Tubeless rescued by a plug
Quoted: 479 Post(s)
Liked 277 Times
I've posted before about these wheels - Cannondale Hollogram - the extreme difficulty to mount/dismount tires. I got all the expected tips, e.g. pinch all the way around, too much tape, start at the valve, start opposite the valve... I've had two pro mechanics attempt the mount/dismount. Both went something like "Damn. This is reaaaaaallll... grrrr... ughhhh..... llly tight" and resorted to using a bead jack. So yeah... I need to ditch the wheels.
Yesterday, 20 miles from home, I got a puncture that wouldn't seal - my bike, back and the rider behind me got sprayed with Stans. Holding the wheel with the hole at the 6:00 position almost worked - leak/spray stopped, held air... for about 1/2 mile.
I was debating next steps: Uber, calling home for a ride... and attempting to tube it - when a club mate pulled out a plug kit and said "one more option".
Plugging the tire was so damn simple. It took about 3 min and sealed completely. I didn't have to enlarge the hole in the tire, so no loss there if the hole's too big to be booted.
Definitely adding a plug kit to the pouches that go with all my tubeless bikes.
(I did slice off most of the excess after taking that pic)
Quoted: 20810 Post(s)
Liked 9,456 Times
Good stuff - they should definitely be in every tubeless users flat kit. That said, keep an eye on it - I've found that, with my sealant (Orange Seal), if the cut is big enough to need a bacon strip, it's also big enough for the bacon strip to eventually work its way out because of the air pressure in road tires. One of the things that I've done to help delay this is to tie a knot in the middle of the strip and shove that inside the tire casing.
Thread Killer
Quoted: 3147 Post(s)
Liked 1,711 Times
I’ve never used a plug, although there were two Pro One episodes— I see the OP was a Pro One, too— where I could have used one. One of those times I limped home with the sealant breaking free every couple miles and pumping after letting it sit cut-at-the-bottom, but the other was an Uber call when I couldn’t wrestle the tire off the rim because I’d forgotten my levers.
Do you have any thoughts on the Dart versus your knot technique? I reckon I should heed the warning and buy some kind of plug kit today.
Liked 9,456 Times
No, the Darts look interesting, but I've only seen them online - I'd like to see/touch them in person before buying; I'm not clear on how bulky the fronds (for lack of a better term) are and whether or not I'd be comfortable with using them on skinny tires.
Likes For WhyFi:
Quoted: 479 Post(s)
Liked 277 Times
I'd mostly considered the plug as a last resort - that the tire would be tossed when I got home. My plan is to pull the tire off the wheel (using a tree as an anchor and the winch on my truck to pull ;-) ) and then inspect the tire. If, after slicing the plug off (inside and out), the hole looks "bootable", I may keep it around... maybe.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
You know what I'm going to say.... "You know what also takes about 3 minutes and leaves you with the peace of mind that it will hold? An innertube"
Otherwise sure these seem like solutions that can help. Bravo.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
Thread Killer
Liked 1,711 Times
Thread Killer
Liked 1,711 Times
You should do a challenge video— tube change vs. plug— and showcase ur skillz.
Liked 9,456 Times
Quoted: 479 Post(s)
Liked 277 Times
I'm by no means a tubeless diehard for road bikes. I won't ride gravel or mtn bikes with tubes, but for the road, I'm kinda neutral. I went tubeless with these wheels because I knew a roadside tube swap would be brutal, and the tubeless route just reduced the odds of a flat. That theory held... for about three years - first flat with the tubeless.
I eat carbide.
Liked 1,306 Times
Who knows. Maybe I'll change my mind someday but every time I see a thread about plugs there's always some sort of mixed experiences. I know a tube works, is cheap and can be reused.
One tip: keep the Dart/pulg in your jersey pocket. The last thing you want is to be fumbling around in a saddlebag while sealant is spraying everywhere and you're losing pressure.
I ride with a Stan's Dart in my pocket. I've (knock wood) never had to use it so I can't comment on its effectiveness. I also ride with a regular ol' tube, Co2, levers etc in the saddlebag. I include a minipump on longer gravel rides.
Likes For Hiro11:
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
I have never worked with the plugs so I can't really comment but honestly I can change a tube in under 3 minutes. Had to do it on my tubeless setup the first ride out this year as the sealant had dried up and I didn't check. I don't ever foresee a point where I wouldn't be riding without a tube ever. Even if the tire is pretty shredded I can get a boot in there and use a tube to get home.
Quoted: 1248 Post(s)
Liked 1,323 Times
I have used and always ride with a DynaPlug Racer system used twice over the years works great. Was on a bike tour in Vietnam a few years ago and got a puncture to big for sealant alone. Jabbed the pug in added a bit of air and all was good for the remainder of the life of that tire. Saved me an roadside repair with a filthy bike covered with who knows what as well a removing bags.
Thread Killer
Liked 1,711 Times
Thread Killer
Liked 1,711 Times
Quoted: 3952 Post(s)
Liked 7,298 Times
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
90PSI seems high for a TL 25mm tire. I weight 185lbs and run 85 rear and 80 front and I am pretty sure I could run 80 and 75.
It's nice to see that a plug worked! Last time I had a flat, 3 LBSs told me a TL tire could not be repaired at all. This is BS. I am sure a patch properly glued from the inside could do the job if the slash is too big for the sealant to do its job.
Liked 9,456 Times
Likes For WhyFi:
Quoted: 166 Post(s)
Liked 252 Times
So I guess IMO its a semi permanent repair, definitely something that needs to be monitored or at least aware of.
Try the pressure calculator at zipp.com and be sure that your pump gauge is accurate. I replaced my very old gage with something much larger and easier to read, with a more appropriate range. At 140 pounds or less, I use 62/64 in my 28mm michelin tubeless.
https://www.amazon.com/dp/B0087UYDPS...v_ov_lig_dp_it
Thread Killer
Liked 1,711 Times
I will just pass on someone else's experience, but a coworker has been using darts on his commuter for a year. three plugged holes over a year using darts. finally broke down tires for sealant and it was all gone the darts had poked his tape(three little holes) and the sealant had filled his rim. He broke the the tires down because he was seeing sealant at all the nipples and it was time anyway. None of this mattered to him the dart is such a fast repair he could care less about tape and sealant loss down the road.
Of course, to even imagine that happening, the tire would have to be ridden on totally flat, which is crazy enough to discount the story, but even suspending doubt for that, it seems unlikely that a Dart plug tip is long enough to reach the rim tape. I mean, the plug tip does not seem as long as even the G Height (i.e. shelf to top of hook), and then to add in the thicknesses of the tread and collapsed sidewall makes it even a longer span. Then you have to imagine the nylon Dart plug tip is hard and sharp enough to pierce the tape on the rim bed.
I suppose it *could* happen to have a catastrophic tubeless blowout which goes flat before you can stop the bike and that a previously installed Dart plug could be pressed far enough into the rim, perhaps by a rock or some perfectly uneven surface, and puncture the tape, but that all seems, honestly, extremely unlikely... and then to happen 3 times? Man, I have a hard time believing that.
Thread Killer
Liked 1,711 Times
Oh, wait...damn, it’s April Fools Day! You got me, sloppy12 ! Haha!
Likes For chaadster:
Quoted: 166 Post(s)
Liked 252 Times
To be clear, since you’re using lower-case “dart” rather than the capitalized brand name, are you indeed talking about the Stan’s Dart plugs?
I really don't care what you discount.
