Nipple replacement question
Hi
I am a home bike mechanic and i have build a few wheels already.
I have a perfectly good wheel-set i want to replace the nipples on for aesthetic reasons - the wheel is almost brand new.
i have a wheel building stand with dial gauges, a digital tension gauge, a good spoke spanner and a nipple driver.
my question is if i want to replace the nipples, should I:
I am interested in what experienced wheel builders say on this?
- measure the tension of a spoke using the digital spoke tension gauge, take out the old nipple and re-tighten the new nipple to that tension and repeat for the whole wheel.
- measure the tension on the spokes by strumming the spoke using an frequency counter on my phone, and re-tighten the new nipple to that tension, or
- un-tension all spokes, then replace each nipple and basically rebuild the wheel to the required tension.
- forget it, it is a waste of time and you will only f**k it up
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
If it’s true, round, and uniformly tensioned before you start then if it’s true after each nipple is replaced then you should be good to go. Watch out for spoke twist.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4343 Post(s)
Liked 3,001 Times
3.
If your wheel is true and evenly tensioned, then yeah it's good to go - but if you don't start from a state of zero tension and then layer it on, the chances of buggering something up is pretty high and will be frustrating.
Likes For DiabloScott:
Mad bike riding scientist
Quoted: 6240 Post(s)
Liked 4,249 Times
I agree with DiabloScott. There are too many variables in wheel building for you to detension and replace spokes nipples one at a time. Best to detension the whole wheel, replace the spoke nipples, and then retension the whole wheel.
Stuart Black
Stuart Black
Likes For cyccommute:
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 228 Post(s)
Liked 311 Times
I too would go with approach #3. Aside for your current objective, I use this approach anytime I'm working on a wheel that is seriously outta-whack. Better results in less time.
Dean
Dean
Roll Me Up and Smoke Me When I Die
Quoted: 512 Post(s)
Liked 657 Times
Is 5 a 3 with buggering it all up? That...
Make sure to detention the spokes evenly, I'd go 1/2 to 1 turn at a time, once they have no or little tension left, start changing out for the vanity nipples.
Quoted: 2614 Post(s)
Liked 1,958 Times
I'd stick with #4. You'll only see the nipples when you're not riding.
If you need or want to replace the nipples anyway, I'd start with #1 and plan on proceeding to #3. It's easier to finish truing a wheel that's close to "done" and checking individual spoke's tension, one at a time, will get you nearly there.
Liked 4,249 Times
There’s no need to detention evenly. Layering tension when adding tension is needed to avoid various problems. However just releasing tension isn’t going to cause any issues with later retensioning.
Stuart Black
Stuart Black
Liked 4,249 Times
Okay. But I don’t get the joke. Why would you need to detention in layers? The wheel won’t care because you are going to tension in layers after the spoke nipples are exchanged.
Stuart Black
Stuart Black
Quoted: 4843 Post(s)
Liked 3,969 Times
I'd back off the tension, replace the nipples, tighten till the threads disappear and true and tighten from there, working to minimize spoke tension differences. In other words, exactly like I was building from scratch.
Likes For 79pmooney:
