Mirror Chrome paint - Anybody Try It?
Crawlin' up, flyin' down
Quoted: 1026 Post(s)
Liked 2,528 Times
Has anybody used this stuff on a bike/frame project? I am toying with the idea of using it or something like it to "chrome" some lugs. Feedback more than welcome.
To be clear, I am not committed to this project at all. This is just early-stage "I wonder if . . . " type exploration. "Are you out of your mind?" and "Don't even think about it" are perfectly acceptable responses.
As always, thanks in advance to the Collective for any info you may have.
Likes For bikingshearer:
Quoted: 1088 Post(s)
Liked 1,205 Times
Do you have an old seat post you could prep and test it on?
I know Groody Bros powder coating recently posted on their Instag*ram (anticipating site censor) page showing some powder "chrome" that impressed them, so it's possible other chrome paint is reaching an enlightened age.
If you try it, please post results here!
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
I highly doubt that this would give the same mirror finish as a really good chrome job, but it very well may be better than a vintage Raleigh International chrome lug, which would be more than acceptable for a lot of applications.
Looks like a $40 experiment. I've blown more than that on a lot of goofy ideas.
Quoted: 3511 Post(s)
Liked 2,926 Times
I've never seen metallic paint that looks like chrome, but if it lives up to the hype, why not?
I struggle to think a paint alone can provide that finish. I'd expect to have to a heck of clear job on top of it, but with a can of spraymax 2K nearly anything is possible.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,601 Times
I have, with a similar local product. While it might work, I found that I did not have the patience required for the desired result.
Likes For non-fixie:
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
I have not tried it but it looked promising until I viewed the videos. I suppose if one could spray or dunk it might work......but brushed on can leave brush marks unless a heavy cote is applied....videos on You Tube demonstrate this issue quite well.
JM2C's Ben
JM2C's Ben
Voltaire
Voltaire
Quoted: 3810 Post(s)
Liked 6,699 Times
Quoted: 964 Post(s)
Liked 1,451 Times
Nice, @nlerner !
My experience has been that if you polish up or at least wet sand to 1000 or 1500 grit before painting it can look quite decent.
Quoted: 1106 Post(s)
Liked 1,328 Times
Not that stuff (and for a bottle of 15ml no thank you), but...
https://www.bikeforums.net/classic-v...ass-paint.html
https://www.bikeforums.net/classic-v...-involved.html
Quoted: 566 Post(s)
Liked 1,050 Times
nlerner Is it fair to say it looks like aluminum 2/3 of the way to a mirror finish polish? Kinda’ looks that way in the pic.
Liked 6,699 Times
Quoted: 874 Post(s)
Liked 2,288 Times
It is very hard to have a painted surface that looks like chrome plating but I haven’t tried any of the newer products that are available. It may be fine for small detail work like lugs though.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I saw a new bike with chromed lugs in a bike shop a few years ago. I think it was a Fuji. It looked good. On closer inspection, the lugs were painted chrome; you could tell if you looked real close. It still looked good. I don't think it would be easy to get such a good finish from a spray can. When I've tried, I got a finish that looks quite a bit like polished aluminum that hasn't been polished in a while, which was better than it looked when I started, but not great. It made a pair of crusty steel rims look like aluminum, which is an upgrade, right?
www.rhmsaddles.com.
www.rhmsaddles.com.
I'd try something like this if I really wanted chrome:
https://caswellplating.com/electropl...ting-kits.html
That being said, I repainted a Cinelli I have owned since new because the chrome was shot. It no longer has chrome, or China Blue paint.
Quoted: 3464 Post(s)
Liked 2,829 Times
There are a number of chrome look finishes out there. I stumbled on a YouTube video by a plastic model kit enthusiast where he bought a bunch of brands, followed the instructions, on a few used the instructions from another brand for comparison of results.
most were sprayed on a plastic spoon for test, concave and convex sides.
some were pretty good, I don't know if headlug worthy but for half forks and stays - hundreds cheaper than chrome plating.
way back there was a bike brand from Benelux named The Dura- no chrome but impressive finish.
Shifting is fun!
Bikes: Yes, please.
Liked 4,601 Times
Liked 2,528 Times
Based on what I have read here, odds are I will not run this experiment. If I do, I will try it out on a thrashed and/or craptastic old frame first. So all I would need to get is the paint, the right brush(es), and a POS old frame no one cares about. Other than that, I have everything I'd need.
Thanks for the responses, everyone. As usual, some thoughtful responses. It sounds like no one here as used the particular product I asked about. If I try it out, I'll post the results, but don't hold you breath. .
Liked 2,829 Times
Preval canister spray system- load the thinned paint in the cup, screw on the propellant tank with spray can type tip and spray.
forgot to note that some systems point to gloss black undercoat- among other attributes is will expose surface irregularities. So, files, emery and wet sand in reducing grades is part of the process in my view. ( surface prep applied to perfect chrome plating too)
I have two forks that need plating. One is a Gios, needs strip surface prep and chrome.
another high value fork that needs a chrome crown and tip faces.
will do the Gios fork first. The other may not get done. Hydrogen embrittlement is a thing.
ask the plater if he has an oven.
final note, 531 is probably easier to work with, Columbus has chrome in it... 531 does not, so when the dechroming stops and the tube attack starts...
monitoring very much required.
Has anyone tried to polish the "chrome" paint after spraying and cover the polished "chrome" with clear coat?
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
I have no experience with the one-coat liquid that OP has shared, but did buy (and it's not cheap) some rattlecan chrome paint plus the required black undercoat, made by a company call **** Stix (I don't name them...).
I wanted to use it on a Ciocc that had severe chrome loss, but after making a test on a disposable fork, I decided "no".
This paint does give a pretty good facsimile of chrome plating, but not perfect, plus you need the surface to be perfectly smooth so lots of hand work with the best wet/dry papers and micromesh. Then the black undercoat is crucial and must also be perfect, rather than risk incompatible paints I paid another $20 on **** Stix own black paint, add that to the $26 for the chrome paint.
Then you must wait for the black to cure (several days) and get best "chrome" with thin-thin coats, laying it on thick is counter-productive.
All done the stuff is delicate and tho I did not attempt a clear top coat I have read that this can dull the shine, so at the end of experiment decided "this is not the chrome paint you seek..."
HUH! the censor robot does not like the brand name but I did not pick that and am not mentioning the brand to smear any group or individual. it's Sp_z
