Ben
Voltaire
Voltaire
Quoted: 283 Post(s)
Liked 636 Times
Well I pulled the critter out of my red Vitus .
Appears to be correct ? with a flat face to push on the machined flat on the post (should have taken a pic of that too I suppose ?)
The separate tip does not want to rotate but is a different material . Appears to be hardened after a quick swipe with a file .
I see a curve to the od of the tip so suspect a ball with a flat ground in it .
All good fun .
Vitus in red
All good fun .
Vitus in red
Quoted: 283 Post(s)
Liked 636 Times
Ben
Ben
I know what you are saying though . I have a couple of 80s PX10 with an allen head capscrew in the seat tube which locks the seatpost just fine .
Disparaged by most out there but I have never had any issue with it slipping .
Liked 831 Times
So gonna ask the obvious question, is the grub screw a standard metric thread assuming you could figure out how to get the flat on the bearing? Also have to assume the original had a provision for keeping the flat correctly located and only turning rotationally, not something a standard bearing grub screw will do.
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Liked 831 Times
hiya - There is a corresponding flat machined in the correct seat post for these frames .I know what you are saying though . I have a couple of 80s PX10 with an allen head capscrew in the seat tube which locks the seatpost just fine .Disparaged by most out there but I have never had any issue with it slipping .
