On the market for a new chain - Suggestions?
Thanks, Datlas. Your post was very helpful. The other thing I noticed about counterfeit items is the box. Like your attached photo, the colors on the counterfeit box are dull and the printing looks like it came off an inkjet printer.
Quoted: 338 Post(s)
Liked 408 Times
In my experience, 'chain checker' tools are terribly inaccurate, although usually they indicate much more wear than is reality, not less wear. There are many reports of chain-checker tools that indicate a new-in-box chain is worn to the point of needing replacement. I use a ruler or tape measure to measure the distance between 12 links. It just seems like 9000 km is a unusually long life for a chain.
Advocatus Diaboli
Quoted: 4735 Post(s)
Liked 1,532 Times
Doesn't wattage come into play for chain wear. 9000kms with average of 200w vs. 9000kms at average of 100w, etc?
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
As title say, I am on the market for a new chain. My current one - KMC X11SL - that came factory equipped on my TCR finally reached the end of its life (0.5% wear) after 9000kms (5600mi) of usage. No complaints about it except that I always found it to be noisier than the other ones I've used in the past.
I've narrowed down my choices to these two. Any thoughts on them or any other ones I should be looking at?
1) Shimano DA (CN-HG901) - Good option & on sale right now
1) Wippermann Connex 11SX - Seems to be better than DA, but also more expensive
I don't mind getting less lifespan if I can have a quieter drivetrain.
Thanks!
Thanks!
Likes For phrantic09:
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
It’s a factor. But maintenance (keeping it clean and lubed) probably matters more.
All cassettes and chain rings eventually wear out. If you repeatedly switch from a worn chain to a new one, eventually you'll get new-chain skip on the cassette or chain suck on the chain rings. If you had a chain with only a few hundred miles on it, it wouldn't skip on the most worn sprockets.
My point is that a chain can be worn out with far less than 0.5% elongation. Most chain wear tests, only measure elongation, which is WRONG.
Last year, I bought two "Ultegra" chains from Amazon and BOTH snapped after only a few miles of riding. Both were purchased from what appears to be the actual Shimano store on Amazon, at least the listing links back to it. Both chains snapped nowhere near where I had cut them to length and nowhere near the quick link. This is obviously terrible from a safety perspective. I'm certain both chains were counterfeit, a risk I was not aware of at the time. This isn't hype, DO NOT BUY CHAINS FROM AMAZON. Actually, I've stopped buying anything bike-related from Amazon. I don't trust them.
Advocatus Diaboli
Liked 1,532 Times
Good point, I have no idea who is actually running the "Shimano Store" on Amazon. Maybe the ones I got were legit, but I've never had an Ultegra chain snap before. Let alone TWO after less than 100 miles each. I've just glad this neither break happened during a hard effort.
Advocatus Diaboli
Liked 1,532 Times
https://www.optivations.com/
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
9000km doesn't sound like too much with a good lube - things like Silca / Ceramicspeed / actual waxing should be easily able to do it. Of course, weight, riding conditions and all that are going to influence the story. I've got about 6500km on my current chain and it's really fine. Occasionally I swap to a fairly fresh race chain and there's no difference in length or shifting.
Of course! A stronger rider will stretch its chain much faster. Newton's third law!
Quoted: 6963 Post(s)
Liked 10,963 Times
I do believe that people are getting poor lifespan because of poor maintenance. I lube mine (wax based lubricant) every 100kms even if the recommended interval is 200kms and I deep clean it every 1000kms. Some people don't care about their chain lifespan and replaces them at specified mileage while others like me want to get as much as possible.
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1252 Post(s)
Liked 1,284 Times
Interestingly, my wife had been struggling with sloppy, unpredictable shifting on her road bike for several months, despite having a brand new Shimano Ultegra cassette and chain installed along with a tuneup...and then a follow-up tuneup by a different mechanic...and then another follow-up tuneup by a still different mechanic! Finally the fourth mechanic got it dialed in...but one of his comments was "Those Ultegra chains don't last as long as many other brands because long before they start to show wear from any of the traditional chainwear indicators, their side plates have bent or twisted slightly due to all the weight-reduction sculpting, so they no longer shift smoothly." He replaced the Ultegra chain -- which had less than 2,000 miles on it -- with a KMC chain.
Quoted: 3952 Post(s)
Liked 7,297 Times
Likes For tomato coupe:
Liked 10,963 Times
Likes For Koyote:
Achtung!
Bikes: 60.1, Marvel
Quoted: 515 Post(s)
Liked 268 Times
Where are people buying the Connex chains? I have new chains on both of my bikes, but I’ll probably need to get more next year and would like to give these a try. I am not interested in eBay or Amazon vendors - just don’t trust them after seeing the fake chains thread. Thanks in advance.
Quoted: 426 Post(s)
Liked 274 Times
I can't tell the difference between kmc, shimano, durace, sram chains and I usually have 3 on rotations. I soak my chains to clean them so I need a few chains.
Maybe if I only used one chain I would notice how long it wears or how quit it is etc. dunno. I take off my chain once a week. There's always a big difference putting on the cleaned oil chain vs the dirty one week old chain with 100+ miles on it.
Likes For sean.hwy:
I have had both SRAM, Shimano, KMC and Campagnolo chains.
1. All look, feel, sound and work identical to me.
2. A new chain always feels, looks and sounds better than a worn chain, that's the only thing I can tell.
3. I like KMC because of the missing link, and they are usually pretty affordable for lightweight chains
Likes For maartendc:
Quoted: 338 Post(s)
Liked 408 Times
Using a top shelf lube makes chains last longer, saves watts and they're actually cleaner, all at no extra effort. The only downside is price.
When I went from "whatever is in the shop" to Squirt my chains started living longer. Further change to Ceramicspeed UFO made the whole drivetrain cleaner and again extended chain life. All for the same effort.
Places like ZFC and others who test this stuff do the cycling world a favour.
Quoted: 426 Post(s)
Liked 274 Times
Amazon is almost aliexpress now :/
Most of the time when I search for something specific it returns 99% not what I want and it's always from some overseas no name company.
Likes For sean.hwy:
Liked 7,297 Times
Using a top shelf lube is not where the extra effort comes in -- it's lubing your chain every 100 km and deep cleaning it every 1000 km to eke out extra mileage. That's what the "my time is valuable" is about.
Liked 10,963 Times
I just replace a chain when it seems to be getting a bit worn. But then, $40 for an Ultegra chain isn’t a big deal to me.
