How to remove rear wheel from road bike that has drop out screws.
Question about removing rear wheel from road bike that has drop out screws.
Hello, I'm brand new to this forum and pretty new at cycling in general. I just bought a vintage-styled Bianchi (the Bianchi L'Eroica) and I wanted to take it to my local shop to have pedals put on as well as have a general tune up done but unfortunately the frame of the bike will not fit in my car unless I remove both the front and rear wheel. I have never removed the rear wheel of a bike frame that had adjustment screws on it before so I was wondering... Do I need to touch the adjustment screws at all to remove the wheel, or can I just remove the wheel and keep the adjustment screws intact? I appreciate any and all advice on the matter, thanks!
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
If they are set so the wheel is centered in the frame no need to touch them. Kind of the reason they are there, to center the wheel in horizontal dropouts and allow quick wheel replacement.
Likes For dedhed:
Quoted: 837 Post(s)
Liked 1,061 Times
Likes For Crankycrank:
Likes For dsbrantjr:
Likes For Rick:
Thank you for the replies! So I can safely take off the rear wheel without having to touch the adjustment screws at all? The reason I want to take it to a shop for a tune up is mainly because the rear center-pull break squeaks when using it. Perhaps later on I will find the time to research more on how to regularly maintain my bike but at the moment I just wanted to get my bike set up to be able to ride immediately.
Quoted: 506 Post(s)
Liked 639 Times
Likes For KerryIrons:
The only time I've seen such adjustment screws is on the old style more classic frames with forward facing horizontal dropouts. And since it's an old style classic frame you have I'd bet an E-beer that it's one of that style of dropout. I know that they have a slight downward angle but they are still referred to as "horizontal. The screws in those setups are partly about squaring up the wheel in the frame but also to adjust the chain wrap around the cogset for better shifting. This being the time frame before all the fancy angles and cut aways in the special shifting teeth. The sort with the screws are the types on the left hand side of the picture below. The upper right are more modern and the lowest right is for single speeds and track bikes.... mostly....
So yes, very much leave the screws alone if the shifting is good. And if you need to adjust the wheel tracking it's best to do most of it on the non drive side screw and only a slight adjustment of the other in the opposite direction so that the cogset retains it's position relative to the derailleur. On the other hand if the shifting is spotty then you can play with moving the wheel axle deeper for more wrap or forward for less to alter the shifting. If you're using current or even any cogsets and derailleurs from the last 20 to 25 years though then it'll likely be quite tolerant of the positioning. If the screws don't have locking nuts then add some. They should stay in place. I've even seen set screws on one frame I had. For that one I had to use blue Loctite since there was nothing to add a locking nut onto.
Likes For BCRider:
SE Wis
Liked 3,395 Times
Regarding the screws and shifting. Yes, it also locates the rear cogs in respect to the derailleur, but unless you're at limits of RD capacity I find it usually doesn't have much effect and unless you understand all this best not to worry about it. I've never seen lock nuts on the dropout screws and the springs are sufficient to hold them. In fact more often they are rusted in place and can't be moved.
Quoted: 1608 Post(s)
Liked 2,216 Times
@NewSlang22 - WRT toe-ink. You may or may not be able to make this adjustment. The critical factor is the brake caliper. If it is a casting, like Universal brakes, don't try to adjust by "bending" the caliper arm. It will break.
P1000591 on Flickr
he other option is to use pad holders that have adjustment for toe-in.
P1000591 on Flickr
Likes For SJX426:
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
Those set screws are there to help take up chain slack, in other words to set the chain tension. The tension should not be more or less than a half an inch when you push down on the chain in the center. Once you have the tension set correctly then you make sure the axle is aligned.
It took me a little while to find the CORRECT article on the internet that knew what they were talking about, because I can't explain how to set the screws without showing you, and I can't be there to do that. The internet had 2 pages of incorrect information as to what those screws were for. Without further ado please see:
Simple Ways to Adjust Horizontal Dropouts: 13 Steps (wikihow.com)
Likes For rekmeyata:
Quoted: 3511 Post(s)
Liked 2,926 Times
Likes For smd4:
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
The OP's bike is a typical multispeed w/rear derailer bike, so there is nothing they need to do to set chain tension. Just get the wheel centered up, tighten it, and proceed.
You don't. The upside of vertical dropouts is that if the frame was made properly to begin with you'll never need to mess with it. The downside is that it has to be done right from the start, and you can't run it as a fixie because there's no way to adequately tension the chain. Of course running fixed on a horizontal dropout isn't exactly ideal, but that isn't to say you can't/I haven't.
Likes For jccaclimber:
Liked 2,926 Times
Personally, I use the adjusters to make sure my cog set is as close to the jockey wheel as possible. I also prefer to let the derailleur cage spring do the job of tensioning the chain. But that’s just me.
Likes For smd4:
SE Wis
Liked 3,395 Times
https://www.bianchi.com/bike/campagnolo-10sp-compact/
How exactly do the screws set the chain tension on this?
Likes For dedhed:
Liked 2,926 Times
Likes For smd4:
Likes For bboy314:
Thank you for the replies! I was able to remove the back wheel just fine without having to adjust the screws. I appreciate all the advice given in this thread. I think I will just leave the screws in the position they are in for now (they appear to be set in the middle). Now I just have to find advice on what to do with all the rust inside this 5 year old frame lol ...
SE Wis
Liked 3,395 Times
Likes For dedhed:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Liked 253 Times
Chain tension on a derailleur bike is automatically adjusted by the spring on the derailleur arm, so these bikes have a vertical dropout slot withno adjuster screws. The advantage of the vertical dropout slot is that high chain tension will not cause the wheel to slip forward. I have never seen a vertical dropout with an adjuster screw.
https://www.ebay.com/itm/264628969278
https://www.ebay.com/itm/255640698091
Horizontal dropouts with adjuster screws were used on some higher-end frames throughout the 1980s. I have a very nice late 1980s frame built that way - and it's definitely intended for use with a derailleur (it also has integral derailleur hanger).
Liked 253 Times
Most recent derailleur-equipped bikes have vertical slots. However, prior to the 1980s that wasn't as common. In that era, high-end bikes often if not generally used horizontal dropouts with adjustment screws. Here are a couple of examples - note the integral derailleur hanger on each frame:
Liked 2,926 Times
My question was facetious, since you seemed to suggest that the screws were used to adjust "chain tension" in derailleur-equipped bikes. I was trying to see how you thought such an adjustment could be made in a bike without such screws.
It *sounds* like you believe the screws are used to adjust chain tension in derailleur equipped bikes. Are your 80's era bikes with horizontal dropouts actually fixies? Or do they have derailleurs?
And you seem a bit distrusting of quick release skewers. Used correctly, they won't slip.
right for horizontal, but the question was about vertical. I have a couple of 80's era bikes with horizontal dropouts with the screws and some without, but a person can adjust for the chain slack without the screws, it's just easier with them, and the skewers have to be strong enough to hold the hub in place without slipping.
The comment you made to which I replied reads (in part) as follows:
Chain tension on a derailleur bike is automatically adjusted by the spring on the derailleur arm, so these bikes have a vertical dropout slot with no adjuster screws.
In my reply, I even highlighted the portions of the above to which I was referring. I guess you missed that.
As written, your comment categorically states that derailleur bikes have vertical dropouts. For that categorical statement to be true, it would need to apply to all bikes/frames using derailleurs. That in turn means your statement, as written, is not correct - because not all bikes with derailleurs (or frames designed to be used with a derailleur) have vertical dropouts.
That's the point I was making. It's also why I provided two examples of frames with horizontal dropouts and adjuster screws that had integral derailleur hangers.
Had you qualified your statement concerning derailleur bikes using vertical dropouts to indicate that there were exceptions, I'd probably have said nothing.
