Go Back  Bike Forums > Bike Forums > Utility Cycling
[Nihola] Remove front wheels?
Utility Cycling Want to haul groceries, beer, maybe even your kids? You don't have to live car free to put your bike to use as a workhorse. Here's the place to share and learn about the bicycle as a utility vehicle.
Old 07-22-23, 10:16 AM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Liked 118 Times in 99 Posts
Question [SOLVED] [Nihola] Remove front wheels?
Hello,
I need to remove the front wheels on a Nihola Low Single trike with its Magura drum brakes.
I read that it takes two 19mm spanners, but before I go ahead, does someone know how to do it?
Thank you.
Edit: Apparently, it's those two nuts. Not sure why two 19mm spanners would be needed instead of just one.
Winfried is offline
Old 07-26-23, 08:54 AM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Turns out it's the 19mm bolt on the outside. You just need a socked wrench.
Winfried is offline
