Wheelset Questions
Quoted: 139 Post(s)
Liked 43 Times
Wheelset Questions
I am shopping for an alloy wheelset for my Giant Contend AR that will be a noticeable improvement over the stock Giant SR2 Disc wheelset, and I am a bit confused after all the reading I have done from online sources. Usually, I can see certain comments repeated from different sources and get a sense of some sort of consensus on what products are good. E.g., with groupsets, you often read that the Shimano 105 is the "sweet spot" for a good price and performance balance, or with bikes there are numerous reviews with specific pro and con items identified. With wheelsets I am seeing anything but a consensus or any detailed reviews that sound like more than advertising copy.
So far, I have identified the Hunt 4 Season Disc wheelset for under $400, with a weight of 1588 grams as a likely candidate. I know I can ask Hunt these questions, and I will, but any input from BF members will be appreciated. Generally, is it a good wheelset that is likely to make a noticeable difference over the factory set? Is that a reasonable weight or need I go to a much more expensive option in order to get a meaningful weight difference? I cannot find the Giant stock wheelset weight listed anywhere so I don't even know what I am starting with.
I assume I need to ensure that it is compatible with my Claris 8 speed groupset, my disc brakes, and my through axles, though it looks like it will be except, possibly, the 8-speed cassette. I recently mounted 32cm Continental GP5000 tires, with latex tubes, on my bike and was very pleasantly surprised at the degree of improvement and would like to use the same tires on a new set.
I would also like to identify other brands that might be a rough equivalent. I have been looking at Shimano's but other than price, I cannot determine how similar they may be in quality or features.
I have read several putative wheelset guides online (Ultimate Shimano Wheels Guide and Hierarchy, etc.) and am no less confused. Any suggestions for <500 dollar wheelsets? Any other specific things I need to worry about?
PS, no need to warn me that I am wasting money on a cheap bike. I love the frame and it is part of the hobby I love to spend a little more changing the bike a bit here and there.
Expired Member
Quoted: 3681 Post(s)
Liked 5,446 Times
Is there an improvement are you hoping for beyond weight? What is the weight of your current wheels? In general, you'll probably have at least double, maybe triple your budget for any noticeable difference.
Quoted: 6973 Post(s)
Liked 10,975 Times
OP: If you don't know how to ascertain which wheels are compatible with your drivetrain, I think you should go to a shop (ideally the shop at which you purchased the bike) for help with choosing a new wheelset.
And even though you don't want to hear it, you will be spending money in an attempt to turn a sow's ear into a silk purse. Rather than upgrading a bunch of parts, you'd be better off (economically) by just buying a better bike and relegating your old one to the trainer or for rainy day riding.
Likes For Koyote:
should be more popular
I assume one could find (used?) semi-deep carbon wheels for around that budget that would at least provide some additional aero benefits at a similar weight as these Hunt wheels?
Quoted: 432 Post(s)
Liked 461 Times
Wouldn't be surprised if the stock wheels were north of 2kg. Almost anything would be an upgrade. I think 1500g is a good target for a new wheelset, so the wheels you mentioned aren't far off. The rotors will either be 6 bolt or centerlock but even if the two wheels have different rotor interfaces you can just get new rotors to match the wheel. As far as the cassette, 8-11sp Shimano all have the same interface; you may need to add a spacer or two to use the 8sp cassette with an 11sp freehub. Your tires and tubes should be just a straight swap.
Likes For tFUnK:
Tomorrow, our club is doing a 50 mile to the ice cream festival.
My new wheels have not arrived yet, so in the spirit of this discussion I figure that I will be 3rd in line instead of 2nd. At normal guy level, that is the amount of improvement you will get.
But the return trip, with a belly full of peanut cluster toffee crunch....probably last.
Likes For bblair:
Quoted: 6199 Post(s)
Liked 4,816 Times
Wheels won't improve your ride comfort if that is what you are seeking better wheels for. Get better tires for that.
If you do a lot of riding at a high speed that has tight turns and other technical things to challenge you then you might need a better set of wheels that lets you feel the road better. Otherwise, weight will likely be the only benefit, and that might not be much depending on what exact model rims and hubs are on your bike right now. Some alloy rims aren't very much heavier than some carbon rims.
So again if your demands for cornering performance and being able to sense the road through your bike isn't one of your needs and talents yet, then just ride some more and save the money for a better bike.
Likes For Iride01:
Quoted: 878 Post(s)
Liked 726 Times
You'll notice a difference in weight and hub engagement on those Hunts, but I would recommend finding a wheelset with wider outer rim width to pair with 32mm tires. I have a Hunt Aero Disc Light wheelset with 32mm GP 5K TLs and they're noticeably bad in crosswinds and feel unstable, enough so that I'd rather use a heavier DT Swiss wheelset with slower and heavier 35mm Pirelli Cinturato Velos on my foul weather bike.
Likes For surak:
Shimano WH-RS100, WH-RS500, or SuperTeam, are great options for <$500
Likes For ussprinceton:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1950 Post(s)
Liked 1,475 Times
Liked 4,816 Times
But maybe you are correct. I'm not certain 5 PSI would be that noticeable a change in ride comfort. And if you are claiming the PSI should be dropped much lower then you could have just dropped the pressure for the tire on the original rim.
Zinn talked about heat build up on rims and some vs rim size and some of what little of the discussion I understood is what gives me cause to doubt you..
Technical FAQ: The science of tire pressure, rim width, and heat buildup
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I can't comment on comparisons to your existing wheels, but I think the Hunt Four Season Disc set will be quite good. I have Hunt's Four Season Aero (rim brake) wheels on my bike, and I like them a lot. They're very similar to the ones you're looking at. Hunt gives good customer service, they build a quality product, and their prices seem to be in the sweet spot for avid recreational riders. This has been my experience, anyway. I'm sure there are other options that would work just as well. The question still remains: What are you hoping to achieve by replacing your existing wheels?
Liked 1,475 Times
Not quite certain I agree. You might drop the pressure 4 or 5 PSI for a rim that is 4 mm wider internally, but the same road forces are still going into the rim/wheel at that lower pressure.
Total System Weight: 220 lbs.
Surface Condition: New Pavement
Wheel Diameter: 700C/29"
Average Speed: Recreational
Measured Tire Width: 25 mm
Tire Type: Mid-Range casing butyl tube
Weight Distribution: 48/52 (road bikes)
The calculator returns: 94.5 PSI rear, 92.5 PSI front.
Keeping all parameters the same except increasing Measured Tire Width to 26 mm results in 89 PSI rear, 87 PSI front.
Keeping all parameters the same except increasing Measured Tire Width to 27 mm results in 84 PSI rear, 82 PSI front.
If I recall correctly, going from 17 mm IW to 19 mm IW increased the measured width of a slightly used GP5K (having a nominal width of 25 mm) from 25 mm to 26 mm.
For comparison, BRR testing 25 mm wide tubeless tires (which have stiffer sidewalls) shows a 1.7 mm increase in tire width going from 18C to 22C wheels. The Rim Width Test | Bicycle Rolling Resistance
I can feel a 5 PSI difference; whether that significantly affects comfort is a more difficult question.
So, if one is increasing internal wheel width by 4 mm as you originally posited, Silca would suggest a 10 PSI decrease, while BRR would suggest a 10-12 PSI decrease.
