Addiction 2022.2
#3851
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,898 Times
The Canyon has a carbon post. Given it's rated for heavier than I am, I don't worry too much about it.
Likes For genejockey:
#3852
Liked 11,898 Times
Position should be the same, but fractions of millimeters count here. If you want to test them, I'd go ahead and center the calipers on them, using the business card trick, and then see if you still get rub.
#3853
Mostly Harmless
Bikes: Have two wheels
Quoted: 13714 Post(s)
Liked 4,529 Times
#3854
Mostly Harmless
Liked 4,529 Times
#3855
Quoted: 20810 Post(s)
Liked 9,456 Times
#3856
VFL For Life
Bikes: Velo Volmobile
Quoted: 28614 Post(s)
Liked 1,857 Times
It's a mystery why anyone lives there.
Childhood favourite?
#3857
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12771 Post(s)
Liked 7,687 Times
Cinque.
Wordle 320 5/6
Wordle 320 5/6
#3858
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
#3859
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
I’d try it both ways, it sounds to me like you’re describing wheel flex that’s making the rotor ping
#3861
Quoted: 18415 Post(s)
Liked 15,545 Times
I choose to blame all of you.
Wordle 320 X/6
Wordle 320 X/6
#3862
Fat n slow
Liked 2,085 Times
This weekend’s “race”
https://www.strava.com/routes/2954800741709751144
This is only about 20 miles of dirt that’s pretty well groomed. All of the major climbs are dirt which add some challenge. One of them last year I spun out and had to get off and walk, hopefully wider tires and better gearing will fix that. Believe it hits ~18% in a few places. Last year was 28s with 36/30 as lowest gear and this year will be 32s with 31/34.
pretty excited and have no real expectations, just do it for fun.
Likes For phrantic09:
#3863
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
#3864
So it is
Quoted: 11401 Post(s)
Liked 4,758 Times
#3865
So it is
Liked 4,758 Times
#3867
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3193 Post(s)
Liked 1,842 Times
Likes For seedsbelize2:
#3868
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Likes For datlas:
#3869
Liked 9,456 Times
I’ve been talking to seattle forrest, he has a C3 with ardennes and hasn’t ever had brake rub problems. So now I wonder if it’s the cheaper carbon my bike is made of, or the super teams, though they seem bullet proof not sure what that says about flex’s.
if I put my bontrager wheel on the cervelo to test out the wheel theory, would it matter that the rotor on the bontrager wheel is sram? I would not touch the brake. I could tell in a matter of seconds whether or not the rub was there.
If there's no rub in the stand but there's rub on the road, that obviously means that there's a change in relative position between the rotor and pads. The rotor is bolted to a solid, machined hub. The hub is being held in place by a ~1/2" thick axle. The axle is fastened in to the dropouts and there's only a couple inches of carbon fork between the axle and caliper - there's virtually no room for movement if everything is secured properly. If things aren't secured properly and if things aren't quite square and true, you get problems like you're getting.
Make sure your rotor is true and properly tightened. Make sure your calipers are centered and aligned. Make sure you're consistently tightening the thru-axel. If you can't consistently tighten the TA because if its design, get a Robert axle and use a torque wrench. Done and done.
Likes For WhyFi:
#3870
Quoted: 9653 Post(s)
Liked 6,365 Times
Wordle 320 3/6
#3871
Bikes: Shmikes
Quoted: 10167 Post(s)
Liked 5,862 Times
have not had that happen yet. I had the rear wheel not what to open once in Dallas. That was a head scratcher.
If a closet door is sticking, you don't try a different door - you make sure that the hinges are tight, that the frame is plumb and that the door is square. Everything else is a shot in the dark and a waste of time when the basics haven't yet been addressed, IMO.
Have you taken a plastic tire lever and pressed your pistons in and then made sure they're retracting?
#3872
Quoted: 10236 Post(s)
Liked 5,184 Times
I have. The rotor has a slight bent in it. However, spinning in the bike stand with a white sheet of paper behind it there is plenty of clearance and it doesn’t rub, when I ride it sitting down 75 percent of the time it doesn’t rub. When I stand it’s a constant rub. The skewer is as tight as I can make it.
sounding like a new axle and new rotor. I’m just super skeptical that’s going to fix the problem. And furthermore how the hell do my rotors keep getting bent?
#3873
Liked 5,184 Times
#3874
Liked 9,456 Times
If the rotor is a Shimano IceTech, which is an steel and aluminum sandwich, it's not going to take much at all. If it's a solid steel rotor, you may need to bend it a little beyond true so that it springs back in to a more true position.
Jump to the 3min mark or so, if you're impatient -
#3875
Liked 6,365 Times
